This API call generates a token that allows you to execute update package download URLs.
/public/v1.0/oauth/api-token
| Parameter | Type | Description | In | Required |
| body | Token | - | body | optional |
TokenGrantCredentialsDto object| Element | Type | Description | Required |
| clientId | string | - | optional |
| clientSecret | string | - | optional |
| scope | string | - | optional |
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
{"clientId": "string","clientSecret": "string","scope": "string"}
| Code | Description |
| 200 | Token generated successfully |
| 401 | Invalid credentials |
| 404 | Cluster not found |
In this example, you generate a token execute following REST call:
curl -X POST "https://mcsvc.dynatrace.com/rest/public/v1.0/oauth/api-token"-H "accept: application/json"-H "Content-Type: application/json"-d "{ \"clientId\": \"dt0s04.AAAAAAAA\", \"clientSecret\": \"dt0s04.AAAAAAAA.AAAA00AAAAAAAAAA0OBA6AVNCQVQAGSO25VM5KDFBIKEZ7HVG6THKTHGWAY5ACCL\", \"scope\": \"sso20-managed-cluster-offline-bundle\"}"
{"token": "aaA0aAAaAaAAA0AaAAAaaAaaAaAAAaA0AaA0.eyJzdWIiOiJjbHVzdGVyLTBhMDBhMGEwLTkyZWMtMTFlNy1iMWU2LTEyZmJkMWZiMzczMkBkeW5hdHJhY2UtbWFuYWdlZC5jb20iLCJhdWQiOiJkdDBzMDQuTFFWT1FQQVMiLCJ1aWQiOiI5N2Y0OGFhMy1jYmRiLTRkMzEtOGE2YS02NjUyNTQxMzY5MTIiLCJzY29wZSI6InNzbzIwLW1hbmFnZWQtY2x1c3Rlci1vZmZsaW5lLWJ1bmRsZSIsImlzcyI6Imh0dHBzOi8vc3NvLXNwcmludC5keW5hdHJhY2VsYWJzLmNvbTo0NDMiLCJleHAiOjE2MTU0NzcxNTIsImdyYW50VHlwZSI6ImNsaWVudF9jcmVkZW50aWFscyIsImlhdCI6MTYxNTQ2OTk1Mn0.svn34bJEZbziHVyV7cKW9OWwvBwakzH0Ke_Iu19GV743zrC4zHuX4YQFts-JkEHRYmnVvnQRwPPCakuq0LHVjA","scopes": ["sso20-managed-cluster-offline-bundle"],"expiresAt": 1615477153001}
200
