Review the operating system requirements before installing Dynatrace Managed.
Dynatrace Managed requires a dedicated host. The host must not run other services that consume significant central processing unit or memory resources, or that use ports required by Dynatrace Managed.
Dynatrace Managed runs on a 64-bit Linux distribution (see supported distributions below). It supports installation on physical and virtualized hosts but not in containers.
Dynatrace Managed requires a fixed IPv4 address. It supports only IPv4 address spaces.
Configure your firewall settings before installation.
The libraries installed with Dynatrace Managed are locale-aware. Set the system locale to an English option, for example LANG=en_US.UTF-8, to ensure correct display of text and symbols.
| Linux distribution | Versions | CPU architectures |
| Amazon Linux | 2, 20231 | x86-64 |
| Debian | 11, 12 | x86-64 |
| Oracle Linux | 8.8, 8.10, 9.2, 9.4, 9.7, 9.8, 10.11, 10.21 | x86-64 |
| Red Hat Enterprise Linux | 8.10, 9.6, 9.8, 10.01, 10.21 | x86-64 |
| Rocky Linux | 9.2, 9.4, 9.7, 9.8, 10.01, 10.1, 10.21 | x86-64 |
| SUSE Enterprise Linux | 12.5, 15.4, 15.5, 15.6, 15.7 | x86-64 |
| Ubuntu | 18.04, 20.04, 22.04, 24.04, 26.04 | x86-64 |
