Log Monitoring default limits (Logs Classic)
Log Monitoring Classic
The following page lists default limits for the latest version of Dynatrace Log Monitoring.
The below limitations apply to both log file ingestion and generic log ingestion via API:
Log events per minute
Log data ingestion is limited by default to 10,000 log events per minute per cluster.
If your log data stream within your cluster exceeds the limit, all log events above the limit are ignored.
If you increase resources (RAM) in your nodes, you can increase the limit based on the cluster resources size using an API call or Cluster Management Console (CMC).
This applies to all event sources (OneAgent and generic log ingestion). You can use self-monitoring metrics to get a count of incoming log events and log events rejected because this limit was exceeded. For details, see Self-monitoring metrics.
Refresh cluster limit using the API call
See Update log events per cluster for Log Monitoring.
Refresh cluster limit using Cluster Management Console (CMC)
- In the CMC, select Environments and the environment for which you wish to update the total log events per cluster.
- On the environment details page, in the Cluster overload prevention settings section, select the Refresh cluster limit.
