You can run your Dynatrace synthetic monitors from a private Synthetic location, which is a location in your private network infrastructure where you install one or more Synthetic-enabled ActiveGate instances.
With monitors executed from a private location, you can bring the testing capabilities available in public locations right into your own environment. With private locations you can:
Private Synthetic locations support all types of Dynatrace synthetic monitors.
Make sure the target host you plan to use for running synthetic monitors complies with system and hardware requirements for private Synthetic locations. Note that Synthetic-enabled ActiveGates have more demanding hardware and system requirements than a regular Environment or Cluster ActiveGate.
There are no new versions of Chromium for Red Hat/Oracle Linux/Rocky Linux 8 beyond version 133. For important security and stability reasons, we've decided to discontinue our support for installing Synthetic-enabled ActiveGate on Red Hat/Oracle Linux/Rocky Linux 8 after ActiveGate version 1.325. ActiveGate version 1.325 is the last Synthetic-enabled ActiveGate supported on Red Hat/Oracle Linux/Rocky Linux 8. Additionally, with Dynatrace version 1.326, we plan to introduce mechanisms preventing Synthetic-enabled ActiveGates on Red Hat/Oracle Linux/Rocky Linux 8 from being updated beyond version 1.325.
Until version 1.329 Synthetic-enabled ActiveGates on Ubuntu 20 and Ubuntu 22 use Chromium snap. When customizing the default temporary directory for private Synthetic files—/var/tmp/dynatrace/synthetic, the path must begin with /var/tmp, for example, TEMP=/var/tmp/syn. Dynatrace requires write access to /var/tmp for the installation of Chromium snap packages.
Since version 1.331, these restrictions no longer apply. The latest ActiveGate version on Ubuntu 20 and Ubuntu 22 uses Chrome for Testing, just like Ubuntu 24.
You cannot execute synthetic monitors using an Environment ActiveGate configured for multi-environment support.
You can create a private location using a clean-installed Synthetic-enabled Environment ActiveGate version 1.169+ or Cluster ActiveGate with Dynatrace Managed version 1.176+. If you want to use an existing ActiveGate host, uninstall ActiveGate first.
Synthetic-enabled ActiveGate is used exclusively to run synthetic monitors. A clean ActiveGate installation for the purpose of synthetic monitoring disables all other ActiveGate features, including communication with OneAgents.
Make sure that the ActiveGate can connect to other Dynatrace components as well as the resource you want to test. See Set up a proxy for private synthetic monitoring.
Only IPv4 and DNS UDP are supported for network configuration.
https://synthetic-packages.s3.amazonaws.com. For security reasons, public access to the S3 bucket is enabled only for specific files; trying anything else will result in a 403 error.The instructions below describe how to install an ActiveGate in the previous Dynatrace. To learn how to install an ActiveGate in the latest Dynatrace, see Private synthetic locations on Grail.
Synthetic-enabled ActiveGate is used exclusively to run synthetic monitors. A clean ActiveGate installation for the purpose of synthetic monitoring disables all other ActiveGate features, including communication with OneAgents. Make sure the host on which you install the ActiveGate has access to the internet.
If this web UI-guided installation fails, or you prefer to prepare the host for the Synthetic engine yourself, you can manually install the browser and other dependencies via S3. You can also install the browser from a custom, local repository.
For Environment ActiveGate, in Dynatrace Hub, select ActiveGate > Set up.
For Cluster ActiveGate, go to the Dynatrace Cluster Management Console and select More > Add new Cluster ActiveGate.
Select the operating system to view instructions.
Create a PaaS Token or enter an existing token. This token has the Download OneAgent and ActiveGate installers InstallerDownload token scope, which allows you to download the ActiveGate installer. Once provided, the token is automatically appended to download and installation commands, which are then displayed in the UI.
You can find existing tokens listed on the Access tokens page. Note that a PaaS token is only displayed once upon creation, after which it's stored encrypted and cannot be revealed. We recommend that you store a PaaS token after creation in a password manager so that you can reuse it as needed.
Linux only For Choose installer type, keep the default selection: x86/64.
For What's the purpose of this ActiveGate, select Run synthetic monitors from a private location.
