Observe GitHub workflow actions and pull requests with Dashboards and SDLC events
  • Latest Dynatrace
  • Tutorial
  • 4-min read
  • Preview
In this tutorial, you'll
  • Learn about your GitHub workflow performance.
  • Learn about your pull request timings.
  • Integrate GitHub and Dynatrace.
  • Use Dashboards Dashboards to observe GitHub workflows and pull requests.
  • Use this information to streamline CI/CD pipelines, improve productivity, and generate data-driven insights.
Concepts
Software Development Lifecycle (SDLC) events
SDLC events are events with a separate event kind in Dynatrace that follow a well-defined semantics for capturing data points from a software component's software development lifecycle. The SDLC event specification defines the semantics of those events.
Why were GitHub webhook events changed into SDLC events?
The main benefits are data normalization and tool agnosticism. As a result, Dashboards Dashboards, apps, and Workflows Workflows can be built on SDLC events with well-defined properties rather than tool-specific details.
Why use GitHub webhooks instead of REST API?
The main GitHub webhooks advantages are:
  • Require less effort and fewer resources than polling an API.
  • Scale better than API calls.
  • Allow near-real-time updates, since webhooks are triggered when an event occurs. For more information, see Choosing webhooks or the REST API for more details.
Target audience
This information is intended for platform engineers and DevOps engineers who use GitHub in their Internal Development Platform (IDP).
Learning outcome
In this tutorial, you'll learn how to
  • Forward GitHub webhook events to Dynatrace.
  • Normalize the ingested event data.
  • Use Dashboards Dashboards to analyze data and drive improvements.
Security disclaimer
GitHub webhooks require HMAC-SHA256 signature verification, which Dynatrace doesn't currently support. A secure production setup requires a proxy, such as a serverless function, to handle authentication.
For brevity, this tutorial uses a Dynatrace access token as a URL parameter in the GitHub webhook configuration. This approach is insecure and should only be used in sandbox environments, as the token could be exposed or misused.
To mitigate the risk, adhere to the following security best practices:
  • Minimal Permissions: Assign the least set of permissions necessary for the access token, as outlined in this tutorial.
  • Access Control: Limit the ability to configure webhooks in GitHub to a small group of authorized personnel.
  • Token Security: Never commit the access token to a Git repository.
Prerequisites
Install the Configuration As Code tool of your choice. Either install the Terraform CLI or install the Monaco CLI. Depending on the tool you choose, pick the correct setup section below.
1. Setup: Prepare the configuration
  1. Create a new platform token with the following permissions and store it in a secure place:
    • Run apps: app-engine:apps:run.
    • View OpenPipeline configurations: settings:objects:read.
    • Edit OpenPipeline configurations: settings:objects:write.
    • Create and edit documents: document:documents:write.
    • View documents: document:documents:read.
  2. Clone the Dynatrace community examples repository using the following command.
    git clone https://github.com/Dynatrace/community-examples.git
2. Setup: Configuration as Code
You can choose between two options:
  • Terraform.
  • Monaco.
  1. Set up Terraform.
    1. Prepare the Terraform configuration.
      The configuration consists of
      • Dashboards Dashboards to analyze GitHub activities.
      • OpenPipeline configuration to normalize GitHub events into SDLC events.
      1. Move to the github_pipeline_observability_terraform directory with the following command.
        cd community-examples/configuration-as-code/github_pipeline_observability_terraform
      2. Store the retrieved platform token in an environment variable.
      $env:DYNATRACE_PLATFORM_TOKEN='<YOUR_PLATFORM_TOKEN>'
      export DYNATRACE_PLATFORM_TOKEN='<YOUR_PLATFORM_TOKEN>'
      1. Store your Dynatrace environment URL in an environment variable. Make sure to replace <YOUR-DT-ENV-ID> with your Dynatrace environment ID, e.g. abc12345.
      $env:DYNATRACE_ENV_URL='https://<YOUR-DT-ENV-ID>.apps.dynatrace.com'
      export DYNATRACE_ENV_URL='https://<YOUR-DT-ENV-ID>.apps.dynatrace.com'
    2. Check the OpenPipeline configuration for SDLC events.
      These steps modify the OpenPipeline configuration for SDLC events. If your OpenPipeline configuration contains only default/built-in values, you can apply it directly. If you have any dynamic routes, first download your configuration and then manually merge it into the provided configuration.
