Compute histogram summaries with the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 3-min read
This page describes how to ingest histograms via the OTel Collector, which can help you to reduce costs associated with ingestion.
You can also use the OTLP ingest API to ingest histograms directly, without additional data manipulation.
The following configuration example shows how to use the Collector to compute and ingest summaries of histogram buckets, such as the overall sum of all values in the bucket and their total count.
Prerequisites
  • One of the following Collector distributions with the transform and filter processors:
    • The Dynatrace OTel Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • The Dynatrace API endpoint URL to which the data should be exported
  • A Classic access token with the relevant access scope (only required for SaaS and ActiveGate)
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Demo configuration
receivers:
otlp:
protocols:
grpc:
endpoint: 0.0.0.0:4317
http:
endpoint: 0.0.0.0:4318
processors:
transform:
metric_statements:
- context: metric
statements:
# Get count from the histogram. The new metric name will be <histogram_name>_count
- extract_count_metric(true) where type == METRIC_DATA_TYPE_HISTOGRAM
# Get sum from the histogram. The new metric name will be <histogram_name>_sum
- extract_sum_metric(true) where type == METRIC_DATA_TYPE_HISTOGRAM
# convert the <histogram_name>_sum metrics to gauges.
- convert_sum_to_gauge() where IsMatch(name, ".*_sum")
filter:
metrics:
metric:
# Drop metrics of type histogram. The _count and _sum metrics will still be exported.
- type == METRIC_DATA_TYPE_HISTOGRAM
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
service:
pipelines:
metrics:
receivers: [otlp]
processors: [transform,filter]
exporters: [otlp_http]
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we configure the following components.
Receivers
Under receivers, we specify the standard otlp receiver as active receiver component for our Collector instance and configure it to accept OTLP requests on gRPC and HTTP.
Processors
Under processors, we configure the following two processor instances:
  • transform, to compute the desired sum and count values of the histograms:
    • We first use the function extract_count_metric to compute the number of values in each histogram bucket.
    • Then, we use the function extract_sum_metric to compute the total sum of all of its values and convert it to a gauge using convert_sum_to_gauge.
  • filter, to drop the existing histogram buckets (based on type) and avoid histogram-related error messages.
With this configuration, the Collector drops histogram metrics and creates in their place two new metrics for the sum and item count of each respective histogram.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization:
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest metrics (metrics.ingest) scope.
Service pipelines
Under service, we assemble our receiver and exporter objects into a metric pipeline and enable the two processors by referencing them under processors.
Limits and limitations
Metrics are ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP API and are subject to the API's limits and restrictions. For more information see:
  • OpenTelemetry metrics limitations
  • Dynatrace metrics mapping
Related topics
  • Enrich ingested data with Dynatrace-specific fields
Related tags
Application Observability