Optional Assign the ActiveGate to a private Synthetic location—select a location from the dropdown list. You can also assign the ActiveGate to a location after installation.
Optional You can turn off support for browser monitors. If you do so, the Synthetic ActiveGate will be treated as browserless.
Optional Set customized options to assign the ActiveGate to a Network zone and ActiveGate group.
Download the installer to the target host.
Linux only Recommended Verify signature—run the displayed command on the target host to download a certificate file and verify the installer.
Linux only Select a Linux distribution.
Run the installer and any other commands—make sure you use the exact commands displayed in the UI.
Linux only The installer automatically downloads the browser and dependencies required by the Synthetic engine. On Red Hat, Oracle Linux, and Rocky Linux you also need to enable repositories from which the installer downloads the dependencies. As a prerequisite for enabling proprietary repositories on Red Hat, you need to register your Red Hat instance. The web UI provides you with all the required commands for doing so, as shown in the example below.
Verify the ActiveGate installation (Show deployment status).
Monitors on a private Synthetic location can reach every destination that the ActiveGate host can reach. This lets you monitor internal applications, but it also means that anyone who can create or edit monitors for the location can send requests to those same destinations.
The Synthetic engine partially blocks potentially harmful requests, such as those to cloud metadata APIs, for HTTP monitors. This protection doesn't apply to browser monitors due to how they handle network traffic. In either case, it's not a substitute for network controls.
Before you use the location in production, restrict network access for the ActiveGate host (for example, with firewall rules or egress filtering) so that it can reach only the destinations your monitors need.
Examples of destinations to consider:
169.254.169.254, which can expose credentials that grant access to your cloud resourceslocalhost and link-local addresses (169.254.0.0/16)To restrict network access of your private location, apply the following measures.
The instructions below describe how to add a private location in previous Dynatrace. To learn how to add a private location in the latest Dynatrace, see Private synthetic locations on Grail.
Search for and select Settings. Then select Web & mobile monitoring > Private synthetic locations.
Select Create location.
Give your location a custom Name, for example Boston office, 3rd floor.
Map it from an existing geographic location or add a custom geographic location defined by Country, Region, City, and Geographic coordinates.
Add a Synthetic-enabled ActiveGate to the location. Note that an ActiveGate can only be assigned to a single location.
You can also leave the location temporarily unassigned and assign it during the ActiveGate installation process.
Select Add.
Select Save.
Now, when you create your HTTP or browser monitor, select the location you've just created from the list of all available locations. For more information, see Create an HTTP monitor, Create a single-URL browser monitor, or Record a browser clickpath.
This section is not relevant for browserless locations.
Amazon Linux 2023, Ubuntu and Oracle Linux 9 use Chrome for Testing instead of Chromium. For manual installation of Chrome for Testing on these operating systems, see Amazon Linux 2023, Ubuntu and Oracle Linux 9 (Chrome for Testing).
If the web UI-guided installation fails or you prefer to prepare the host for the Synthetic engine yourself, you can install the browser and other dependencies using the procedure below. Ensure that you can connect to https://synthetic-packages.s3.amazonaws.com to access the browser and dependencies. For security reasons, public access to the S3 bucket is enabled only for specific files; trying anything else will result in a 403 error.
Also see Install the browser from a custom repository below.
See how to update the browser manually in Manage private Synthetic locations in Classic. We strongly recommend that you keep your Linux-based Synthetic-enabled ActiveGates and browser versions updated—Dynatrace supports browser versions that are no more than two versions behind the the latest Dynatrace-supported version for a specific ActiveGate release.
This section is only relevant for releases 1.329 and earlier.
Install Synthetic engine dependencies:
sudo apt-get update && sudo apt-get -y install xvfb x11-xkb-utils xfonts-100dpi xfonts-75dpi xfonts-scalable libnss3-tools auditd
Chromium dependencies:
sudo apt-get -y install fonts-dejavu-core
sudo snap install gnome-3-38-2004 gtk-common-themes
Download and install Chromium.
Download the snap (Ubuntu Server 20.04 and 22.04) package archive. This is a safe and verified archive hosted by Dynatrace.
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/snap/chromium-142.0.7444.175-3313.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/snap/chromium-141.0.7390.122-3285.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/snap/chromium-140.0.7339.185-3251.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/snap/chromium-139.0.7258.138-3235.tgz
You can verify the authenticity of the packages using the signature files stored together with the package archives.
