Dynatrace Operator release notes version 1.9.0
  • Release notes
Release date: April 13, 2026
Minimum operator version required for direct upgrade: 1.5.0—see Upgrade from older versions. Review the release notes for each intermediate version and pay attention to breaking changes before upgrading.
On this page, you’ll find an overview of what’s new and improved in Dynatrace Operator version 1.9.0.
New features and enhancements
  • Metadata enrichment for OneAgent code modules:
    When using applicationMonitoring or cloudNativeFullstack, metadataEnrichment is enabled automatically and does not need to be added explicitly. This ensures Kubernetes metadata is automatically added to all signals, giving full observability context without additional configuration.
  • The SecurityContexts of Dynatrace OpenTelemetry Collector, EdgeConnect, NodeConfigCollector, and CSI driver containers have been updated to align with the latest CIS Kubernetes Benchmark and Pod Security Standards (PSS).
  • When Kubernetes monitoring is first enabled (for example, when onboarding a new cluster), KSPM settings are automatically configured. New clusters no longer require manual configuration. Existing clusters and their configurations are not affected. For details, see Unavailable in Dynatrace Managed.
  • Legacy dt.kubernetes.* metadata enrichment attributes have been fully replaced by k8s.* attributes. For backward compatibility, the legacy attributes are still emitted by default. If you've migrated your dashboards, alerts, and queries to use k8s.*, you can disable the legacy attributes by setting feature.dynatrace.com/enable-attributes-dt.kubernetes="false" on the DynaKube. For the full list of feature flags, see DynaKube feature flags for Dynatrace Operator.
    • Affected attributes (with replacement from Semantic dictionary):
      • dt.kubernetes.cluster.id (replaced by k8s.cluster.uid)
      • dt.kubernetes.workload.kind (replaced by k8s.workload.kind)
      • dt.kubernetes.workload.name (replaced by k8s.workload.name)
  • To improve startup times, the image pull policy now follows the Kubernetes default (IfNotPresent for tagged images, Always for :latest or untagged images) instead of being explicitly set to Always. You can configure the image pull policy in the DynaKube for operator managed components or the Helm chart for the operator itself. For configuration options, see DynaKube parameters for Dynatrace Operator.
  • Following changes in Kubernetes 1.31+, AppArmor profiles are now configured directly in the pod or container securityContext instead of using annotations. No action is required — the Dynatrace Operator automatically applies the correct method based on your cluster version. If you're on Kubernetes 1.30 or earlier, the existing Helm chart-based AppArmor configuration continues to work but is deprecated and will be removed after Kubernetes 1.30 reaches end of life. For details, see Enable AppArmor for enhanced security.
  • You can now control rolling update behavior directly in the DynaKube individually for OneAgent, ActiveGate, and LogMonitoring using the new rollingUpdate field. For details, see DynaKube parameters for Dynatrace Operator.
  • The support archive now includes a kubernetes-version.txt file with the Kubernetes server version of the cluster.
Resolved issues
  • Fixed an issue where the Dynatrace Operator reset the replica count of ActiveGate, EdgeConnect, OpenTelemetry Collector, and databases extension reconcilers to default values on every reconciliation, interfering with horizontal pod autoscaling (HPA). The Operator no longer writes the replicas field, unless explicitly specified in the DynaKube.
  • Fixed an issue where a secret creation failure for Dynatrace injection in one namespace aborted secret creation for all remaining namespaces.
  • The Helm value customPullSecret is now applied to all components deployed in the Dynatrace namespace.
  • Injection behavior controlled by dynatrace.com/inject, otlp-exporter-configuration.dynatrace.com/inject, and the DynaKube feature flag feature.dynatrace.com/automatic-injection is now aligned with the OneAgent and metadata enrichment injection mechanisms. For details about the available settings for these flags, see Pod and container annotations.
  • Namespace validation now also covers OTLP-exporter auto-configuration. Applying a DynaKube fails with an error if its namespaceSelector for OneAgent injection, metadata enrichment, or OTLP-exporter configuration overlaps with another DynaKube. Ensure that each namespace is assigned to only one DynaKube for injection.
