Timeseries API v1 - PUT a custom metric
Registers your custom metric. You need to specify the ID, the display name, and type of the metric.
If you use the ID of an existing metric, the respective parameters will be updated.
The request consumes and produces an application/json
payload.
PUT | ManagedDynatrace for Government | https://{your-domain}/e/{your-environment-id}/api/v1/timeseries/{timeseriesIdentifier} |
SaaS | https://{your-environment-id}.live.dynatrace.com/api/v1/timeseries/{timeseriesIdentifier} | |
Environment ActiveGate | https://{your-activegate-domain}:9999/e/{your-environment-id}/api/v1/timeseries/{timeseriesIdentifier} |
Authentication
To execute this request, you need an access token with DataExport
scope.
To learn how to obtain and use it, see Tokens and authentication.
Parameters
Parameter | Type | Description | In | Required |
timeseriesIdentifier | string | The ID for the new metric. It must start with the You can use alphanumeric characters and the following punctuation marks: periods ( If you use the ID of an existing metric the respective parameters will be updated. The length of ID is limited to 256 characters. | path | required |
body | TimeseriesRegistrationMessage | The JSON body of the request. Contains parameters of the new custom metric. | body | optional |
Request body objects
The TimeseriesRegistrationMessage
object
The definition of a custom metric.
Element | Type | Description | Required |
dimensions | string[] | The metric dimension key that will be used to report multiple dimensions. For example, a dimension key to report the metric for different network cards for the same firewall. You can use alphanumeric characters and the following punctuation marks: periods ( The CUSTOM_DEVICE dimension is added to each new custom metric automatically. The length of dimension keys and values is limited to 128 characters each. | optional |
displayName | string | The name of the metric that will appear in the user interface. It is limited to 256 characters. To edit the value of that field, you need the Write configuration ( | optional |
types | string[] | The definition of the technology type. It is used to group metrics under a logical technology name in the UI. Metrics must be assigned a software technology type that is identical to the technology type of the custom device you are sending the metric to. For example, if you define your custom device using type The field is required when creating a new metric. | optional |
unit | string | The unit the metric will use. To edit the value of that field, you need the Write configuration (
| optional |
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
1{2 "dimensions": [3 "coffee"4 ],5 "displayName": "received.coffees",6 "types": [7 "coffee machine"8 ],9 "unit": "Count"10}
Response
The result is JSON containing the metadata of the newly created metric.
Response codes
Code | Type | Description |
201 | TimeseriesDefinition | Success. The custom metric has been created. |
Response body objects
The TimeseriesDefinition
object
The configuration of a metric with all its parameters.
aggregationTypes | string[] | The list of allowed aggregations for this metric.
detailedSource | string | The feature, where the metric originates. |
dimensions | string[] | The fine metric division, for example process group and process ID for some process-related metric. |
displayName | string | The name of the metric in the user interface. |
filter | string | The feature, where the metric originates.
pluginId | string | The ID of the plugin, where the metric originates. |
timeseriesId | string | The ID of the metric. |
types | string[] | Technology type definition. Used to group metrics under a logical technology name. |
unit | string | The unit of the metric.
warnings | string[] | The warnings that occurred while creating the metric. |
Response body JSON model
1{2 "aggregationTypes": [3 "AVG",4 "SUM",5 "MIN",6 "MAX"7 ],8 "detailedSource": "Infrastructure",9 "dimensions": [10 "HOST"11 ],12 "displayName": "CPU idle",13 "filter": "BUILTIN",14 "timeseriesId": "com.dynatrace.builting:host.cpu.idle",15 "types": [16 "Test"17 ],18 "unit": "Percent",19 "warnings": []20}
Example
In this example, the request creates a new custom metric with the custom:firewall.connections.dropped
ID of the F5-Firewall
type. Its unit is count
. The nic
dimension key is used to report the metric for different network cards for the same firewall.
The API token is passed in the Authorization header.
The request returns parameters of the newly created metric as confirmation.
Curl
1curl -X PUT \2 https://mySampleEnv.live.dynatrace.com/api/v1/timeseries/custom:firewall.connections.dropped \3 -H 'Authorization: Api-Token dt0c01.abc123.abcdefjhij1234567890' \4 -H 'Content-Type: application/json' \5 -d '{6 "displayName" : "Dropped TCP connections",7 "unit" : "Count",8 "dimensions": [9 "nic"10 ],11 "types": [12 "F5-Firewall"13 ]14}'
Request URL
1https://mySampleEnv.live.dynatrace.com/api/v1/timeseries/custom:firewall.connections.dropped
Request body
1{2 "displayName" : "Dropped TCP connections",3 "unit" : "Count",4 "dimensions": [5 "nic"6 ],7 "types": [8 "F5-Firewall"9 ]10}
Response body
1{2 "timeseriesId": "custom:firewall.connections.dropped",3 "displayName": "Dropped TCP connections",4 "dimensions": [5 "CUSTOM_DEVICE",6 "nic"7 ],8 "unit": "Count (count)",9 "detailedSource": "API",10 "types": [11 "F5-Firewall"12 ],13 "aggregationTypes": [14 "AVG",15 "SUM",16 "MIN",17 "MAX"18 ],19 "filter": "CUSTOM"20}
Response code
201