      Step 3 indicates if a configuration merge is needed or if you can apply the provided configuration directly.
      1. Go to Settings > Process and contextualize > OpenPipeline > Software Development Lifecycle.
      2. Check the Dynamic routing section, are there any other routes than Default route?
      3. If the answer is yes, follow the steps in the next section. Otherwise, skip ahead.
    3. Merge OpenPipeline routing entries.
      If you have any OpenPipeline routing entries that aren't default, then you need to merge them before you can proceed.
      • Download your OpenPipeline configuration. You need to set up the DYNATRACE_ENV_URL and DYNATRACE_PLATFORM_TOKEN environment variables according to the Dynatrace Terraform provider installation guide. Then you can use the export utility of the Dynatrace Terraform provider to download all routing entries for SDLC events. Navigate to the directory that includes the terraform-provider-dynatrace_vx.y.z binary and use it to export the dynatrace_openpipeline_v2_events_sdlc_routing configurations, for example, ./terraform-provider-dynatrace_v1.86.0 -export dynatrace_openpipeline_v2_events_sdlc_routing.
        You should see an output similar to this example:
        The environment variable DYNATRACE_TARGET_FOLDER has not been set. Use the'configuration' folder as default.
        Downloading "dynatrace_openpipeline_v2_events_sdlc_routing" Count: 1
        Post-Processing Resources ...
        - [POSTPROCESS] dynatrace_openpipeline_v2_events_sdlc_routing - openpipeline_v2_events_sdlc_routingPost-Processing Resources - Group child configs with parent configs ...
        Finishing touches ...
        Writing ___resources___.tf
        Writing ___datasources___.tf
        Writing main.tf
        Writing ___variables___.tf
        Writing main ___providers___.tf
        Writing modules ___providers___.tf
        Remove Non-Referenced Modules ...
        Finish Export ...
        Terraform executable path: /usr/local/bin/terraform
        Executing 'terraform init'
        ... finished after 3 seconds
      • The export utility has created a folder configuration. You can now open the following files:
        • Your downloaded configuration file containing all available routing entries for SDLC events ./configuration/modules/openpipeline_v2_events_sdlc_routing/openpipeline_v2_events_sdlc_routing.openpipeline_v2_events_sdlc_routing.tf.
        • The provided file main.tf, which contains the routing configurations for the GitHub pipelines.
      • Merge all routing_entry blocks of your downloaded routing file into the routing_entries block of the resource events_sdlc_global_routing_table in main.tf, and then save the file.
      This is mandatory because the Dynamic Routing table is a global configuration, and the order of the entries, as well as the matcher clauses, determines the overall routing.
    4. Apply the Terraform configuration.
      Run this command to verify the provided Terraform configuration.
      terraform plan
      Run this command to apply the provided Terraform configuration.
      terraform apply
    Set up Monaco.
    1. Prepare the Monaco configuration.
      1. Move to the github_pipeline_observability directory with the following command.
      1. In the manifest.yaml file, replace the <YOUR-DT-ENV-ID> placeholder in the environments name property, and url value property with your Dynatrace environment ID.
      manifestVersion: 1.0
      projects:
      - name: pipeline_observability
      environmentGroups:
      - name: group
      environments:
      - name: <YOUR-DT-ENV-ID>
      url:
      type: value
      value: https://<YOUR-DT-ENV-ID>.apps.dynatrace.com
      auth:
      platformToken:
    1. Merge OpenPipeline routing entries
    If you have any OpenPipeline routing entries, that are not default, then you need to merge them before you can proceed.
      monaco download -e <YOUR-DT-ENV-ID> --settings-schema "builtin:openpipeline.events.sdlc.routing"
    • Open the following files:
      • Your downloaded configuration file, download_<DATE>-<TIME>/project_<YOUR-DT-ENV-ID>/builtinopenpipeline.events.sdlc.routing/<SOME-UUID>.json.
      • The provided configuration file, pipeline_observability/openpipeline/events.sdlc.global.routing.json.
    • Merge the routingEntries of your downloaded routing file into the routingEntries of events.sdlc.global.routing.json, and then save the file.
    This is mandatory as the Dynamic Routing table is a global configuration and the order of the entries as well as the matcher clauses determine the overall routing.
