OneAgent file aging mechanism
  • 6-min read
OneAgent in the installer-based deployment uses a built-in aging mechanism that makes sure the OneAgent files are kept within a reasonable size.
Aging mechanism is not used in the application-only mode.
Optimal OneAgent disk usage is determined based on the following limits:
  • The minimum required space is 200 MB * 3 = 600 MB (logs, alerts, crash reports).
  • The default required space is 1 GB * 3 = 3 GB (logs, alerts, crash reports).
The two type of files that contribute most to OneAgent disk space usage during its operation are OneAgent log files and runtime data such as crash and memory dumps.
Log files
The maximum disk space occupied by OneAgent log files is very well managed by the OneAgent aging mechanism. Logs grow in size slowly and steadily. A continuous cleanup process that runs every minute keeps the log size within reasonable constraints. We designed the log aging mechanism with inside knowledge on how OneAgent-related events are logged, so log file aging doesn't require additional configuration.
Runtime data
Unlike log files, large runtime data files such as crash and memory dumps are generated ad hoc and can cause rapid spikes in disk usage. To mitigate this, use the DATA_STORAGE installation parameter to specify a custom directory for large runtime data. Locate the custom directory on a resource where tight disk size constraints are not as critical as they are on the disk where OneAgent is installed.
For more information on customizing OneAgent installation, see the OS-specific help: Linux, Windows, or AIX.
Emergency cleanup
In an emergency situation, when free disk space reaches 3% threshold, OneAgent cleans all the files from directories managed by the aging mechanism except the latest installer logs and OneAgent OS module log
OneAgent aging mechanism rules
The OneAgent aging mechanism ensures that the disk space used by OneAgent is constantly within predefined limits. To do that, a number of rules are applied to OneAgent directories. If necessary, you can contact a Dynatrace product expert via live chat to modify some of the aging rules.
Log directory
  • Linux/AIX /var/log/dynatrace/oneagent
  • Windows %PROGRAMDATA%\dynatrace\oneagent\log
The file aging mechanism checks the files and subdirectories in the main log directory and removes the oldest files when:
  • The total directory size is above 1 GB
  • Any file in this directory is older than 14 days
Files are removed from any subdirectory that contains more than 1000 files (newest files are preserved; oldest files are removed).
There are additional rules for subdirectories:
  • {log-dir}/process
    Files are removed when any of these conditions are true:
    • The files in this directory use more than 300 MB in total
  • {log-dir}/installer
    • The files in this directory use more than 30 MB in total
    • Any file in this directory is older than 180 days On Windows, the driver.log file is preserved.
  • {log-dir}/dumpproc
    • The files in this directory use more than 100 MB in total
Data storage directory
  • Linux/AIX /var/lib/dynatrace/oneagent/datastorage
  • Windows %PROGRAMDATA%\dynatrace\oneagent\datastorage
  • {data_storage_dir}/supportalerts
    • This directory contains more than 10 files
    • The files in this directory use more than 1 GB in total
    • Any of the files in this directory is older than 7 days
  • {data_storage_dir}/memorydump
    • Any of the files in this directory is older than 2 hours
    • The files in this directory use more than 20 GB in total
  • {data_storage_dir}/crashreports
    • They have already been reported to Dynatrace
    • This directory contains more than 100 files
    • Any of the files in this directory is older than 3 days
Runtime directory
  • Linux/AIX /var/lib/dynatrace/oneagent/agent/runtime
  • Windows %PROGRAMDATA%\dynatrace\oneagent\agent\runtime
The OneAgent file aging mechanism checks the subdirectories starting with 0x. Checks are performed recursively.
  • If the 0x* directory contains a dump subdirectory and all the files in it are older than 3 days, then the dump subdirectory is removed.
  • If all the files and directories in the 0x* directory are older than 7 days, the whole directory is removed.
  • If the size of all files in the runtime directory exceeds 1GB, the 0x* directories are removed, starting with the oldest, until the runtime directory size is below 1GB.
  • This directory is also fully cleaned up during OneAgent update.
Installation bin directory
  • Linux/AIX /opt/dynatrace/oneagent/agent/bin
  • Windows %PROGRAMFILES%\dynatrace\oneagent\agent\bin
  • {install-dir}/agent/bin
    OneAgent deploys a number of file artifacts during the update process, specifically in cases of injectable technology modules. All injectable module files are stored in versioned folders. When OneAgent is active, it performs file cleanup according to the following criteria:
    • The currently used version is always preserved.
    • OneAgent scans all the monitored processes and determines which libraries are used.
    • The library list is compared to the contents of the bin directory. Unused binaries from the 32-bit and 64-bit directories are removed, regardless of whether Host monitoring is enabled or disabled. For binaries in the any directory, cleanup occurs only if Host monitoring is enabled. The OneAgent aging mechanism retains the current version and the 10 most recent previous versions, keeping a total of 11 versions.
Starting with OneAgent version 1.347 file aging for the installation bin directory doesn't work when both autoupdate and automatic injection are disabled at the same time.
Aging mechanism for OneAgent in application-only monitoring mode
If you don't have access to the infrastructure layer, Dynatrace also provides the option of application-only monitoring for Kubernetes, OpenShift, CloudFoundry or SAP Business Technology Platform.
The aging mechanism in application-only monitoring mode manages the logs of the OneAgent modules. All of them are located in the respective subdirectories of the default OneAgent log directory:
Log rotation
Each OneAgent module limits its number of logs to 5. Each of these 5 files is limited to 10 MB.
Log aging
OneAgent purges the log files at startup when:
  • A log file is older than 14 days
  • The combined size of all log files exceeds 300 MB
  • There are more than 1,000 log files
To prevent unnecessary delays in your application's startup, the OneAgent bulk purge limit is set to delete a maximum of 50 of the oldest files.
