Monitor AWS Lambda
  • Dynatrace Classic
  • How-to guide
  • 1-min read
  • Published Mar 06, 2024
For information about differences between classic services and other services, see Migrate from AWS classic (formerly 'built-in') services to cloud services.
Dynatrace ingests metrics for multiple preselected namespaces, including AWS Lambda. You can view metrics for each service instance, split metrics into multiple dimensions, and create custom charts that you can pin to your dashboards.
Prerequisites
To enable monitoring for this service, you need
  • ActiveGate version 1.197+
  • For Dynatrace SaaS deployments, you need an Environment ActiveGate or a Multi-environment ActiveGate.
    For role-based access in SaaS deployment, you need an Environment ActiveGate installed on an Amazon EC2 host.
  • Dynatrace version 1.200+
  • An updated AWS monitoring policy to include the additional AWS services.
To update the AWS IAM policy, use the JSON below, containing the monitoring policy (permissions) for all supporting services.
JSON predefined policy for all supporting services
"Version": "2012-10-17",
"Statement": [
"Sid": "VisualEditor0",
"Effect": "Allow",
"Action": [
"acm-pca:ListCertificateAuthorities",
"apigateway:GET",
"apprunner:ListServices",
"appstream:DescribeFleets",
"appsync:ListGraphqlApis",
"athena:ListWorkGroups",
"autoscaling:DescribeAutoScalingGroups",
"cloudformation:ListStackResources",
"cloudfront:ListDistributions",
"cloudhsm:DescribeClusters",
"cloudsearch:DescribeDomains",
"cloudwatch:GetMetricData",
"cloudwatch:GetMetricStatistics",
"cloudwatch:ListMetrics",
"codebuild:ListProjects",
"datasync:ListTasks",
"dax:DescribeClusters",
"directconnect:DescribeConnections",
"dms:DescribeReplicationInstances",
"dynamodb:ListTables",
"dynamodb:ListTagsOfResource",
"ec2:DescribeAvailabilityZones",
"ec2:DescribeInstances",
"ec2:DescribeNatGateways",
"ec2:DescribeSpotFleetRequests",
"ec2:DescribeTransitGateways",
"ec2:DescribeVolumes",
"ec2:DescribeVpnConnections",
"ecs:ListClusters",
"eks:ListClusters",
"elasticache:DescribeCacheClusters",
"elasticbeanstalk:DescribeEnvironmentResources",
"elasticbeanstalk:DescribeEnvironments",
"elasticfilesystem:DescribeFileSystems",
"elasticloadbalancing:DescribeInstanceHealth",
"elasticloadbalancing:DescribeListeners",
"elasticloadbalancing:DescribeLoadBalancers",
"elasticloadbalancing:DescribeRules",
"elasticloadbalancing:DescribeTags",
"elasticloadbalancing:DescribeTargetHealth",
"elasticmapreduce:ListClusters",
"elastictranscoder:ListPipelines",
"es:ListDomainNames",
"events:ListEventBuses",
"firehose:ListDeliveryStreams",
"fsx:DescribeFileSystems",
"gamelift:ListFleets",
"glue:GetJobs",
"inspector:ListAssessmentTemplates",
"kafka:ListClusters",
"kinesis:ListStreams",
"kinesisanalytics:ListApplications",
"kinesisvideo:ListStreams",
"lambda:ListFunctions",
"lambda:ListTags",
"lex:GetBots",
"logs:DescribeLogGroups",
"mediaconnect:ListFlows",
"mediaconvert:DescribeEndpoints",
"mediapackage-vod:ListPackagingConfigurations",
"mediapackage:ListChannels",
"mediatailor:ListPlaybackConfigurations",
"opsworks:DescribeStacks",
"qldb:ListLedgers",
"rds:DescribeDBClusters",
"rds:DescribeDBInstances",
"rds:DescribeEvents",
"rds:ListTagsForResource",
"redshift:DescribeClusters",
"robomaker:ListSimulationJobs",
"route53:ListHostedZones",
"route53resolver:ListResolverEndpoints",
"s3:ListAllMyBuckets",
"sagemaker:ListEndpoints",
"sns:ListTopics",
"sqs:ListQueues",
"storagegateway:ListGateways",
"sts:GetCallerIdentity",
"swf:ListDomains",
"tag:GetResources",
"tag:GetTagKeys",
"transfer:ListServers",
"workmail:ListOrganizations",
"workspaces:DescribeWorkspaces"
"Resource": "*"
If you don't want to add permissions to all services, and just select permissions for certain services, consult the table below. The table contains a set of permissions that are required for All AWS cloud services and, for each supporting service, a list of optional permissions specific to that service.
