Send Slack notifications for problems
  • Latest Dynatrace
  • Tutorial
  • 4-min read
Problems are automatically opened by Dynatrace when anomalies or alert conditions are detected in your environment. In Workflows Workflows, build a simple workflow that listens to problems and automatically sends Slack Connector Slack notifications whenever a new problem is triggered. This guide shows you how.
What will you learn
In this tutorial, you'll learn how to alert your team in real time by automatically messaging the details of a new problem to a specific Slack channel.
At a short glance, you will:
  1. Create a simple workflow.
  2. Add an event trigger for Davis problems.
  3. Configure a Slack message.
  4. Save and run the workflow to get email notifications.
  5. Verify your workflow is working as expected.
Prerequisites
Steps
    1. Go to Workflows Workflows.
    2. Select Add Workflow in the upper-right corner of the page.
    3. Select the workflow title. By default, it is Untitled workflow, and enter a meaningful name. The workflow type is set to simple workflow by default.
    1. In the Select trigger section, select a Problem trigger.
    2. Set the Problem state to active or closed. This option means that the problem can be both active or closed. This setting causes the workflow to trigger twice, once when the problem becomes active and again when it is closed.
    3. In the Event category drop-down list, select Select all.
    4. Optional Select Query past events to see the most recent problem events that would have triggered this workflow.
    5. Optional Enter Entity tags or Additional custom filter query to only trigger the workflow on the relevant problems.
    1. Select Add Add task on the trigger node.
    2. In the Choose action section, select Slack Connector Send message action type. Give the action type a meaningful title.
    3. Select a pre-configured Slack connection.
    4. Select a Slack connection from the Connection drop-down list.
    5. Select a Slack channel for your message from the Channel drop-down list.
    6. In the Message field, enter the following:
      "blocks": [
      "type": "header",
      "text": {
      "type": "plain_text",
      "text": "{{ ':white_check_mark:' if event()['event.status'] == 'CLOSED' else ':warning:' }} {{ 'RESOLVED' if event()['event.status'] == 'CLOSED' else 'OPEN' }} - {{ event()['event.name']}}",
      "emoji": true
      "type": "section",
      "text": {
      "type": "mrkdwn",
      "text": "- *Problem link*: <{{ environment().url }}/ui/intent/dynatrace.davis.problems/view-problem#%7B%22event.id%22%3A%22{{ event()['event.id'] }}%22,%22event.kind%22%3A%22{{event()['event.kind']}}%22%7D|{{ event()['display_id'] }}> \n- *Impacted Entities:* `{{ event()['affected_entity_ids'] }}`\n- *Problem duration:* `{{ (event().get('resolved_problem_duration', 0) | int) / 1000000 / 1000 / 60 }} minutes`"
      "type": "section",
      "text": {
      "type": "mrkdwn",
      "text": {{ ('>' ~ event()['event.description']) | replace('\n', '\n>') | to_json }}
      "type": "divider"
      "type": "section",
      "text": {
      "type": "mrkdwn",
      "text": "*Workflow link*: <{{ environment().url }}/ui/apps/dynatrace.automations/workflows/{{ execution().workflow.id }}|Workflow>"
      This configuration uses event context placeholders to populate the Slack message with relevant problem details dynamically.
      The Problem trigger returns the problem record. You can use any field from the problem record, stored in dt.davis.problems, in the Slack message.
  4. Save and run the workflow to send out Slack notifications.
    1. Select Create draft.
    2. Select Deploy.
    3. Select Run to see the selected problem event that will be used for the workflow.
  5. Verify that your workflow is working as expected:
    1. Go to your workflow.
    2. Select Run.
    3. Select Run again to execute the workflow.
      Execution logs aren't available for a simple workflow. If an error occurs, you can find the error details on the right in the task details pane.
Conclusion
You’ve created a simple workflow that sends Slack messages when problems are opened or closed. This setup helps to ensure that your team is immediately informed about critical issues in your environment.
You can extend this workflow by
  • Adding conditions to handle specific problem categories or severities.
  • Adding auto remediation steps to your workflow.
This workflow is a great starting point for automating incident response and improving operational awareness.
Related tags
Dynatrace PlatformWorkflowsWorkflowsSlack ConnectorSlack
