Unified analysis reference
  • Dynatrace Classic
  • Reference
  • 34-min read
  • Published May 19, 2022
This is a general description of the unified analysis extension YAML file and ways to create custom visualizations and configure cards, dashboards, and injections.
Details settings
To customize the details page, start with the detailsSettings and specify the types of information to be included on a unified analysis page. This enables you to customize the page to show all of the data points, charts, and visuals that are most relevant and beneficial to you.
detailsSettings:
staticContent:
showProblems: true
showProperties: true
showTags: true
showGlobalFilter: true
showAddTag: true
layout:
autoGenerate: false
cards:
- key: cpu_mem
type: CHART_GROUP
- key: disks
type: ENTITIES_LIST
staticContent
Enable or disable static elements like problems, properties, tags, global filter and Add tag option.
FieldTypeDescriptionRequired
showProblems
boolean
If true, the details page shows the problem card.
Required
showProperties
boolean
If true, the details page shows the properties card.
Required
showTags
boolean
If true, the details page shows the entity tags.
Required
showFilterBar
boolean
If true, the details page shows the filter bar.
Required
showAddTag
boolean
If true, the details page shows the Add tag option.
Required
layout
Reference cards that should be shown on the page (like chart groups or entity lists) or use the automatically generated page layout.
autoGenerate
boolean
If true, the page content is automatically generated.
Required
cards
enum
Possible values for type field: CHART_GROUP, ENTITIES_LIST, EVENTS, LOGS, MESSAGE, METRIC_TABLE, INJECTIONS, BREAK_LINE, HEALTH_CARD, CARD_GROUP.
Optional
Details injections
The detailsInjections field defines injections for the entity details page. This information can be used to better evaluate user experience and also help with root-cause analysis.
Injections must be supported by the page—the layout needs to include an injected cards placeholder.
detailsInjections:
- type: CHART_GROUP
entitySelectorTemplate: type(custom:host), toRelationship.sameAs($(entityConditions))
key: injectedChartGroups
- type: ENTITIES_LIST
key: injectedList
width: HALF_SIZE
- type: EVENTS
key: injectedEvents
width: FULL_SIZE
type
enum
Defines the type of card available to inject. Possible values: CHART_GROUP, ENTITIES_LIST, EVENTS, LOGS, MESSAGE, HEALTH_CARD, CARD_GROUP, METRIC_TABLE.
Required
key
String
The unique key of the card, which is used to reference desired card configuration.
Required
String
Entity selector pointing to related entities.
Details
It can serve multiple purposes—selecting the entity where the chart will be displayed and filtering them based on certain rules or relating entities. It is used in conjunction with entityType to further refine which entities are applicable for the card. For example, if entityType is HOST, you can use entitySelectorTemplate to show the card only for hosts using a certain operating system.
$entityConditions acts as a dynamic placeholder, adapting to the context in which the card appears. For example, when the card is displayed on a page dedicated to a specific host, $entityConditions will automatically adjust to conditions applicable to that host.
For example, when the card with the following configuration is displayed on the host page.
"entitySelectorTemplate": "type(NETWORK_INTERFACE) AND fromRelationships.isNetworkInterfaceOf($(entityConditions))"
The $(entityConditions) placeholder will be automatically replaced to point to the specific host entity.
"entitySelectorTemplate": "type(NETWORK_INTERFACE) AND fromRelationships.isNetworkInterfaceOf(type(HOST) AND entityId(HOST-<id>))"
Optional
width
enum
A value that determines how much vertical space the card is taking. Possible values: HALF_SIZE, FULL_SIZE.