Extract the installation packages. Go to the directory where you saved the archive and run the following command:
mkdir /tmp/chromium ; tar xzf chromium.tgz -C /tmp/chromium
This creates a /tmp/chromium directory and extracts the packages into it.
Install the extracted packages.
sudo chown -R root:root /tmp/snap-private-tmp
sudo snap ack /tmp/chromium/chromium.assert
sudo snap install --devmode /tmp/chromium/chromium.snap
Substitute dtuserag with the names of the ActiveGate service user and group if they differ from the default values.
sudo chown -R dtuserag:dtuserag /tmp/snap-private-tmp
This installs all the packages extracted to the /tmp/chromium/ directory. You can delete the /tmp/chromium/ directory and the downloaded chromium.tgz archive after successful Chromium installation.
After you satisfy the dependencies, run the ActiveGate installer with root rights with the --enable-synthetic parameter set to manual. For example:
/bin/bash ./Dynatrace-ActiveGate-Linux.sh --enable-synthetic=manual
curl to use the correct proxy. Specify your proxy and port details by running the commands as in this example:
vi /root/.curlrcproxy=http://proxy.example.com:8080
Set up repositories and install dependencies.
ActiveGate version 1.325 is the last Synthetic-enabled ActiveGate to support Red Hat 8.
sudo subscription-manager register --auto-attach
Extras and Optional repositories as well as EPEL (Extra Packages for Enterprise Linux ).
sudo subscription-manager repos --enable rhel-8-for-x86_64-baseos-rpmssudo subscription-manager repos --enable rhel-8-for-x86_64-appstream-rpmssudo rpm -Uvh https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm
sudo dnf install -y xorg-x11-server-Xvfb xorg-x11-xkb-utils xorg-x11-server-utils xorg-x11-fonts-100dpi xorg-x11-fonts-75dpi xorg-x11-fonts-Type1 libwayland-server mesa-libgbm curl nss-tools
Download the rpm package archive. This is a safe and verified archive hosted by Dynatrace.
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-152.0.7977.82-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-151.0.7922.137-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-150.0.7871.128-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-148.0.7778.215-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-147.0.7727.137-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-146.0.7680.177-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-144.0.7559.132-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-143.0.7499.192-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-142.0.7444.175-2.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-141.0.7390.122-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-133.0.6943.141-1.el8.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-140.0.7339.185-1.el9.tgz
curl --output chromium.tgz https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-139.0.7258.138-1.el9.tgz
Install extracted packages.
sudo dnf install -y /tmp/chromium/*.rpm
Disable automatic update of Chromium packages:
sudo dnf -y install python3-dnf-plugin-versionlocksudo dnf versionlock add chromiumsudo dnf versionlock add chromium-common
Optional Install non-Latin TrueType fonts:
sudo dnf install dejavu-fonts-common.noarch dejavu-sans-fonts.noarch
See how to update Chrome for Testing manually in Manage private Synthetic locations in Classic. We strongly recommend that you keep your Linux-based Synthetic-enabled ActiveGates and Chrome for Testing versions updated—Dynatrace supports Chrome for Testing versions that are no more than two versions behind the the latest Dynatrace-supported version for a specific ActiveGate release.
Unlike Chromium on other distributions, Chrome for Testing updates do not use package managers. You manually manage the Chrome binaries while dependencies are managed by the system package manager.
On Ubuntu Server 20.04 and 22.04 Chrome for Testing is supported since 1.331
sudo apt-get update && sudo apt-get -y install xvfb x11-xkb-utils xfonts-100dpi xfonts-75dpi xfonts-scalable libnss3-tools auditd fonts-dejavu-core
Install Chrome for Testing dependencies:
sudo apt-get -y install libasound2 libatk-bridge2.0-0 libatk1.0-0 libcairo2 libcups2 libgbm1 libnspr4 libnss3 libpango-1.0-0 libxcomposite1 libxdamage1 libxfixes3 libxkbcommon0 libxrandr2
Download and set up Chrome for Testing.