    1. Deploy the Monaco configuration.
      Run this command to verify the Monaco configuration provided.
      monaco deploy --dry-run manifest.yaml
      Run this command to apply the Monaco configuration provided.
      monaco deploy manifest.yaml
3. Setup: Create a Dynatrace access token
To receive events processed by OpenPipeline, you need an access token with the following OpenPipeline scopes:
  • openpipeline.events_sdlc.
  • openpipeline.events_sdlc.custom.
To generate an access token:
  1. Go to Access tokens Access Tokens.
  2. Select Generate new token.
  3. Enter a name for your token.
    Dynatrace doesn't enforce unique token names. You can create multiple tokens with the same name. Be sure to provide a meaningful name for each token you generate. Proper naming helps you to efficiently manage your tokens and perhaps delete them when they're no longer needed.
  4. Select the required scopes for the token.
  5. Select Generate token.
  6. Copy the generated token to the clipboard. Store the token in a password manager for future use.
    You can only access your token once upon creation. You can't reveal it afterward.
  1. Select these scopes:
    • OpenPipeline - Ingest Software Development Lifecycle Events (Built-in) (openpipeline.events_sdlc)
    • OpenPipeline - Ingest Software Development Lifecycle Events (Custom) (openpipeline.events_sdlc.custom)
  2. Save the generated token securely for subsequent steps. We refer to it as <YOUR-ACCESS-TOKEN>.
4. Setup in GitHub: Create the GitHub webhook
Exchange the <YOUR-DT-ENV-ID> and <YOUR-ACCESS-TOKEN> placeholders with your Dynatrace environment ID and access token, respectively, in the https://<YOUR-DT-ENV-ID>.live.dynatrace.com/platform/ingest/custom/events.sdlc/github?api-token=<YOUR-ACCESS-TOKEN> example.
Use this URL when configuring the Payload URL in the GitHub webhooks settings below.
In GitHub, create the webhook
  1. In GitHub, select your organization or repository.
  2. Go to Settings > Webhooks.
  3. Select Add webhook.
  4. Configure the following settings:
    • Payload URL: Enter the URL that receives the webhook event.
    • Content Type: application/json
    • Which events would you like to trigger this webhook?: Select Let me select individual events and enable:
      • Pull requests
      • Workflow runs
      • Workflow jobs
      • (disable "Pushes")
  5. Select Active to receive event details when the hook is triggered.
  6. Select Add webhook to save the webhook.
5. Unlock enhanced development insights with GitHub Dashboards
Now that you've successfully configured GitHub and Dynatrace, you can use Dashboards Dashboards and SDLC events to observe your GitHub workflows and pull requests.
Analyze
In Dynatrace, open the GitHub Workflow Pulse and the GitHub Pull Requests dashboards to:
  • Track real-time activities of pull requests.
  • Analyze workflow execution details and workflow health.
  • Gain job insights.
  • Review step durations for workflows.
To try out, go to Dynatrace Playground.
Optimize
Use these insights for the following improvement areas:
  • Increase CI/CD pipeline efficiency.
    Observing workflow executions lets you identify bottlenecks and inefficiencies in your CI/CD pipelines.
    Knowing about these bottlenecks and inefficiencies helps optimize build and deployment processes, leading to faster and more reliable releases.
  • Improve developer productivity.
    Automated pipelines reduce the manual effort required for repetitive tasks, such as running tests and checking coding standards. This automation allows developers to focus more on writing code and less on administrative tasks.
  • Get data-driven development insights. Analyzing telemetry data from CI/CD pipelines provides valuable insights into the development process. You can use the telemetry data to make informed decisions and continuously improve the development flows.
Continuous improvements
Check and adjust your CI/CD pipelines regularly to make sure they're running smoothly.
In Dynatrace, adjust the timeframe of the relevant dashboards to monitor the long-term impact of your improvements.
Call to action
We highly value your insights on pipeline observability. Your feedback is crucial in helping us enhance our tools and services. Visit the Dynatrace Community page to share your experiences, suggestions, and ideas directly on the Feedback channel for CI/CD Pipeline Observability.
Further reading
  • Blog post: Observability throughout the software development lifecycle increases delivery performance.
Related topics
  • How to ingest data (events)
  • Software development lifecycle (SDLC) events
  • Ingest SDLC events
  • Dashboards
Related tags
Software DeliveryDashboardsDashboardsOpenPipelineOpenPipeline