Optional
Details filters
The detailsFilter field defines filters for the entity details page. It enables you to customize the page to show only the data you want to see. It automatically displays metric dimension filters if there are any dimension splits on the page (chart or metric table). To display only metric dimension filters, define it as empty (detailsFilters: {}).
detailsFilters:
relationships:
- type(HOST_GROUP), toRelationship.isInstanceOf($(entityConditions))
- type(AZURE_REGION), fromRelationship.isSiteOf($(entityConditions))
entityFilters:
- displayName: filters
filters:
- type: entityName
displayName: name
freeText: false
modifier: contains
defaultSearch: true
distinct: false
entityTypes:
- my:interface
relationships
You can enable filtering by configuring the relationship between page entity type and related entity type. For example, filter process list by host name:
relationships:
- type(HOST) AND toRelationship.isProcessOf($(entityConditions))
You can also configure the filtering on multiple levels. For example, filter the processes by host group name:
relationships:
- type(HOST) AND fromRelationship.isInstanceOf(type(HOST_GROUP))
entityFilters
The block that defines the groups of filters (these are displayed slightly grayed out in the filtering list).
filters
Array
The actual filters that are part of this group.
Required
type
String
Must reference an attribute of the entity you are filtering. Note: every entity has entityName as a default attribute.
Required
displayName
String
How this filter is labelled within the web UI.
Required
freeText
boolean
If true, the user can freely type text; otherwise, they must select from a list of suggestions. Note: only default attributes such as entityName are capable of offering list of suggestions.
Required
modifier
boolean
When freeText is true, this defines how the text should be matched against the attribute. When freeText is false, this must be omitted. Note: All non-default attributes must match as equals regardless of this option.
Optional
defaultSearch
boolean
If true, if the user starts typing without selecting a filter first, this filter is selected by default. Only one filter within the filtering block may have this enabled.
Optional
distinct
boolean
If true, only one instance of this filter can be applied.
Required
entityTypes
Array
A mandatory list of entity types that this filter applies to. If you omit this, your filtering bar just shows a spinning wheel because of the incomplete definition.
Optional
List settings
The listSettings section enables you to customize the list view of the unified analysis page. You can change the selection and order of columns, how the list is sorted, and the number of rows to display.
listSettings:
staticContent:
header:
title: My hosts
description: My hosts list
icon: host
layout:
autoGenerate: false
cards:
- type: CHART_GROUP
key: chart
key: entitiesList
- type: INJECTIONS
staticContent Required
Enable or disable static elements like problems, properties, tags, global filter, and the Add tag option.
showProblems
boolean
If true, the list page shows the problem card.
Optional
showProperties
boolean
If true, the list page shows the properties card.
Optional
showTags
boolean
If true, the list page shows the entity tags.
Optional
showGlobalFilter
boolean
If true, the list page shows the filter bar.
Required
showAddTag
boolean
If true, the list page shows the Add tag option.
Optional
header
Object
The definition of the page header.
Optional
breadcrumbs
Array
A list of breadcrumbs leading to the page.
Optional
hideDefaultBreadcrumb
boolean
If true, the default breadcrumb for the current page is hidden.
Optional
layout Required
autoGenerate
boolean
Required
cards
enum
Possible values for type field: CHART_GROUP, ENTITIES_LIST, MESSAGE, INJECTIONS, BREAK_LINE.
Optional
List injections
The listInjections field defines injections for the entity list page. Injections must be supported by the page—the layout needs to include an injected cards placeholder.
listInjections:
- type: CHART_GROUP
key: injectedList
width: HALF_SIZE
type
enum
Defines the type of card available to inject. Possible values: CHART_GROUP, ENTITIES_LIST, MESSAGE, METRIC_TABLE.
