Monitor AWS Fargate
  • How-to guide
  • 1-min read
To monitor your AWS Fargate workloads, deploy Dynatrace OneAgent as described below.
Prerequisites
  • Create an API token in your Dynatrace environment and enable the following permissions:
    • Access problem and event feed, metrics, and topology (API v1)
    • PaaS integration - Installer download
  • Review the list of supported applications and versions.
Runtime integration
These instructions describe how to integrate Dynatrace OneAgent code modules into your Fargate tasks using an initContainer. The initContainer copies the OneAgent artifacts into a shared ephemeral volume, where environment variables then configure and activate OneAgent.
Dynatrace provides OneAgent code module images on public registries, such as the following:
  • Dynatrace Code Modules Image Tags.
An image can then be used for container services that support initContainers. The dynatrace-codemodules image contains the OneAgent artifacts and a small CLI, the dynatrace-bootstrapper, that is executed at startup to copy the artifacts into a volume shared with the application container.
Select an image
The following image tag formats are available:
  • Immutable tags — contain code modules of a specific release, for example, 1.327.51.20251205-162230
  • Rolling tags (major.minor) — for example, 1.327
  • Technology-specific images — available with both immutable and rolling tags, for example, 1.327-java, 1.327-dotnet
Rolling tags (for example, 1.333) receive patch updates automatically when a container restarts. New tasks pick up the latest patch version without task definition changes. Use rolling tags when automatic hot-fix delivery is the priority.
Immutable tags (for example, 1.333.17.20250601-120000) pin tasks to a specific version, giving you deterministic deployments and a clear rollback path. Use immutable tags when strict version control or compliance requirements apply.
Technology-specific images (for example, 1.333-java, 1.333-dotnet) contain only the code modules for a single runtime, resulting in a smaller image and faster pull and startup times. Avoid technology-specific images if your container runs multiple runtimes that need to be instrumented simultaneously, for example, PHP served behind NGINX.
Store credentials securely
Store Dynatrace credentials as secrets and reference them in the secrets field of your task definition. Use whichever secrets solution fits your setup, for example, AWS Secrets Manager.
Configure the task definition
Create a task definition file (for example, task-definition.json) with the following structure. The initoneagent container runs first, copies OneAgent artifacts into a shared ephemeral volume, and exits. Your application container then starts and loads OneAgent via LD_PRELOAD.
Replace <your-application-image>, <your-account-id>, <your-region>, and <your-secret-name> with your own values.
"family": "<your-task-family>",
"requiresCompatibilities": ["FARGATE"],
"networkMode": "awsvpc",
"cpu": "256",
"memory": "512",
"taskRoleArn": "arn:aws:iam::<your-account-id>:role/<your-task-role>",
"executionRoleArn": "arn:aws:iam::<your-account-id>:role/<your-task-execution-role>",
"containerDefinitions": [
"name": "initoneagent",
"image": "public.ecr.aws/dynatrace/dynatrace-codemodules:1.333",
"essential": false,
"user": "0:0",
"command": [
"--source=/opt/dynatrace/oneagent",
"--target=/mnt/dynatrace/oneagent",
"--technology=<your-technology>"
"environment": [
{ "name": "DT_ONEAGENT_OPTIONS", "value": "flavor=default&include=all" }
"secrets": [
"name": "DT_API_URL",
"valueFrom": "arn:aws:secretsmanager:<your-region>:<your-account-id>:secret:<your-secret-name>:DT_API_URL::"
"name": "DT_PAAS_TOKEN",
"valueFrom": "arn:aws:secretsmanager:<your-region>:<your-account-id>:secret:<your-secret-name>:DT_PAAS_TOKEN::"
"mountPoints": [
"sourceVolume": "oneagent",
"containerPath": "/mnt",
"readOnly": false
"logConfiguration": {
"logDriver": "awslogs",
"options": {
"awslogs-group": "<your-log-group>",
"awslogs-region": "<your-region>",
"awslogs-stream-prefix": "ecs"
"name": "<your-application-container>",
"image": "<your-application-image>",
"essential": true,
"linuxParameters": {
"initProcessEnabled": true
"environment": [
{ "name": "LD_PRELOAD", "value": "/mnt/dynatrace/oneagent/agent/lib64/liboneagentproc.so" }
"secrets": [
"name": "DT_TENANT",
"valueFrom": "arn:aws:secretsmanager:<your-region>:<your-account-id>:secret:<your-secret-name>:DT_TENANT::"
"name": "DT_TENANTTOKEN",
"valueFrom": "arn:aws:secretsmanager:<your-region>:<your-account-id>:secret:<your-secret-name>:DT_TENANTTOKEN::"
"name": "DT_CONNECTION_POINT",
"valueFrom": "arn:aws:secretsmanager:<your-region>:<your-account-id>:secret:<your-secret-name>:DT_CONNECTION_POINT::"
"mountPoints": [
"readOnly": false
"dependsOn": [
"containerName": "initoneagent",
"condition": "COMPLETE"
"options": {
"volumes": [
"name": "oneagent",
"host": {}
Replace <your-technology> with your application runtime (valid values: python, java, dotnet, nodejs, php, go, apache, nginx, all).
  1. Register the task definition:
    aws ecs register-task-definition --cli-input-json file://task-definition.json
  2. Update your ECS service to use the new revision:
    aws ecs update-service \
    --cluster <your-cluster-name> \
    --service <your-service-name> \
    --task-definition <your-task-family>
Alternative integration paths
  • EKS on Fargate — you can run on Amazon EKS with the Fargate launch type using application-only injection with Dynatrace Operator. See Install on EKS Fargate.
  • Container build-time injection — to embed OneAgent into your container image at build time using Docker multi-stage builds, see Set up OneAgent on containers for application-only monitoring.
Optional configuration
After you integrate OneAgent, you can customize its behavior by adding environment variables to your application container.
Route OneAgent logs to stdout
To route OneAgent diagnostic logs to stdout alongside your application logs, add the following environment variables to your application container:
  • DT_LOGSTREAM=stdout — routes OneAgent diagnostic output to standard output
  • DT_LOGLEVELCON=INFO — sets the log verbosity level
When you configure the awslogs log driver on your containers (as shown in the task definition example), CloudWatch Logs captures both application and OneAgent diagnostic logs in a single stream.
Configure network zones
You can configure network zones as an environment variable:
  • DT_NETWORK_ZONE: equals your.network.zone
See network zones for more information.
Monitor consumption
Monitoring consumption depends on your licensing model:
  • Dynatrace Platform Subscription (DPS): Consumption is billed in GiB-hours, see Calculate your consumption of Full-Stack Monitoring.
  • Dynatrace classic licensing: Consumption is billed in host units, see Application and Infrastructure Monitoring (Host Units).
Troubleshooting
For OneAgent integration issues, see Application image OneAgent integration problems.
Related topics
  • OneAgent platform and capability support matrix
Related tags
Infrastructure ObservabilityAWS
