Deploy OneAgent on Mesos/Marathon
  • 2-min read
  • Published May 21, 2020
Mesos is a generic cluster resource manager which can be used together with the Marathon framework to run containers in distributed environments.
To monitor applications running in Mesos clusters, we recommend that you deploy OneAgent on all Mesos agent nodes by means of a Marathon application deployment. Following this, install OneAgent on the Mesos primary nodes, as explained on this page.
Locate your OneAgent installer URL
The first step is to obtain the location for ONEAGENT_INSTALLER_SCRIPT_URL. This information is presented to you during OneAgent installation.
To get your ONEAGENT_INSTALLER_SCRIPT_URL
  1. Go to Deploy Dynatrace.
  2. Select Start installation > Linux.
  3. Determine the installer script URL and token from the UI-provided wget command:
This is the URL:
OneAgent URL
OneAgent URL
  • Replace the value of arch parameter with <arch>. Ignore the flavor=default parameter.
  • For the API-Token value, you need a PaaS token.
Your URL should look like this: https://host.domain.com/api/v1/deployment/installer/agent/unix/default/latest?arch=<arch>
This is your ONEAGENT_INSTALLER_SCRIPT_URL.
This your URL and API token.
OneAgent installation page with URL to be modified
Append the API token to the URL using the API-Token parameter. Your URL should look like this:
https://host.domain.com/api/v1/deployment/installer/agent/unix/default/latest?arch=x86&flavor=default&Api-Token=<token>
Install OneAgent
  1. Deploy OneAgent on Mesos agent nodes.
    If you're using DC/OS to manage your Mesos cluster, you can take advantage of the Dynatrace package in the DC/OS universe. The universe package will automatically deploy Dynatrace to all your Mesos agent nodes.
    If you're not using DC/OS, you can run OneAgent as a Marathon application by following this example.
    • Use the cat command to create the dynatrace-oneagent.json file. Before you run it, edit the JSON part from the example below and replace the two placeholders with your Mesos cluster specific data:
      • REPLACE_WITH_YOUR_URL is the location for ONEAGENT_INSTALLER_SCRIPT_URL you determined earlier.
      • REPLACE_WITH_NUMBER_OF_NODES is the integer representing the number of nodes in your Mesos cluster.
    cat <<- EOF > dynatrace-oneagent.json
    "id": "dynatrace-oneagent",
    "cpus": 0.1,
    "mem": 256,
    "instances": REPLACE_WITH_NUMBER_OF_NODES,
    "constraints": [["hostname", "UNIQUE"], ["hostname", "GROUP_BY"]],
    "container": {
    "type": "DOCKER",
    "volumes": [
    "containerPath": "/mnt/root",
    "hostPath": "/",
    "mode": "RW"
    "docker": {
    "image": "dynatrace/oneagent",
    "forcePullImage": true,
    "network": "HOST",
    "privileged": true,
    "parameters": [
    { "key": "pid", "value": "host" },
    { "key": "ipc", "value": "host" },
    { "key": "env", "value": "ONEAGENT_INSTALLER_SCRIPT_URL=REPLACE_WITH_YOUR_URL" },
    { "key": "env", "value": "ONEAGENT_INSTALLER_SKIP_CERT_CHECK=false "}
    "args": [
    EOF
    After you created the dynatrace-oneagent.json file, send an HTTP POST request to the Mesos primary leader to deploy the Marathon application with OneAgent.
    curl -X POST -H "Content-Type: application/json" http://your-mesos-master:8080/v2/apps -d@dynatrace-oneagent.json
  2. Deploy OneAgent on Mesos primary nodes.
    Marathon doesn't allow you to deploy applications to primary nodes (except for nodes that are tagged as both primary and agent). This is why you must manually install OneAgent on all Mesos primary nodes that aren't additionally configured as Mesos agents. For this, use the default Linux installer.
Related topics
  • OneAgent platform and capability support matrix