Required
key
String
Required
List filters
The listFilters field defines filters on the list page.
listFilters:
relationships:
entityFilters:
filters:
- type: entityName
entityTypes:
- HOST_GROUP
- AZURE_REGION
freeText: false
displayName: name
distinct: true
relationships
relationships:
relationships:
entityFilters
The list of entity filters. For generic entities, the only filter types with suggestions are entityName, tag, healthState, and ipAddress / dt.ip_addresses. Any custom attributes must be set to freeText: true with modifier: equals. There are no suggestions supported, so you must type the exact value to filter.
filters
Array
Required
type
String
Required
displayName
String
Required
freeText
boolean
Required
modifier
boolean
Optional
defaultSearch
boolean
Optional
distinct
boolean
Required
entityTypes
Array
Optional
Properties card
The propertiesCard field displays the entity properties that are shown on the card as key-value pairs. By default, all available attribute properties are displayed.
propertiesCard:
properties:
- type: RELATION
relation:
entitySelectorTemplate: NOT VALIDATED IN SCHEMA
displayName: default
- type: ATTRIBUTE
attribute:
key: attribute
displayName: Attribute
properties Required
Use this configuration to specify the properties card.
type
enum
Defines the type of property. Possible values: RELATION, ATTRIBUTE.
Optional
RELATION
Enables you to specify the relation to the specific entity.
String
An entity selector that is used to retrieve the selected entities.
Details
Required
displayName
String
The name of the relation.
Required
fallbackMessage
String
Displays additional message if no entity is found. By default, the whole property is hidden.
Optional
ATTRIBUTE
Enables you to overwrite attribute display options.
key
String
Used to reference the desired attribute.
Required
displayName
String
The name of the attribute.
Optional
Chart group cards
The chart group cards enable you to visualize the specified metrics in dedicated charts.
  • The metricSelector expression specifies the metrics your chart is based on. For more information, see Metrics API - Metric selector. The examples below use simple metric selector expressions referring directly to the metric keys.
chartsCards:
- key: chartGroup
conditions:
- NOT VALIDATED IN SCHEMA
numberOfVisibleCharts: 2
charts:
- displayName: Chart
conditions:
visualizationType: GRAPH_CHART
graphChartConfig:
visualization:
themeColor: DEFAULT
seriesType: LINE
metrics:
- metricSelector: NOT VALIDATED IN SCHEMA
- metricSelector: builtin:host.cpu.usage:avg
visualization:
themeColor: DEFAULT
seriesType: LINE
- displayName: Chart2
visualizationType: PIE_CHART
pieChartConfig:
metric:
defaultAggregation: AVG
showLegend: true
themeColor: ORANGE
- displayName: Chart3
visualizationType: SINGLE_VALUE
singleValueConfig:
metric:
displayName: Single value
defaultAggregation: COUNT
showSparkline: true
showTrend: true
key
String
Required
conditions
Array
Defines the conditions that need to be fulfilled for the chart group card to be visible.
Optional
Integer
The number of charts that are visible on the unified analysis page.
Required
mode
enum
Defines the chart group behavior and interactivity. Possile values: NORMAL, STATIC.1
Required
1
NORMAL mode enables you to interact with the charts (view different data points or zoom in/out). Charts with STATIC mode are presented in a fixed, restricted manner.
charts
displayName
String
The title of the card.
Required
conditions
Array
Optional
visualizationType
The visualizationType defines the type for your chart: a graph chart GRAPH_CHART, a pie chart PIE_CHART, or a single value SINGLE_VALUE. If you don't specify the visualization type, the graph chart is rendered by default.
GRAPH_CHART
visualization
enum
Enables you to define a theme color, and series type (COLUMN, LINE or AREA). You can also enable showing the axis legend by setting the showLegend flag to true.
Required
metrics
Array
Defines how to retrieve data for a single line in the chart.
Required
thresholds
Array
Defines thresholds after which the background of the chart will change the color to the selected one.
Optional
metricSelector
A metric selector expression for a dedicated metric line.
visualization
enum
Optional
PIE_CHART
metric
Object
Defines how to retrieve data for the pie chart.
Required
defaultAggregation
enum
Defines default aggregation of the chart timeseries. If not defined or selected one is not supported, it is deduced from metrics metadata.
Optional
SINGLE_VALUE
metric
Object
Defines how to retrieve data for the single chart.
Required
displayName
String
Defines the name of the value.
