If you have any questions related to Dynatrace Intelligence agentic and generative AI, start by seeing if they have already been answered in the FAQ.
Starting with Dynatrace version 1.335+, Dynatrace generative AI is enabled by default for all new tenants. This means that the change is applicable to all tenants created from Dynatrace version 1.335 onwards. You can see and change the setting in
Settings > Dynatrace Intelligence > Generative and agentic AI > Enable generative AI if you'd like to opt out.
Keep in mind that:
For details, see Getting started with generative AI.
Dynatrace Intelligence agentic and generative AI will be available for all Dynatrace SaaS customers using the latest Dynatrace. Both AWS and Azure accounts are supported.
Dynatrace Intelligence agentic and generative AI is not available for Dynatrace Managed customers.
No. Dynatrace Intelligence agentic and generative AI is available on any SaaS environment running the latest Dynatrace, irrespective of your licensing model.
No. There is no licensing associated with our current generative AI functionality. However, even though Dynatrace Intelligence agentic and generative AI is not charged for, all queries that are executed by generative AI are subject to licensing consumption according to your existing licensing agreement. If you are concerned about the cost of auto-executing generated queries, you can choose to generate DQL only, without executing it. For more information, see Query with natural language.
Dynatrace Intelligence agentic and generative AI itself has no impact on your license consumption. However, all queries that are executed by the generative AI are subject to license consumption according to your existing license agreement. For more information, see Will Dynatrace Intelligence agentic and generative AI be licensed?.
No. Customer data and customer prompts aren't used for training. Dynatrace Intelligence generative AI is based on a retrieval augmented generation (RAG) approach, which means that data and additional context is used only to enrich prompts. The underlying foundation model doesn't learn from this. Customer data isn't used to automatically fine-tune, train, or improve any models or services, either by Dynatrace or by enterprise vendors hosting the LLM.
However, Dynatrace has a custom DQL generation model that uses internally generated data sourced from the DQL queries executed by Dynatrace employees. The training data doesn't include any identifiable employee information or customer data.
Agentic Dynatrace Assist shares some additional information, such as tool call results, with enterprise vendors hosting the LLMs that Dynatrace agentic and generative AI are based on.
No, customer data is not used to train Dynatrace Intelligence agentic and generative AI at all. There is no risk of customer data being shared between environments.
For the basic Dynatrace Intelligence generative AI functionality, there is no access to customer data. The generic query generation relies only on public domain knowledge (Semantic Dictionary, DQL documentation, etc.) and an extensive, curated dataset that is managed by Dynatrace. The only customer context that generative AI has access to is the user's prompt.
However, if you enable environment-aware queries, Dynatrace Intelligence generative AI will create a semantic index that is stored in the Dynatrace platform. Creating a semantic index allows generative AI to generate more accurate queries that identify and reference relevant entities, events, and metrics. This lets you run deeper and more complex data analysis by asking about the specifics of the data in your environment. Keep in mind that:
Yes. Dynatrace Intelligence agentic and generative AI respects user privileges, and it may provide different responses to different users based on their access rights.
The Dynatrace Intelligence generative AI functionality currently allows you to conduct quick data analysis in Notebooks and Dashboards by generating DQL based on your natural language prompts.
You can provide feedback directly in the Notebooks or Dashboards apps. To learn how to give feedback through Dashboards and Notebooks, see Query with natural language.
Yes. Dynatrace Intelligence agentic and generative AI does respond to commands and questions in languages other than English.
We have a ready-made self-adoption dashboard available, which provides a comprehensive overview of:
You or your administrators can use this dashboard to get a better understanding of which generative AI features are being used, to review user prompts and AI responses, and to get insights into users' satisfaction with the features. The dashboard can be found under the title Dynatrace Intelligence Feature Adoption.
All interactions with Dynatrace Intelligence generative AI are logged in Grail as dt.system.events and require relevant permissions to retrieve and view such events.
