AWS Lambda functions monitored with classic OneAgent layers should be updated to the latest generation monitoring layer to take full advantage of Dynatrace’s enhanced observability capabilities.
To migrate AWS Lambda functions currently monitored with classic OneAgent layers
DT or the dtconfig.json file).Alternatively, you can reuse the configuration created for the classic AWS Lambda layer with the following adaptations that make the latest generation of Dynatrace AWS Lambda monitoring backward-compatible.
DT_CLUSTER_ID to DT_CLUSTER.disabled by doing one of the following:
DT_OPEN_TELEMETRY_ENABLE_INTEGRATIONOpenTelemetry.EnableIntegration from the dtconfig.json file.Once these adaptations are complete, remove the classic layer and add the latest generation layer. Ensure that the selected layer matches the correct architecture and be aware of differences in system requirements and available features.
The latest generation layers are located in a different Dynatrace AWS account than the classic layers. That's why the account number part of the layer ARN changes from 725887861453 to 585768157899.
The tables below compare key features and performance metrics between the classic and latest AWS Lambda implementations.
The table below compares features for Java layers tested in hello-world Lambda functions (only returning a response) with 512 MB of allocated memory.
| Feature | AWS Lambda (classic) | AWS Lambda (latest) |
Supported sensors | Few built-in | Many built-in |
Cold start invocation overhead (typical) | < 4,000 ms | < 1,500 ms1 |
Warm start invocation overhead (typical) | 70–80 ms | 60 ms |
Response time overhead (typical) | 20 ms | < 5 ms |
Log enrichment | Manual | Automatic for supported frameworks, structured logs |
Layer size for traces-only layer | < 10 MB | > 15 MB, depending on OneAgent |
Token stored in Secret Manager | Supported for non-SnapStart | Supported |
OpenTelemetry integration | Supported | Supported |
Code base | Based on OpenTelemetry SDK | OneAgent |
For .NET runtimes, cold start invocation overhead is ~5,000 ms.
Requires OneAgent version 1.329+.
Requires OneAgent version 1.341+.
Minimum memory | 1,500 MB | 128 MB |
Handler function definition | In class | In class or base class |
SnapStart | Supported | Supported |
Module type | CommonJS | CommonJS, ESM (opt-in)4 |
ESM support is experimental. To enable it, set the DT_ENABLE_ESM_LOADERS environment variable to true. Note that aws-sdk tracing support is available for CommonJS only. Enabling ESM support increases memory consumption.