Optional
defaultAggregation
enum
Optional
showSparkline
boolean
If true, the sparkline is visible.
Optional
showTrend
boolean
If true, the trend is visible.
Optional
thresholds
Array
Optional
foldTransformation
enum
Defines transformation method, which folds data into single value. Possible values: AUTO, LAST_VALUE, MAX, MIN, SUM, MEDIAN, VALUE, PERCENTILE_10, PERCENTILE_75, PERCENTILE_90.
Optional
List of available conditions
ConditionName|param1key=param1value|param2key=param2value
ConditionParametersMinimum schema versionDescription
demo
Not applicable
224
Used to demonstrate the conditions feature.
isSaaS
Not applicable
233
Indicates if the server deployment type is SaaS.
featureFlag
Feature flag key
233
Validates the status of a specific feature flag.
entityAttribute
Dynamic parameters1
231
Checks if the page's monitored entity possesses certain attributes with specified values or if they exist with any value.
relatedEntity
230
Validates the existence of a specified related entity in the environment.
extensionConfigured
extensionId, aboveOrEqualVersion, belowOrEqualVersion, featureSets, activatedOnHost2
243
Validates the presence of a specified extension in the environment, considering other parameters.
uiPermission
Specified UI permision
243
Confirms if you possess a specified permission (for example, CONFIG_WRITE).
isActive
Not applicable
246
Determines if the page's monitored entity is active.
serviceType
Type of the service
246
Confirms the type of the service. The scope limited to METype.SERVICE details pages.
typeExists
Type of the service
248
Checks if a specified METype service is present in the environment.
platform
Not applicable
254
Checks 3rd generation compatibility.
metricAvailable
metric3, lastWrittenWithinDays4
256
Verifies if a given metric key has associated metadata and the last time it was updated.
1
When parameters are provided with a specific value, they are formatted as key=value. The system will verify the exact match of this key-value pair. If only the key is provided without any accompanying value, the system will simply check if that key is present using the .exists() method.
2
The extension is configured to operate on the current host.
3
Metric key
4
The specified number of days within which the system checks the most recent updates.
Entities list cards
The entities list card displays other entities that are related to the focused entity. The YAML file below lists all Synology disks mapped to an instance of DiskStation Manager on which the details page focuses.
  • The entitySelectorTemplate expression specifies the entities to list on the card. For more information, see Environment API v2 - Entity selector.
  • The expression type(syn:disk),fromRelationships.runsOn($(entityConditions)) lists the entities of type syn:disk that have a relationship of from direction and runsOn type to the syn:diskmanager represented via the $(entityConditions) placeholder that stands for a focused entity.
entitiesListCards:
- key: disks
displayName: Synology disks
pageSize: 10
displayCharts: false
entitySelectorTemplate: "type(syn:disk),fromRelationships.runsOn($(entityConditions))"
displayIcons: true
enableDetailsExpandability: true
columns:
- type: ATTRIBUTE
attribute:
key: some_attribute
displayName: Some attribute
- type: RELATION
relation:
entitySelectorTemplate: type("syn:partition"),fromRelationship.isChildOf($(entityConditions))
displayName: Partitions
displayAmount: false
fallbackMessage: "no partition"
filtering:
relationships:
- type(syn:partition), fromRelationship.isChildOf($(entityConditions))
entityFilters:
filters:
- type: entityName
displayName: name
freeText: true
modifier: contains
defaultSearch: true
distinct: false
entityTypes:
- my:interface
- type: entityName
displayName: Partition name
freeText: true
modifier: contains
defaultSearch: false
distinct: false
entityTypes:
- syn:partition
key
String
Required
displayName
String
The card title.
Optional
pageSize
Integer
The number of rows visible on a single page.
Required
displayCharts
boolean
If true, charts with aggregated data appears above table.
Required
String
The entity selector is used to find entities that are to be displayed on the list.
