URL-based sampling
OneAgent version 1.281+
To modify a specific trace contribution to the environment trace volume, you can customize the capturing frequency of specific URLs to your needs.
- Go to Settings > Server-side service monitoring > URL-based sampling.
- Select Add URL.
- Create your new rule.
To modify a URL capturing frequency, select a scaling factor option from Importance of a specific URL. To capture the URL more frequently, increase the capturing value and vice versa. If you never want to capture a trace for a specific URL, turn on Ignore this URL.
Type the URL path or specify query parameters.
Use wildcards (
) for URLs with similar segment paths, such as URLs of the same domain.For example, in
/api/product/**/detail
, all values between slashes are ignored; the path applies to both/api/product/1/detail
and/api/product/2/detail
.To specify query parameters, go to Query parameters and select Add item.
Type a query parameter name.
- Type the query parameter value or turn on Query parameter value is undefined.
optional To apply the scaling factor to one or more HTTP methods, turn off Any HTTP method and select the HTTP method(s) to target.
- Select Save changes.
Process and process group override
To override URL-based sampling environment settings for a specific process group or process
- On the process group level, select More (…) > Process group settings and select URL-based sampling.
- On the process level, select More (…) > OneAgent feature settings and select URL-based sampling.
Use cases examples
- Select Add URL.
- From Importance of a specific URL, select Reduce by 4x the capturing value.
- Type the URL path
/_healthz
. - From Path comparison condition, select Starts with.
- Turn on Any HTTP method.
- Go to the process group and select More (…) > Process group settings > URL-based sampling.
- Select Add URL.
- Turn on Ignore a specific URL.
- Type the URL path
- Turn off Any HTTP method.
- From the HTTP method list, turn on OPTIONS.
- optional Create a new rule for each process group that you want to target.