Create the Chrome for Testing directory:
sudo mkdir -p /usr/lib/chrome_for_testing
Download the Chrome for Testing package archive to a temporary location. This is a safe and verified archive hosted by Dynatrace.
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-152.0.7977.82.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-151.0.7922.138.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-150.0.7871.181.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-148.0.7778.215.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-147.0.7727.137.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-146.0.7680.178.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-144.0.7559.133.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-142.0.7444.175.zip
curl --output /tmp/chrome.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-141.0.7390.122.zip
Extract the installation package and clean up:
sudo unzip /tmp/chrome.zip -d /usr/lib/chrome_for_testingrm /tmp/chrome.zip
This creates a chrome-linux64 directory inside /usr/lib/chrome_for_testing and extracts the Chrome binary and supporting files into it.
Verify Chrome for Testing by checking the version:
/usr/lib/chrome_for_testing/chrome-linux64/chrome --version
Command output should show the Chrome version you downloaded.
After you satisfy the dependencies, run the ActiveGate installer with root rights. The installer will automatically detect and validate Chrome for Testing. For example:
Custom Chrome for Testing directory: If you want to use a different directory than the default /usr/lib/chrome_for_testing, specify it using the CFT_DIR environment variable during installation:
CFT_DIR=/custom/path /bin/bash ./Dynatrace-ActiveGate-Linux.sh --enable-synthetic=manual
You can also configure the path by setting the synthetic_chrome_for_testing_path property in the custom.properties file after installation. The new directory will be used after the upgrade of Synthetic module.
Chrome for Testing files are preserved during ActiveGate uninstallation. If you uninstall the ActiveGate, the Chrome for Testing directory and its contents will remain on the system and can be reused during reinstallation.
ActiveGate version 1.243+ In addition to web UI-guided ActiveGate installation and manual installation of the browser and dependencies, you can also install ActiveGate by pointing to a custom, local repository for browser components. As this repository is an HTTP server that you set up within your network, the advantage of this method is that it can be used in environments with intranet-only or limited network access.
This method of installing the browser broadly consists of:
Download the browser components—the package archive and signature file—from the safe and verified archive hosted by Dynatrace. See Requirements for private Synthetic locations for links to the latest supported and provided browser versions.
We recommend keeping your Linux-based Synthetic-enabled ActiveGates and browser versions up to date; choose the latest provided browser version for ActiveGate.
For example, for ActiveGate version 1.331 on Ubuntu 24 the required files are:
https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.ziphttps://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip.sigThe corresponding download commands are:
curl -o chrome-for-testing-linux64-143.0.7499.192.zip https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip
curl -o chrome-for-testing-linux64-143.0.7499.192.zip.sig https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip.sig
Install a web server of your choice and create a directory, for example, chromium-repo, to serve the browser components to the ActiveGate host. Copy the downloaded browser components to this directory.
Download the ActiveGate installer from Dynatrace Hub.
Resolve all dependencies and enable repositories as required as shown in Install the browser and dependencies manually from S3 above. The custom repository can be used only for browser packages, not their dependencies.
Install the ActiveGate with the Synthetic module enabled (--enable-synthetic) and the DYNATRACE_SYNTHETIC_CUSTOM_CHROMIUM_REPO environment variable pointing to the location of the custom repository (https://172.18.0.100/chromium-repo in this example).
sudo DYNATRACE_SYNTHETIC_CUSTOM_CHROMIUM_REPO=http://172.18.0.100:8000/chromium-repo /bin/bash Dynatrace-ActiveGate-Linux-x86-*.sh --enable-synthetic
You can use the hostname of the HTTP server instead of the IP address so long as the ActiveGate host can resolve the hostname.
Once you've installed the browser in this way from a custom repository, it can only be autoupdated. See Browser autoupdate from a custom repository in Manage private Synthetic locations for details and update alternatives.
You can install a custom browser version, that is, override the browser version that the ActiveGate installer looks for. This is applicable for manual ActiveGate installation, as described in Browser installation via S3 or via a custom repository.