Details
Optional
displayIcons
boolean
If true, the name column displays the icon of the entity.
Required
boolean
If true, rows can be expanded with charts related to that row dimension values.
Required
Integer
Required
displayProblemImpactWidget
boolean
If true, a widget indicating that some entities are not healthy will be displayed above the list. Make sure there is visible filtering with the health state filter.
Optional
columns
Object
Additional attribute or relation columns.
Optional
filtering
Object
The filtering inside the entity list card. It affects only that card's table and chart group.
Optional
columns
Additional columns that are displayed between Name and chart columns. There are 2 types available: ATTRIBUTE and RELATION.
RELATION
Enables you to specify the relation to the entity (1:1 relation) or list of entities (1:n relation).
String
Details
Required
displayName
String
The name of the column.
Required
displayAmount
String
If false, entities are displayed as a list (up to 20 entities). If true, the number of related entities is displayed as a link to the list page. The linked list is prefiltered only if it has configured listFilters with appropriate relationship and entityName filter (freeText: true and modifier: contains).
Required
fallbackMessage
String
Optional
ATTRIBUTE
Enables you to specify custom attribute column.
key
String
Required
displayName
String
Required
Events cards
The events cards display the events related to specified entities.
eventsCards:
- key: events
displayName: Events
entitySelectorTemplates:
- "$(entityConditions)",
- "type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions))",
- "type(PROCESS_GROUP_INSTANCE),fromRelationships.isPgiOfCgi(type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions)))"
showFiltering: true
showPagination: true
pageSize: 10
key
String
Required
displayName
String
The card title. If not set, card are named Events.
Optional
Array
The list of entity selector templates. It defines where the events are gathered from. If empty, the events are gathered for current entity.
Optional
showFiltering
boolean
If true, the filtering bar displays above events chart.
Required
showPagination
boolean
If true, the Show more action is available under events list.
Required
pageSize
Integer
The number of rows visible at card load.
Required
description
String
The description of the card.
Optional
eventSelectorTemplate
String
An event selector that is used to fetch events for related entities.
Optional
displayChart
boolean
Show or hide the chart in the card.
Optional
Logs cards
The logsCards field specifies the behavior of the logs card and has the same functionality as Log viewer. It consists of a bar chart representing different log occurrences during selected timeframe and detailed table where each log is an entry with additional properties like: timestamp, status, content.
logsCards:
- key: logs
displayName: Logs
enablePaging: true
filterQuery: event.type!="k8s" AND ($(logEntityAttributeKey) inEntitySelector "$(entityConditions)" OR dt.entity.container_group_instance inEntitySelector "type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions))" OR dt.entity.process_group_instance inEntitySelector "type(PROCESS_GROUP_INSTANCE),fromRelationships.isPgiOfCgi(type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions)))")
showFiltering: true
pageSize: 10
key
String
Required
displayName
String
The card title.
Optional
enablePaging
boolean
If true, enables paging of the log results in the table.
Optional
filterQuery
String
The predefined filtering for the log table. It is possible to to use LQL syntax also to more complex cases that include entity selectors with unified analysis placeholders in format: expression {attribute} inEntitySelector "{entitySelector}" to display logs of related entities. For example, dt.entity.host inEntitySelector "type(PROCESS_GROUP_INSTANCE) AND fromRelationship.isProcessOf($(entityConditions))".
Optional
showFiltering
boolean
Controls the visibility of the filter bar.
Optional
pageSize
Integer
Optional
description
String
Optional
displayChart
boolean
Optional
Message cards
The messageCards field specifies the behavior of the message card, like visualization options, theme, or text.
messageCards:
- key: message-card
type: CARD
card:
text: internal text
theme: MAIN
displayName: Message Card
- key: message-card2
type: MESSAGE
message:
text: internal text
theme: INFO
key
String
Required
type
enum
Defines the type of your message card. The possible values are: CARD, MESSAGE.
