Enrich OTLP with OneAgent data (non-containerized) (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 2-min read
The following configuration example shows how you configure a Collector instance to enrich OpenTelemetry data with OneAgent host entities.
Enrichment is used for linking OpenTelemetry data to its OneAgent host and properly associating it within the topology model. For example, when ingesting logs from different hosts, tying the host entity to the respective log data allows you to run host-based log analytics tasks.
Container environments
Enrichment is specific to non-container OneAgent environments. Configuring a containerized Collector enrichment setup may lead to incorrect host and topology associations.
Prerequisites
  • One of the following Collector distributions with the Resource Detection processor:
    • The Dynatrace OTel Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • A OneAgent running on the same host as the OTel Collector, where the OneAgent monitors in either Full-Stack, Infrastructure, or Foundation & Discovery mode.
  • The Dynatrace API endpoint URL to which the data should be exported, configured as system environment variable
  • A Classic access token with the relevant access scope (only required for SaaS and ActiveGate), configured as system environment variable
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Demo configuration
receivers:
otlp:
protocols:
grpc:
endpoint: 0.0.0.0:4317
http:
endpoint: 0.0.0.0:4318
processors:
resource_detection/dynatrace:
detectors: [dynatrace]
override: false
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
service:
pipelines:
traces:
receivers: [otlp]
processors: [resource_detection/dynatrace]
exporters: [otlp_http]
metrics:
receivers: [otlp]
logs:
receivers: [otlp]
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we configure the following components.
Receivers
Under receivers, we specify the standard otlp receiver as active receiver component for our Collector instance.
This is mainly for demonstration purposes. You can specify any other valid receiver here (for example, zipkin).
Processors
Under processors, we specify the resource_detection processor and configure it with the Dynatrace-specific detector dynatrace.
With this configuration, the resource detector processor will attempt to load the following two attributes from the OneAgent enrichment file:
  • dt.entity.host
  • host.name
If the resource detector could load these values successfully, it will add them as resource attributes to the OTLP request. No additional processor configuration is necessary.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and headers.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest logs (logs.ingest), Ingest metrics (metrics.ingest), and Ingest OpenTelemetry traces (openTelemetryTrace.ingest) scopes.
Service pipeline
Under service, we assemble our receiver, processor, and exporter objects into service pipelines, which will perform these steps:
  • accept OTLP requests on the configured ports
  • enrich them with the Dynatrace-relevant host data, using the resource detector processor
  • and export the enriched data to Dynatrace
Related tags
Application Observability