In this command for manual ActiveGate installation via S3, an environment variable points to an explicit browser version number 143.0.7499.192, which is part of the Chrome for Testing package archive.
sudo /bin/bash -c "export DYNATRACE_SYNTHETIC_EXPLICIT_CHROMIUM_VERSION=143.0.7499.192; /bin/bash Dynatrace-ActiveGate-Linux-x86-*.sh --enable-synthetic"
This command searches for the browser version 143.0.7499.192 in the custom repository https://172.18.0.100/chromium-repo.
sudo DYNATRACE_SYNTHETIC_EXPLICIT_CHROMIUM_VERSION=143.0.7499.192 DYNATRACE_SYNTHETIC_CUSTOM_CHROMIUM_REPO=http://172.18.0.100:8000/chromium-repo /bin/bash Dynatrace-ActiveGate-Linux-x86-*.sh --enable-synthetic
In general, we recommend the deployment of a Synthetic-enabled ActiveGate to support the execution of all types of synthetic monitors (HTTP, browser, NAM).
If you don’t need to run browser monitors, consider deploying your node in browserless mode. This mode deploys the node without a browser, reducing hardware requirements. However, browser monitors can’t run on a browserless node.
Consider browserless nodes as an alternative to nodes with browser monitor support when you're focused purely on:
If you want to run browser monitors using Kerberos authentication, the private location should be configured to be able to get a ticket from the Kerberos Key Distribution Center.
ksetup /addkdc DOMAIN.TO.ADD address.of.kerberos.server
The DOMAIN.TO.ADD is your domain name and address.of.kerberos.server is the Kerberos Key Distribution Center (Active Directory Controller if you're using a Microsoft solution). Note that in the credentials used, the domain name must be in uppercase (for example, user@EXAMPLE.COM).
ActiveGate version 1.315+
To install Synthetic-enabled ActiveGate in FIPS compliant mode you need to add --fips-mode flag, see also customize ActiveGate installation for FIPS compliance.
/bin/bash ./Dynatrace-ActiveGate-Linux.sh --enable-synthetic --fips-mode
Please note that FIPS-compliant mode cannot be changed after installation. To change the mode, you need to uninstall ActiveGate and reinstall it with the desired settings. Additionally, if you intend to execute browser monitors, additional setup will be required as described in Proxy configuration for FIPS mode and Proxy configuration for FIPS mode with corporate proxy
To ensure the browser monitor traffic is FIPS compliant, it must be routed through a local intercepting proxy that encrypts traffic with a FIPS-certified crypto library. See Proxy configuration for FIPS mode for details.
For HTTP monitors, we use the Amazon Corretto Crypto Provider FIPS-certified cryptographic library that uses AWS-LC-FIPS 2.x as its cryptographic module. See Certificate #4816.
Synthetic-enabled ActiveGate in FIPS compliant mode supports the same set of cipher suites as regular ActiveGate.
Each tgz package archive is stored in the S3 bucket together with the *.tgz.sig signature file. To verify if the packages on your drive are authentic Dynatrace-provided archives:
Download the signature file. The filename is identical to the package archive but has the sig filename extension. For example, for Chromium 140, the command is:
curl --output chromium.tgz.sig https://synthetic-packages.s3.amazonaws.com/Chromium/rpm/chromium-140.0.7339.185-1.el9.tgz.sig
Verify the package:
wget https://ca.dynatrace.com/dt-root.cert.pem ; openssl cms-verify-in chromium.tgz.sig-inform PEM-content chromium.tgz-binary-CAfile dt-root.cert.pem > /dev/null
Verify the signature timestamp.
You can also get the exact timestamp of a signature. Download the *.tgz.sig.tsr file from the same location as installation packages and signature and run the following command:
openssl ts -reply -in chromium.tgz.sig.tsr -text
With ActiveGate version 1.175+, an ActiveGate executing synthetic monitors can connect through the proxy to both the Dynatrace Cluster and the tested resource. For more information, see Setting up proxy for private synthetic monitoring.
No, you need to run a clean installation specifically for the purpose of synthetic monitoring to enable your ActiveGate to execute monitors from private locations.
Private Synthetic locations require a clean installation of ActiveGate specifically for the purpose of synthetic monitoring.
Manually editing the custom.properties file is not enough to enable the ActiveGate to execute synthetic monitors.
Can't see screenshots in browser monitor results
Visit the Troubleshooting forum in the Dynatrace Community for more troubleshooting information.
Synthetic Classic