Required
CARD
Displays the message in the card format with title, description and buttons.
text
String
Defines the description of the card.
Required
theme
enum
Defines the color theme of the card. The possible values are: WARNING, MAIN, CTA.
Required
displayName
String
Defines the title of the card.
Optional
MESSAGE
Displays the message in the card format with description only.
text
String
Required
theme
enum
Defines the color theme of the message. The possible values are: INFO, WARNING, ERROR.
Required
Problems card
The problemsCard field specifies the behavior of the problems card.
problemsCard:
- NOT VALIDATED IN SCHEMA1
- NOT VALIDATED IN SCHEMA2
Array
Up to 10 entity selectors, used to fetch data for related entities.
Optional
Actions
The actions field defines actions that are available from the menu.
actions:
- actionScope: GLOBAL_DETAILS
actions:
- actionExpression: actionName|key1=value1
- actionScope: CHART_GROUP
key: chart
actionLocation: CHART
actions:
- actionScope: ENTITIES_LIST
key: entitiesList
actionLocation: TABLE_ENTRY
actions:
actionScope
enum
The defined action appears in the settings of the chosen card type. Possible values: GLOBAL_DETAILS, GLOBAL_LIST, PROPERTIES, PROBLEMS, CHART_GROUP, ENTITIES_LIST, EVENTS, LOGS, METRIC_TABLE.
Required
key
String
You can set the key if you want the action to be available only in one specific card. To add this actions in every card of this type, leave it empty.
Required
actionExpression
String
Defines the action expression.
Required
actionLocation
enum
Defines the location of your created action. Possible values: HEADER, CHART, TABLE_ENTRY.
Optional
List of available actions
ActionName|param1key=param1value|param2key=param2value
Generic actions
ActionParametersMinimum schema versionDescription
configuration
Not applicable
221
Creates a link to the entity configuration page. For example, host settings.
relatedEntityConfiguration
entitySelectorTemplate, name
234
Creates a link to the entity configuration page. For example, PGI settings from the host page.
settings
name, scopeClass1, scopeIdentifier2, schemaId3
236
Creates a link to the specified Settings 2.0 topic configuration UI.
hubCapability
text4, hubCapability5
243
Creates a link to the specified Dynatrace Hub capability.
hubExtension
text4, extensionId6
243
Creates a link to the specified Extension in Dynatrace Hub.
relatedEntityScreen
253
Creates a link to the related entity unified analysis page.
platform.intent
json7, label, appId, intentId
254
Platform intent action.
smartscape
Not applicable
255
Redirects to Smartscape.
1
Settings scope class
2
Settings scope identifier
3
Settings schema ID
4
Action display name
5
Hub capability URL part
6
Extension ID used as URL part
7
Entire intent JSON
Core actions
ActionParametersValid for conditionMinimum schema versionDescription
core.editConfig
Not applicable
UAScreenFeatureFlags.ENABLE_CONFIG_BUTTONS
218
Redirects to the entity's settings page and creates links for all its subtypes.
core.shareScreenUrl
Not applicable
Whole page scope
218
Provides a link for sharing feedback.
core.share.feedback
Not applicable
Whole page scope
218
Opens a feedback sharing form.
core.dataExplorer
Not applicable
Chart element type
223
Redirects charts to Data Explorer.
core.alerting
Not applicable
CONFIG_WRITE permissions, Chart element type
224
Redirects charts to set alerts on the selected metric.
core.pinToDashboard
Not applicable
Chart or Whole Services page scope with UAScreenFeatureFlags.ENABLE_PIN_TO_DASHBOARD
224
Pins charts or entire services to the dashboard.
core.problems
Not applicable
224
Navigates to the Problems section.
core.screenType
Not applicable
224
Creates multiple predefined screen type actions.
core.singleCard
Not applicable
UAScreenFeatureFlags.ENABLE_SINGLE_CARD_BUTTONS
232
Displays a single card view.