  • Resolved an issue where CSI volumes could stop working after a node restart due to faulty backoff logic. Mount availability is now verified before backing off.
  • Fixed an issue where the ActiveGate TLS secret was not cleaned up correctly due to an incorrect deletion name. The correct <dynakube>-activegate-tls name is now used.
  • Fixed a connectivity issue between in-cluster ActiveGate and CodeModules agents. TLS certificate secrets in monitored namespaces are now correctly removed when no longer needed — for example, when a user disables the automatic-tls-certificate feature flag. Previously, stale secrets were still being mounted into application pods, causing connectivity failures due to an expired ActiveGate TLS certificate.
  • The app.kubernetes.io/version label on deployed Extensions Execution Controller (EEC) pods now reflects the version specified in the DynaKube. Previously, the label incorrectly contained the operator version or was empty.
  • The EdgeConnect AppArmor annotation that was previously set by the Operator has been removed, as it was never enforced and had no effect. Note that the annotation approach only works on Kubernetes 1.30 and earlier — on Kubernetes 1.31+, the securityContext-based AppArmor configuration is not yet supported for EdgeConnect. To set an AppArmor profile on Kubernetes 1.30 or earlier, use the EdgeConnect spec.annotations field. For details, see Enable AppArmor for enhanced security.
  • Fixed an issue where the node-image-pull job for downloading Dynatrace code modules used a node name instead of a node selector, causing suboptimal interaction with the Kubernetes scheduler.
  • Fixed an issue where deleting a DynaKube and recreating it with a different name caused the Kubernetes cluster connection settings in Dynatrace to be overwritten, changing the cluster name visible in the Dynatrace UI. The Operator now reconciles the Kubernetes cluster entity before modifying settings, ensuring existing configuration is preserved.
  • Fixed an issue where the ActiveGate entered an initial Error phase during deployment before reconciling successfully.
  • Aggregated ClusterRoles are no longer used. This resolves a known incompatibility with OperatorHub and aligns with least-privilege principles, as their use requires additional permissions during Dynatrace Operator installation. The Dynatrace Operator deployment now uses standard ClusterRoles exclusively. For details, see ClusterRole aggregation.
Known issues
  • Since Dynatrace Operator 1.9.0, a RuntimeDefault seccomp profile is applied to the Dynatrace init container by default. On OpenShift, this can interfere with SecurityContextConstraints (SCCs) — such as anyuid, restricted, or nonroot — that prevent seccomp profile usage, causing the system to fall back to a different SCC (for example restricted-v2). This may render application pods unschedulable or cause workload degradation.
    Disable seccomp profile for Dynatrace init containers if you are affected.
  • Resolved with Dynatrace Operator version 1.9.1 When a OneAgent code modules version is updated, the CSI driver's cleanup of old code modules versions could delete OneAgent binaries that running pods still depend on. Pods created after the update are not affected, but if a container in an already running pod restarts (for example, after an out-of-memory termination), the application loses its OneAgent files, which leads to the application no longer being monitored. Until you upgrade, pin codeModulesImage to a specific version to avoid triggering the cleanup.
Removal and deprecation notices
  • The Helm repository located in dynatrace/helm-charts is archived and no longer receives updates. If you still install or upgrade Dynatrace Operator from it, switch to the OCI registry:
    helm upgrade dynatrace-operator oci://public.ecr.aws/dynatrace/dynatrace-operator \
    --version <version> \
    --namespace dynatrace \
    --reset-then-reuse-values \
    --install
    If you can't use OCI, point your Helm repository to dynatrace/dynatrace-operator instead:
    helm repo remove dynatrace
    helm repo add dynatrace https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/main/config/helm/repos/stable
    For details, see Migrate from the legacy Helm repository.
  • To prevent potential disruptions, we strongly advise keeping your DynaKube API version up to date. Once a version is deprecated and removed, updates may become significantly more complex and time-sensitive.
    • More information about the deprecation process of the DynaKube API versions can be found in the migration guide.