Permissions required for AWS monitoring integration:
  • "cloudwatch:GetMetricData"
  • "cloudwatch:GetMetricStatistics"
  • "cloudwatch:ListMetrics"
  • "sts:GetCallerIdentity"
  • "tag:GetResources"
  • "tag:GetTagKeys"
  • "ec2:DescribeAvailabilityZones"
Complete list of permissions for cloud services
NamePermissions
All monitored Amazon services Required
cloudwatch:GetMetricData,cloudwatch:GetMetricStatistics,cloudwatch:ListMetrics,sts:GetCallerIdentity,tag:GetResources,tag:GetTagKeys,ec2:DescribeAvailabilityZones
AWS Certificate Manager Private Certificate Authority
Amazon MQ
Amazon API Gateway
apigateway:GET
AWS App Runner
Amazon AppStream
AWS AppSync
Amazon Athena
Amazon Aurora
Amazon EC2 Auto Scaling
Amazon EC2 Auto Scaling (built-in)
AWS Billing
Amazon Keyspaces
AWS Chatbot
Amazon CloudFront
AWS CloudHSM
Amazon CloudSearch
AWS CodeBuild
Amazon Cognito
Amazon Connect
Amazon Elastic Kubernetes Service (EKS)
eks:ListClusters
AWS DataSync
datasync:ListTasks
Amazon DynamoDB Accelerator (DAX)
AWS Database Migration Service (AWS DMS)
Amazon DocumentDB
AWS Direct Connect
Amazon DynamoDB
dynamodb:ListTables
Amazon DynamoDB (built-in)
dynamodb:ListTables,dynamodb:ListTagsOfResource
Amazon EBS
ec2:DescribeVolumes
Amazon EBS (built-in)
ec2:DescribeVolumes
Amazon EC2 API
Amazon EC2 (built-in)
Amazon EC2 Spot Fleet
Amazon Elastic Container Service (ECS)
ecs:ListClusters
Amazon ECS Container Insights
ecs:ListClusters
Amazon ElastiCache (EC)
AWS Elastic Beanstalk
Amazon Elastic File System (EFS)
Amazon Elastic Inference
Amazon Elastic Map Reduce (EMR)
Amazon Elasticsearch Service (ES)
es:ListDomainNames
Amazon Elastic Transcoder
Amazon Elastic Load Balancer (ELB) (built-in)
elasticloadbalancing:DescribeInstanceHealth,elasticloadbalancing:DescribeListeners,elasticloadbalancing:DescribeLoadBalancers,elasticloadbalancing:DescribeRules,elasticloadbalancing:DescribeTags,elasticloadbalancing:DescribeTargetHealth
Amazon EventBridge
Amazon FSx
Amazon GameLift
gamelift:ListFleets
AWS Glue
glue:GetJobs
Amazon Inspector
AWS Internet of Things (IoT)
AWS IoT Analytics
Amazon Managed Streaming for Kafka
kafka:ListClusters
Amazon Kinesis Data Analytics
Amazon Data Firehose
Amazon Kinesis Data Streams
kinesis:ListStreams
Amazon Kinesis Video Streams
AWS Lambda
AWS Lambda (built-in)
lambda:ListFunctions,lambda:ListTags
Amazon Lex
lex:GetBots
Amazon Application and Network Load Balancer (built-in)
Amazon CloudWatch Logs
AWS Elemental MediaConnect
AWS Elemental MediaConvert
AWS Elemental MediaPackage Live
AWS Elemental MediaPackage Video on Demand
AWS Elemental MediaTailor
Amazon VPC NAT Gateways
Amazon Neptune
AWS OpsWorks
Amazon Polly
Amazon QLDB
qldb:ListLedgers
Amazon RDS
Amazon RDS (built-in)
rds:DescribeDBInstances,rds:DescribeEvents,rds:ListTagsForResource
Amazon Redshift
Amazon Rekognition
AWS RoboMaker
Amazon Route 53
Amazon Route 53 Resolver
Amazon S3
s3:ListAllMyBuckets
Amazon S3 (built-in)
s3:ListAllMyBuckets
Amazon SageMaker Batch Transform Jobs
Amazon SageMaker Endpoint Instances
Amazon SageMaker Endpoints
Amazon SageMaker Ground Truth
Amazon SageMaker Processing Jobs
Amazon SageMaker Training Jobs
AWS Service Catalog
Amazon Simple Email Service (SES)
Amazon Simple Notification Service (SNS)
sns:ListTopics
Amazon Simple Queue Service (SQS)
sqs:ListQueues
AWS Systems Manager - Run Command
AWS Step Functions
AWS Storage Gateway
Amazon SWF
swf:ListDomains
Amazon Textract
AWS IoT Things Graph
AWS Transfer Family
AWS Transit Gateway
Amazon Translate
AWS Trusted Advisor
AWS API Usage
AWS Site-to-Site VPN
AWS WAF Classic
AWS WAF
Amazon WorkMail
Amazon WorkSpaces
Example of JSON policy for one single service.