core.logs.createMetric
Not applicable
Log card element type
233
Redirects to log settings to create a log metric.
core.opt.out
Not applicable
Whole page scope
235
Navigates to the classic page view.
core.useLocalConfig
Not applicable
UAScreenFeatureFlags.ENABLE_USE_LOCAL_CONFIG_BUTTON
236
Activates the Local Config Mode.
core.sidebar
screenTypeExpression1
UAScreenFeatureFlags.ENABLE_SIDE_BAR_BUTTONS
244
Opens the sidebar.
core.problems.details
pid2
Details page
243
Navigates to specific problem details.
core.logs.filtered
Not applicable
246
Redirects log cards to the Log Viewer.
core.slos.create
Not applicable
CONFIG_WRITE permissions, Slo List element type
255
Redirects charts to create a Service Level Objective (SLO).
1
Page type expression to be rendered in the sidebar
2
Problem ID
Metric table cards
Metric table is a graphical representation of the metrics data related to the same dimension set.
metricTableCards:
- key: metricTable
pageSize: 5
displayCharts: true
filtering: {}
charts:
conditions:
graphChartConfig:
visualization:
themeColor: DEFAULT
seriesType: LINE
metrics:
- metricSelector: builtin:process.cpu:splitBy("process.pid","process.parent_pid","process.executable.name","process.executable.path","process.command_line","process.owner", "dt.entity.process_group_instance")
visualization:
themeColor: DEFAULT
seriesType: LINE
conditions:
key
String
Required
pageSize
Integer
Required
displayCharts
boolean
If true, charts with aggregated data appears above the table.
Required
boolean
Required
Integer
Number of visible charts.
Required
charts
Object
Define the charts to display timeseries data in the table. Table columns are based on the dimensions from the metrics results of those charts. Make sure the metrics of all charts have the same dimensions in a result.
Optional
conditions
Array
Conditions for displaying the chart.
Optional
filtering
Object
The filtering inside the metric table card. It affects only that cards table and chart group. It automatically displays metric dimension filters if there are any dimension splits. To display only metric dimension filters, define it as empty (detailsFilters: {}).
Optional
Health cards
Health cards provide a visual representation of specific metrics within the Dynatrace UI. Each card can be tailored to display up to six distinct tiles, each representing a unique metric or data point.
Health tile can be used as navigation button to specify element on the page that will give more details about that metric.
healthCards:
- key: health_card
tiles:
- displayName: Uptime
metricSelector: builtin:host.uptime
displayMetricValue: 'true'
foldTransformation: LAST_VALUE
- displayName: CPU
anchor:
cardName: Host performance
chartName: CPU usage
- displayName: Available memory
metricSelector: builtin:host.mem.avail.pct
anchor:
chartName: Memory usage
- displayName: Network
metricSelector: (builtin:host.net.nic.trafficIn:merge("dt.entity.network_interface"):avg)+(builtin:host.net.nic.trafficOut:merge("dt.entity.network_interface"):avg)
additionalMetricSelectors:
collection:
- builtin:host.net.nic.trafficIn:merge("dt.entity.network_interface")
- builtin:host.net.nic.trafficOut:merge("dt.entity.network_interface")
anchor:
chartName: Traffic
key
String
Unique key, which is used to map to this health card in the page layout config.
Required
tiles
Array
Collection of tile definitions in the health card. Each tile can display a specific metric. A health card can have up to 6 tiles.
Optional
tiles
displayName
String
The name of the health card tile.
Required
metricSelector
String
Used to relate problems and specify the metric displayed on the tile.
Required
Array
Used to relate problems. Hidden in the UI.
Optional
displayMetricValue
boolean
Determines whether the metric value should be displayed on the tile.
Optional
foldTransformation
Enum
Required
anchor
Object
Defines an element to redirect to when the tile is selected. This can be a specific card or chart name.
Optional
Related tags
Infrastructure Observability