  • The operator.apparmor, webhook.apparmor, and csidriver.apparmor Helm values are deprecated. On Kubernetes version 1.31+, set AppArmor using appArmorProfile in the podSecurityContext instead. These values will continue to work until Kubernetes version 1.30 reaches end of life (August 2026). See Enable AppArmor for enhanced security for details.
  • The DynaKube field .spec.oneAgent.(cloudNativeFullStack|classicFullStack|hostMonitoring|applicationMonitoring).version is deprecated and should no longer be used. The flag will be removed in a future version of the Dynatrace Operator. Do one of the following:
    • Pin the OneAgent version on your environment to control all connected Kubernetes clusters at once.
    • Use the .spec.oneAgent.(cloudNativeFullStack|classicFullStack|hostMonitoring|).image and .spec.oneAgent.(cloudNativeFullStack|applicationMonitoring|).codeModulesImage fields to pin the version on a per-DynaKube basis.
  • The feature.dynatrace.com/oneagent-max-unavailable flag is deprecated. Use the rollingUpdate field in the DynaKube instead. For details, see DynaKube parameters for Dynatrace Operator.
Upgrade from Dynatrace Operator version 1.8
In Dynatrace Operator version 1.9, the DynaKube API version v1beta3 is removed from the CRD. Applying DynaKube resources using this version will fail. Additionally, v1beta4 is now deprecated. Update your DynaKube manifests to v1beta6 before upgrading the Dynatrace Operator. For more information, see Migration guide for DynaKube API versions.
Pods injected via applicationMonitoring or cloudNativeFullStack now automatically receive metadata enrichment. If metadataEnrichment in the DynaKube was enabled only to support OneAgent injection, it can be removed.
The feature flag feature.dynatrace.com/init-container-seccomp-profile is now enabled by default. If you relied on the unspecified seccomp profile on injected init containers, set the flag to false on your DynaKube.
Important notice for clusters that have been running Dynatrace Operator version 1.3 and earlier in the past
Clusters that have previously run Dynatrace Operator version 1.3 and earlier may have obsolete v1beta1 or v1beta2 entries in the DynaKube CRD's .status.storedVersions. These must be removed before upgrading to this release, or the CRD upgrade will fail.
Whether you need to stop at Dynatrace Operator version 1.7.3 first depends on your installation method:
  • Helm-based installation
    • Current version 1.4.0 and later—No action required. The Helm pre-upgrade hook automatically removes obsolete .status.storedVersions entries during the upgrade.
    • Current version 1.3 and earlier—You must upgrade to Dynatrace Operator 1.7.3 before upgrading to the next release.
  • Alternative installation methods (Red Hat OpenShift OperatorHub, OperatorHub.io, Google Marketplace, or plain Kubernetes manifests)
    • Never ran version 1.3 and earlier—No action required.
    • Previously ran version 1.3 and earlier—You must upgrade to Dynatrace Operator 1.7.3 before upgrading to the next release.
Manually remove obsolete entries from .status.storedVersions
Instead of upgrading to version 1.7.3, you can manually remove the obsolete entries from .status.storedVersions:
  1. List the stored versions in the CRD:
    kubectl -n dynatrace get crd dynakubes.dynatrace.com -o jsonpath='{.status.storedVersions}'
  2. Continue only if multiple versions are listed in the output. If only one version is listed, no action is required.
  3. Identify the currently active version:
    storage_version=$(kubectl get customresourcedefinitions dynakubes.dynatrace.com -o jsonpath='{.spec.versions[?(@.storage==true)].name}')
  4. Convert all DynaKubes to the active version:
    kubectl get dynakube -n dynatrace -o yaml | kubectl replace -f -
  5. Remove all previous versions while keeping the active version:
    kubectl patch customresourcedefinitions dynakubes.dynatrace.com --subresource='status' --type='merge' -p "{\"status\":{\"storedVersions\":[\"${storage_version}\"]}}"
Ensuring that .status.storedVersions is clean is crucial to avoid issues with future upgrades.
ArgoCD may display resources that are still using an old API version as "out-of-sync".
