ActiveGate group
  • 2-min read
You can use ActiveGate groups to perform bulk actions on your ActiveGates, such as managing Extensions running on ActiveGates or connecting your Cloud Foundry foundations.
Requirements
  • The name of an ActiveGate group is a string of alphanumeric characters, hyphens (-), underscores (_), and dots (.).
  • Dots are used as separators, so you must not use a dot as the first character of a group name.
  • The length of the string is limited to 256 characters.
Assign ActiveGate to a group
An ActiveGate can belong to only one group. By default, an ActiveGate is assigned to the default group. You can assign an ActiveGate to a group during or after installation.
Assign to a group during installation
To assign an ActiveGate to a group, you can use the --set-group installation parameter during installation. Note that you can't use this parameter during an ActiveGate update. For example:
/bin/bash Dynatrace-ActiveGate-Linux-x86-<version>.sh --set-group=my-group
Dynatrace-ActiveGate-Windows-x86-<version>.exe --set-group=my-group
Assign to a group after installation
To assign ActiveGates to a group, you can use Remote configuration management (select the modify ActiveGate group action).
Alternatively, you can assign an ActiveGate to a group using agctl or by editing the custom.properties file:
ActiveGate version 1.333+
agctl group set mygroup
After assigning the ActiveGate to a group with agctl, you need to restart ActiveGate for the changes to take effect.
  1. Edit the custom.properties file in the ActiveGate configuration directory and configure the group parameter in the [collector] section. For example:
    [collector]
    group = mygroup
    For more information, see Basic rules for working with ActiveGate configuration.
  2. Save the custom.properties file and restart the ActiveGate main service.
Extensions
An ActiveGate running a remote extension needs to belong to an ActiveGate group because Dynatrace uses a group to instruct the extension where it should run. If you plan to use a single ActiveGate to run a remote extension, assign it to a dedicated group containing only that ActiveGate.
When activating the extension, you need to specify an ActiveGate group that will run your extension. You can select an ActiveGate group either during the Dynatrace Hub-based activation workflow, or specify an ActiveGate group name in the JSON payload used to activate the extension using the Dynatrace API.
When connecting Dynatrace to Cloud Foundry foundations, you specify an ActiveGate group responsible for querying Cloud Foundry for data. For more information, see Connect your Cloud Foundry foundations with Dynatrace
