Generate SSO client credentials
  • Published Mar 12, 2021
This API call generates an OAuth API client.
You can create up to 100 OAuth API clients per account. We recommend that you reuse once created OAuth API client.
Endpoint
/public/v1.0/oauth/registration/withLicenseKey
Parameter
ParameterTypeDescriptionInRequired
clientTypestring-queryoptional
Response
Response codes
CodeTypeDescription
200ClientCredentialsDto
Cluster credentials generated successfully
401-
Invalid cluster credentials
Response body objects
The ClientCredentialsDto object
ElementTypeDescription
clientIdstring-
clientSecretstring-
scopesstring[]-
Response body JSON model
"clientId": "string",
"clientSecret": "string",
"scopes": [
"string"
Example
In this example, you generate an OAuth API client execute following REST call.
where :
  • <cluster-identifier> is a cluster identifier (in Dynatrace, go to Licensing). For example, 0a00a0a0-92ec-11e7-b1e6-12fbd1fb3732
  • <license-key> is a license key provided to you in welcome email and visible in Licensing. For example, 0a0aAAAA0jeUv6N.
Curl
curl -X POST "https://mcsvc.dynatrace.com/rest/public/v1.0/oauth/registration/withLicenseKey"
-H "accept: application/json"
-u "<cluster-identifier>:<license-key>"
Request URL
Response body
"clientId": "dt0s04.AAAAAAAA",
"clientSecret": "dt0s04.AAAAAAAA.AAAA00AAAAAAAAAA0OBA6AVNCQVQAGSO25VM5KDFBIKEZ7HVG6THKTHGWAY5ACCL",
"scopes": [
"sso20-managed-cluster-offline-bundle",
"sso20-identity-linking"
Response code
200
