ActiveGate FIPS compliance (Dynatrace Classic)
ActiveGate version 1.315+
What is FIPS?
The Federal Information Processing Standard (FIPS) is "a standard for adoption and use by federal departments and agencies that has been developed within the Information Technology Laboratory and published by NIST, a part of the U.S. Department of Commerce. A FIPS covers some topic in information technology to achieve a common level of quality or some level of interoperability" (source: NIST glossary).
FIPS compliance means that a product adheres to all security requirements imposed by the standard.
ActiveGate FIPS-compliant mode
ActiveGate deployed in FIPS-compliant mode uses FIPS-certified cryptographic libraries:
  • Amazon Corretto Crypto Provider 2.4.1 (which uses AWS-LC-FIPS 2.x as its cryptographic module; for details, see Certificate #4816)
  • BouncyCastle 2.1.2 (for details, see Certificate #4943)
  • BouncyCastle 2.0.0 (for details, see Certificate #4743)
ActiveGate purposes compatibility
Purposex86-64arm64
Routing-monitoring
Applicable
Applicable1
Synthetic monitoring in a private location
Applicable2
Not applicable
z/OS monitoring
Applicable
Not applicable
1
excluding Extension Execution Controller module (same as regular, non-FIPS ActiveGate).
2
refer to Requirements and limitations for Synthetic FIPS compliance.
Host-based ActiveGate deployment
FIPS-compliant mode can be enabled during ActiveGate installation. For details, see Customize ActiveGate installation on Linux.
Requirements
  • Linux x86-64 or ARM64 (AArch64)
  • Operating system with FIPS-compliant mode enabled
    • The ActiveGate installer verifies the configuration of the operating system by checking whether the FIPS-compliant mode status stored in /proc/sys/crypto/fips_enabled evaluates to value of 1
    • If the ActiveGate installer is started in FIPS-compliant mode while the operating system does not have FIPS-compliant mode enabled, the installer stops and exits with an error
Containerized ActiveGate deployment
Containerized ActiveGate deployments rely on FIPS-compliant images, which are available for the following architectures:
  • x86-64
  • ARM64 (AArch64)
Container registries
FIPS-compliant ActiveGate images are available in our supported public registries with the image tag suffix -fips.
Example: public.ecr.aws/dynatrace/dynatrace-activegate:1.315.70.20241127-162512-fips
See Configure DynaKube to use images from public registry for details on how to instruct Dynatrace Operator to use images from the public registry.
Verification of FIPS-compliant mode
Web UI
Dynatrace version 1.317+
To check whether an ActiveGate is running in FIPS-compliant mode
  1. Go to Deployment Status > ActiveGates.
  2. Find the ActiveGate of interest and expand the table row.
  3. Search for the FIPS mode property.
    • If you find FIPS mode with a value of True, the ActiveGate is in FIPS-compliant mode.
    • If you don't find FIPS mode at all, the ActiveGate isn't in FIPS-compliant mode.
To list all ActiveGates running in FIPS-compliant mode
  2. In the filter bar, select the FIPS mode filter and then select True.
REST API
To use the Dynatrace API to check whether a specific ActiveGate is running in FIPS-compliant mode, use GET an ActiveGate to check the value of the fipsMode field.
To use the Dynatrace API to list all ActiveGates running in FIPS-compliant mode, use GET all ActiveGates with the fipsMode query parameter.
Logs
To verify whether ActiveGate is running in FIPS-compliant mode, look up the following entry in the ActiveGate logs (see below how to access logs depending on the ActiveGate deployment type):
2025-06-10 12:16:14 UTC INFO [<tenant>] [FipsDetector] FIPS mode active: true
When FIPS mode active is true, all libraries and configuration related to FIPS compliance are properly initialized and ActiveGate is running in FIPS-compliant mode.
If ActiveGate was installed in FIPS-compliant mode or a FIPS-compliant image was used, but the initialization of FIPS libraries fails or required configuration is missing, ActiveGate cancels its startup and writes the following entries to the log file:
ActiveGate FIPS mode initialization failed
Additionally, a log line describes the specific reason causing the initialization failure.
Accessing logs in host-based deployment
ActiveGate log files have the pattern dynatracegateway.0.<number>.log and can be found in the ActiveGate logs directory (see ActiveGate directories).
Accessing logs in containerized deployment
Logs from containerized ActiveGates can be retrieved using the following command: kubectl -n <NAMESPACE> logs statefulset.apps/<DYNAKUBE_NAME>-activegate In case there are multiple replicas configured, logs from a single pod will be returned.
To get logs from a specific pod, use the following command: kubectl -n <NAMESPACE> logs pod/<DYNAKUBE_NAME>-activegate-<REPLICA_NUMBER>
Supported cipher suites
Cipher suiteTLS version
TLS_AES_256_GCM_SHA384
TLS1.3
TLS_AES_128_GCM_SHA256
TLS1.3
TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
TLS1.2, TLS1.3
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
TLS1.2, TLS1.3
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
TLS1.2, TLS1.3
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
TLS1.2, TLS1.3
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
TLS1.2, TLS1.3
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
TLS1.2, TLS1.3
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
TLS1.2, TLS1.3
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
TLS1.2, TLS1.3