JSON policy for Amazon API Gateway
"Statement": [
"Effect": "Allow",
"Action": [
"apigateway:GET",
"tag:GetResources",
"tag:GetTagKeys",
"Resource": "*"
In this example, from the complete list of permissions you need to select
  • "apigateway:GET" for Amazon API Gateway
  • "cloudwatch:GetMetricData", "cloudwatch:GetMetricStatistics", "cloudwatch:ListMetrics", "sts:GetCallerIdentity", "tag:GetResources", "tag:GetTagKeys", and "ec2:DescribeAvailabilityZones" for All AWS cloud services.
AWS endpoints that need to be reachable from ActiveGate with corresponding AWS services
EndpointService
autoscaling.<REGION>.amazonaws.com
Amazon EC2 Auto Scaling (built-in), Amazon EC2 Auto Scaling
lambda.<REGION>.amazonaws.com
AWS Lambda (built-in), AWS Lambda
elasticloadbalancing.<REGION>.amazonaws.com
Amazon Application and Network Load Balancer (built-in), Amazon Elastic Load Balancer (ELB) (built-in)
dynamodb.<REGION>.amazonaws.com
Amazon DynamoDB (built-in), Amazon DynamoDB
ec2.<REGION>.amazonaws.com
Amazon EBS (built-in), Amazon EC2 (built-in), Amazon EBS, Amazon EC2 Spot Fleet, Amazon VPC NAT Gateways, AWS Transit Gateway, AWS Site-to-Site VPN
rds.<REGION>.amazonaws.com
Amazon RDS (built-in), Amazon Aurora, Amazon DocumentDB, Amazon Neptune, Amazon RDS
s3.<REGION>.amazonaws.com
acm-pca.<REGION>.amazonaws.com
apigateway.<REGION>.amazonaws.com
Amazon API Gateway
apprunner.<REGION>.amazonaws.com
AWS App Runner
appstream2.<REGION>.amazonaws.com
Amazon AppStream
appsync.<REGION>.amazonaws.com
AWS AppSync
athena.<REGION>.amazonaws.com
Amazon Athena
cloudfront.amazonaws.com
Amazon CloudFront
cloudhsmv2.<REGION>.amazonaws.com
AWS CloudHSM
cloudsearch.<REGION>.amazonaws.com
Amazon CloudSearch
codebuild.<REGION>.amazonaws.com
AWS CodeBuild
datasync.<REGION>.amazonaws.com
AWS DataSync
dax.<REGION>.amazonaws.com
dms.<REGION>.amazonaws.com
directconnect.<REGION>.amazonaws.com
AWS Direct Connect
ecs.<REGION>.amazonaws.com
Amazon Elastic Container Service (ECS), Amazon ECS Container Insights
elasticfilesystem.<REGION>.amazonaws.com
eks.<REGION>.amazonaws.com
elasticache.<REGION>.amazonaws.com
elasticbeanstalk.<REGION>.amazonaws.com
elastictranscoder.<REGION>.amazonaws.com
es.<REGION>.amazonaws.com
events.<REGION>.amazonaws.com
Amazon EventBridge
fsx.<REGION>.amazonaws.com
Amazon FSx
gamelift.<REGION>.amazonaws.com
Amazon GameLift
glue.<REGION>.amazonaws.com
AWS Glue
inspector.<REGION>.amazonaws.com
Amazon Inspector
kafka.<REGION>.amazonaws.com
models.lex.<REGION>.amazonaws.com
Amazon Lex
logs.<REGION>.amazonaws.com
api.mediatailor.<REGION>.amazonaws.com
mediaconnect.<REGION>.amazonaws.com
mediapackage.<REGION>.amazonaws.com
mediapackage-vod.<REGION>.amazonaws.com
opsworks.<REGION>.amazonaws.com
AWS OpsWorks
qldb.<REGION>.amazonaws.com
Amazon QLDB
redshift.<REGION>.amazonaws.com
Amazon Redshift
robomaker.<REGION>.amazonaws.com
AWS RoboMaker
route53.amazonaws.com
Amazon Route 53
route53resolver.<REGION>.amazonaws.com
api.sagemaker.<REGION>.amazonaws.com
Amazon SageMaker Endpoints, Amazon SageMaker Endpoint Instances
sns.<REGION>.amazonaws.com
sqs.<REGION>.amazonaws.com
storagegateway.<REGION>.amazonaws.com
AWS Storage Gateway
swf.<REGION>.amazonaws.com
Amazon SWF
transfer.<REGION>.amazonaws.com
AWS Transfer Family
workmail.<REGION>.amazonaws.com
Amazon WorkMail
workspaces.<REGION>.amazonaws.com
Amazon WorkSpaces
Enable monitoring
To learn how to enable service monitoring, see Enable service monitoring.
