Db2 Monitoring on z/OS
  • Latest Dynatrace
  • 2-min read
OneAgent supports Db2 monitoring on z/OS by collecting Db2 metrics.
This feature is planned to be released in iterations. The first iteration of Db2 monitoring collects and reports the following metrics:
  • Db2 CPU % usage
  • MSTR CPU % usage
  • DBM1 CPU % usage
  • Active connections
  • Active outbound connections
  • Active inbound connections
  • Failed connections
  • EDM pool requests
  • Cache Hits
  • Db2 zIIP Time
In the second iteration, the following Db2 metrics are reported:
  • Deadlock count
  • Deadlock Timeout count
  • Latch suspension time
  • Number of SELECTS
  • Number of INSERTS
  • Number of UPDATES
  • Number of DELETES
  • Number of FETCHES
  • Number of OPENS
  • Number of CLOSES
For metrics descriptions, see the Db2 metrics section below.
Enable Db2 Monitoring on z/OS
Db2 monitoring can be enabled via OneAgent features.
  1. Go to Settings > Preferences > OneAgent features.
  2. Find z/OS DB2 Metrics Collection [Opt-In], which is off by default, and turn it on.
No restart of zDC or zRemote is required following a change to this setting.
Db2 metrics collection
The Db2 metrics are collected from SMF type 100 and 101 records. zDC uses SMF U86 exit to collect the metrics from the SMF records and ingests the metrics at one-minute intervals.
Start the Statistics and Accounting traces with the following classes for Db2 to write the SMF 100 and 101 records. Statistics - Class 1 Accounting - Class 1
The CPU metrics are collected from SMF 100 IFCID 1, z/OS System Statistics Data section. The Db2 Subsystem parameter, ZOSMETRICS must be set to YES to get valid CPU metric results.
No permissions are required, as Db2 is not queried directly.
Db2 metric keys
Monitor the metrics using DQL in Grail, use the following Grail key for the respective metrics.
Db2 MetricGrail key
Db2 Address spaces CPU Usage %
dt.process.zos.db2.cpu_usage
MSTR CPU Usage %
dt.process.zos.db2.cpu_usage_mstr
DBM1 CPU Usage %
dt.process.zos.db2.cpu_usage_dbm1
Active connections
dt.process.zos.db2.num_active_connections
dt.process.zos.db2.num_active_outbound_connections
dt.process.zos.db2.num_active_inbound_connections
Failed connections
dt.process.zos.db2.num_failed_connections
EDM pool requests
dt.process.zos.db2.num_edm_pool_requests
Cache hits
dt.process.zos.db2.num_cache_hits
zIIP time
dt.process.zos.db2.ziip_time
Deadlock count
dt.process.zos.db2.num_deadlocks
Deadlock timeout count
dt.process.zos.db2.num_timedout_deadlocks
dt.process.zos.db2.latch_suspension_time
Number of SELECTS
dt.process.zos.db2.num_selects
Number of INSERTS
dt.process.zos.db2.num_inserts
Number of UPDATES
dt.process.zos.db2.num_updates
Number of DELETES
dt.process.zos.db2.num_deletes
Number of FETCHES
dt.process.zos.db2.num_fetches
Number of OPENS
dt.process.zos.db2.num_opens
Number of CLOSES
dt.process.zos.db2.num_closes
Db2 metrics
Db2 CPU usage %
The percentage of the CPU processor used by all Db2 address spaces of a Db2 subsystem. This metric is collected from SMF 100 record (z/OS System Statistics section) and shows the value from the SMF record collected at the minute boundary. ZOSMETRIC parameter must be set to YES to collect this metric.
MSTR CPU usage %
The percentage of the CPU processor used by the MSTR address space of a Db2 subsystem. This metric is collected from SMF 100 record (z/OS System Statistics section) and shows the value from the SMF record collected at the minute boundary. ZOSMETRIC parameter must be set to YES to collect this metric.
DBM1 CPU usage %
The percentage of the CPU processor used by the DBM1 address space of a Db2 subsystem. This metric is collected from SMF 100 record (z/OS System Statistics section) and shows the value from the SMF record collected at the minute boundary. ZOSMETRIC parameter must be set to YES to collect this metric.
Active connections
This metric shows the total number of inbound and outbound connections handled by the Db2 subsystem in the one minute interval.
This metric shows the total number of outbound connections made by the Db2 subsystem to remote server in the one minute interval.
This metric shows the total number of inbound connections received by the Db2 subsystem initiated by the remote server in the one minute interval.
Failed connections
This metric shows the total number of connections from the remote server that were terminated in the one minute interval because CONDBAT was exceeded.
EDM pool requests
Total number of EDM pool requests made for cursor table sections, database descriptors, package table sections and dynamic statement cache. This metric shows the total number of EDM pool requests collected at the one minute interval.
Cache Hits
Total number of inserts into and requests from the Dynamic Statement cache. This metric shows the total number of cache hits collected at the one minute interval.
Db2 zIIP Time
Accumulated Db2 CPU time consumed on the zIIP processor. This metric shows the aggregated zIIP time collected at the one minute interval. This metric is collected from SMF 101 record.
Deadlock count
This metric shows the number of times deadlocks were detected in the last one-minute interval.
This metric shows the number of times in the last on-minute interval a unit of work was suspended for a time that exceeded the timeout value.
Latch Suspension time
This metric shows the accumulated wait time due to latch contention in the last one-minute interval.
Number of SELECTS
This metric shows the number of SELECTS made in the last one-minute interval.
Number of INSERTS
This metric shows the number of INSERTS made in the last one-minute interval.
Number of UPDATES
This metric shows the number of UPDATES made in the last one-minute interval.
Number of DELETES
This metric shows the number of DELETES made in the last one-minute interval.
Number of FETCHES
This metric shows the number of FETCHES made in the last one-minute interval.
Number of OPENS
This metric shows the number of OPENS made in the last one-minute interval.
Number of CLOSES
This metric shows the number of CLOSES made in the last one-minute interval.
