Unregister Managed cluster
This API call allows to release a license from a cluster in order to reuse it:
Endpoint
/public/v2.0/oauth/unregistration
Parameter
Parameter | Type | Description | In | Required |
clusterUuid | string | - | path | required |
Response
Response codes
Code | Description |
200 | Ok |
404 | Cluster with given UUID does not exist |
Example
In this example, you unregister a cluster with identifier 0a00a0a0-00aa-00a-a0a0-00aaa0aa0000
from its license. When this call is successful (with response code 200
), you can reuse this license for a different cluster.
Curl
curl -X PUT "https://mcsvc.dynatrace.com/rest/public/v2.0/unregistration/0a00a0a0-00aa-00a-a0a0-00aaa0aa0000" -H "accept: */*" -H "Authorization: Basic MMiiLLL0c0AthpM0YERwdXI0bEZ5b1IzGGt0AQ"
Request URL
Response body
Response does not have a body.
Response code
200