View service metrics
You can view the service metrics in your Dynatrace environment either on the custom device overview page or on your Dashboards page.
View metrics on the custom device overview page
To access the custom device overview page
  1. Go to Technologies Technologies & Processes Classic.
  2. Filter by service name and select the relevant custom device group.
  3. Once you select the custom device group, you're on the custom device group overview page.
  4. The custom device group overview page lists all instances (custom devices) belonging to the group. Select an instance to view the custom device overview page.
View metrics on your dashboard
You can also view metrics in the Dynatrace web UI on dashboards. There is no preset dashboard available for this service, but you can create your own dashboard.
To check the availability of preset dashboards for each AWS service, see the list below.
Preset dashboard availability list
AWS servicePreset dashboard
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Amazon API Gateway
Not applicable
AWS App Runner
Not applicable
Amazon AppStream
Applicable
AWS AppSync
Applicable
Amazon Athena
Applicable
Amazon Aurora
Not applicable
Applicable
AWS Billing
Applicable
Amazon Keyspaces
Applicable
AWS Chatbot
Applicable
Amazon CloudFront
Not applicable
AWS CloudHSM
Applicable
Amazon CloudSearch
Applicable
AWS CodeBuild
Applicable
Amazon Cognito
Not applicable
Amazon Connect
Applicable
AWS DataSync
Applicable
Applicable
Applicable
Amazon DocumentDB
Applicable
AWS Direct Connect
Applicable
Amazon DynamoDB
Not applicable
Amazon EBS
Not applicable
Not applicable
Amazon EC2 API
Applicable
Not applicable
Applicable
Not applicable
Applicable
Not applicable
Applicable
Applicable
Applicable
Not applicable
Not applicable
Amazon EventBridge
Applicable
Amazon FSx
Applicable
Amazon GameLift
Applicable
AWS Glue
Not applicable
Amazon Inspector
Applicable
Not applicable
Applicable
AWS IoT Analytics
Applicable
Applicable
Not applicable
Not applicable
Not applicable
Not applicable
AWS Lambda
Not applicable
Amazon Lex
Applicable
Applicable
Applicable
Applicable
Applicable
Applicable
Applicable
Amazon MQ
Applicable
Not applicable
Amazon Neptune
Applicable
AWS OpsWorks
Applicable
Amazon Polly
Applicable
Amazon QLDB
Applicable
Amazon RDS
Not applicable
Amazon Redshift
Not applicable
Amazon Rekognition
Applicable
AWS RoboMaker
Applicable
Amazon Route 53
Applicable
Applicable
Amazon S3
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
AWS Service Catalog
Applicable
Not applicable
Not applicable
Not applicable
Applicable
AWS Step Functions
Applicable
AWS Storage Gateway
Applicable
Amazon SWF
Applicable
Amazon Textract
Applicable
AWS Transfer Family
Applicable
AWS Transit Gateway
Applicable
Amazon Translate
Applicable
AWS Trusted Advisor
Applicable
AWS API Usage
Applicable
Applicable
AWS WAF Classic
Applicable
AWS WAF
Applicable
Amazon WorkMail
Applicable
Amazon WorkSpaces
Applicable
Available metrics
This service monitors a part of AWS Lambda (AWS/Lambda). While you have this service configured, you can't have AWS Lambda (built-in) service turned on.
