Dynatrace automatically captures all OpenTracing and OpenTelemetry spans, but you can control and adapt how OpenTelemetry and OpenTracing spans are combined with OneAgent data into PurePath® distributed traces.
The span settings are available at Settings > Server-side service monitoring. You can define rules to:
For details, see the sections that follow.
The OneAgent code module's OpenTelemetry Span Sensor automatically captures all OpenTelemetry attributes. If you want to prevent the accidental storage of personal data, you can exclude specific attribute keys for which the values must not be persisted. By omitting attributes containing personal data, you can meet your organization's privacy requirements and control the scope of stored monitoring data.
To configure attribute storage and masking settings for your environment
Go to Settings > Preferences > OneAgent network modules & integrations.
Select Server-side service monitoring > Attribute capturing.
optional To change the default OpenTelemetry attribute persistence, go to Preferences.
Only one setting preference is possible.
Add an attribute name to the attribute list.
Allowed attributes list Dynatrace recommends a few basic attributes to generally be included, such as service.name or service.version. For ease of use, Dynatrace comes with a default configuration that can be adjusted.
Perform the following actions to mask a stored attribute value.
You can then find the attribute key on the Distributed traces page on the Summary tab.
All detected OpenTelemetry and OpenTracing spans are captured by default. This means that every detected span is added to distributed traces. This gives code-level visibility along with span attributes, even for technologies not supported by OneAgent out of the box.
You can create request attributes based on spans to segment the distributed traces.
We recommend that you exclude spans for technologies supported out of the box by OneAgent for Java and Go.
To control your span capturing
Go to Settings > Server-side service monitoring > Span capturing.
Select Add item.
Enter a Rule name.
In the Rule action list, decide whether you want to Ignore or Capture spans matching the criteria you're about to define.
Select Add item.
You can control span capturing based on the value of the following sources:
OpenTelemetryserverSelect the Comparison type—for example, Contains or Equals.
Enter the value for the source you specified earlier.
By default, the search for key and value is not case sensitive. Turn on Case sensitive if you want your rule to consider key and value case.
Select Save changes.
By default:
server and consumer start new distributed traces automatically. This means that all OneAgent sensors contribute to that distributed trace and a default service is created for the distributed trace.client, internal, and producer don't start new distributed trace automatically.You can choose to start distributed traces based on client, internal, and producer span kinds, and to opt out for server and consumer span kinds, based on various span details.
To control your span entry points
OpenTelemetryserverContext propagation enables you to connect distributed traces through OpenTelemetry/OpenTracing. You can connect distributed traces through any protocol and propagate the inject and extract usage to the Dynatrace PurePath® distributed traces context.
To reduce the risk of context propagation conflicts with built-in sensors, context propagation is disabled by default and is limited to spans matching the criteria of your choice.
To define rules to enable context propagation for specific spans
OpenTelemetryserver
