Validate integration
  • Dynatrace Classic
  • 1-min read
  • Published Aug 13, 2025
You can verify a successful Dynatrace integration with AWS Lambda through the following indicators:
  • Function invocations produce traces in the Distributed Tracing Distributed Tracing.
  • Function invocations generate logs in the Logs Logs.
  • AWS Lambda functions appear in the Services Services.
If any issues arise with the Dynatrace AWS Lambda layers, start by examining the logs and error messages for troubleshooting insights.
Troubleshoot issues with trace collection
Activate Forward Tag 4 trace context extension
This feature is necessary for maintaining trace continuity when using the Dynatrace AWS Lambda extension, as it allows the Dynatrace OneAgent to inject its trace context into outgoing requests. Without this feature, traces initiated by Dynatrace may break, as the trace context would not be forwarded properly.
To activate the Forward Tag 4 trace context extension feature, go to Settings > Preferences > OneAgent features.
Logs
You can check for specific log entries to verify that the AWS Lambda integration is successful.
  • Enable general log output:
    DT_LOGLEVELCON: info
  • Enable HTTP exporter logs:
    DT_DEBUGFLAGS: debugHttpNative=true
  • Check for a log line like:
    [native] [cURL/bc09328b] < HTTP/1.1 202 Accepted
Response codes
Response codeDescriptionHow to troubleshoot
202 AcceptedThe expected response of an ActiveGate, indicates successful exportNo action needed; export was successful
200 OKThe response came from an endpoint that is not an ActiveGate, likely no traces are visibleReview the DT_CONNECTION_BASE_URL
404 Not FoundEndpoint not found, likely no traces are visibleReview DT_CONNECTION_BASE_URL
401 UnauthorizedToken rejected, likely no traces are visibleReview DT_TENANT, DT_CONNECTION_AUTH_TOKEN, DT_CONNECTION_BASE_URL
Troubleshoot issues with log collection
If other troubleshooting methods don't resolve your issue, you can enable debug logging of the log collector.
Enabling debug logging should only be used temporarily, as it will generate a large amount of logs in CloudWatch, which may impact the function's performance.
In your Lambda function's configuration, set the following values:
  • If you are using environment variables:
    Environment variableValue
    DT_LOG_COLLECTION_LOG_LEVELdebug
    DT_LOGGING_DESTINATIONstdout
  • If you are using dtconfig.json configuration, you can enable debug logging by setting the LogCollection.LogLevel and Logging.Destination properties:
    ...other values...
    "Logging": {
    "Destination": "stdout"
    "LogCollection": {
    ...other values...
    "LogLevel": "debug"
The log collector will then print debug logs to the Lambda function's log stream. You can view these logs in the CloudWatch console. Note that the collector will not send its own logs to Dynatrace.
Related tags
Infrastructure ObservabilityAWS