FunctionName is the main dimension.
NameDescriptionUnitStatisticsDimensionsRecommended
AsyncEventAge
The time between when Lambda successfully queues the event and when the function is invoked.
Milliseconds
Multi
FunctionName, Resource
AsyncEventAge
Milliseconds
Multi
FunctionName
AsyncEventAge
Milliseconds
Multi
Region
AsyncEventsDropped
The number of events that are dropped without successfully executing the function.
Count
Sum
AsyncEventsDropped
Count
Sum
FunctionName
AsyncEventsDropped
Count
Sum
Region
AsyncEventsReceived
The number of events that Lambda successfully queues for processing.
Count
Sum
AsyncEventsReceived
Count
Sum
FunctionName
AsyncEventsReceived
Count
Sum
Region
ConcurrentExecutions
The number of function instances that are processing events.
Count
Maximum
Count
Maximum
FunctionName
Count
Sum
Count
Sum
FunctionName
Applicable
Count
Sum
Region
Applicable
DeadLetterErrors
For asynchronous invocation, the number of times that Lambda attempts to send an event to a dead-letter queue (DLQ) but fails.
Count
Sum
DeadLetterErrors
Count
Sum
FunctionName
DeadLetterErrors
Count
Sum
Region
DestinationDeliveryFailures
For asynchronous invocation and supported event source mappings, the number of times that Lambda attempts to send an event to a destination but fails.
Count
Sum
Count
Sum
FunctionName
Count
Sum
Region
Duration
The amount of time that your function code spends processing an event.
Milliseconds
Multi
Duration
Milliseconds
Multi
FunctionName
Applicable
Duration
Milliseconds
Multi
Region
Applicable
Errors
The number of invocations that result in a function error.
Count
Sum
Errors
Count
Sum
FunctionName
Applicable
Errors
Count
Sum
Region
Applicable
Invocations
The number of times that your function code is invoked, including successful invocations and invocations that result in a function error.
Count
Sum
Invocations
Count
Sum
FunctionName
Applicable
Invocations
Count
Sum
Region
Applicable
IteratorAge
For DynamoDB, Kinesis, and Amazon DocumentDB event sources, the age of the last record in the event.
Milliseconds
Multi
IteratorAge
Milliseconds
Multi
FunctionName
IteratorAge
Milliseconds
Multi
Region
OffsetLag
For self-managed Apache Kafka and Amazon Managed Streaming for Apache Kafka (Amazon MSK) event sources, the difference in offset between the last record written to a topic and the last record that your function's consumer group processed.
Milliseconds
Multi
OffsetLag
Milliseconds
Multi
FunctionName
OffsetLag
Milliseconds
Multi
Region
PostRuntimeExtensionsDuration
The cumulative amount of time that the runtime spends running code for extensions after the function code has completed.
Milliseconds
Multi
Applicable
Milliseconds
Multi
FunctionName
Milliseconds
Multi
Region
Applicable
ProvisionedConcurrencyInvocations
The number of times that your function code is invoked using provisioned concurrency.
Count
Sum
Applicable
Count
Sum
FunctionName
Count
Sum
Region
Applicable
ProvisionedConcurrencySpilloverInvocations
The number of times that your function code is invoked using standard concurrency when all provisioned concurrency is in use.
Count
Sum
Count
Sum
FunctionName
Count
Sum
Region
ProvisionedConcurrencyUtilization
For a version or alias, the value of ProvisionedConcurrentExecutions divided by the total amount of provisioned concurrency allocated.
Count
Sum
Count
Sum
FunctionName
Count
Sum
Region
The number of function instances that are processing events using provisioned concurrency.
Count
Sum
Applicable
Count
Sum
FunctionName
Count
Sum
Count
Sum
FunctionName
Applicable
Count
Sum
Region
Applicable
RecursiveInvocationsDropped
The number of times that Lambda has stopped invocation of your function because it's detected that your function is part of an infinite recursive loop.
Count
Sum
Count
Sum
FunctionName
Count
Sum
Region
Throttles
The number of invocation requests that are throttled.
Count
Sum
Throttles
Count
Sum
FunctionName
Applicable
Throttles
Count
Sum
Region
Applicable
UnreservedConcurrentExecutions
For a Region, the number of events that functions without reserved concurrency are processing.
Count
Sum
Region
Related tags
Infrastructure ObservabilityAWS
