Monitor AWS Lambda (Dynatrace Classic)
  • Explanation
  • 3-min read
Dynatrace provides end-to-end observability for AWS Lambda functions through distributed tracing, log correlation, and AI-powered insights using auto-instrumentation without code changes. The OneAgent AWS Lambda extension collects logs directly from Lambda functions, offering an alternative to CloudWatch via Firehose with lower cost, lower latency, and easier setup.
Trace Lambda functions (Dynatrace Classic)
Monitor AWS Lambda functions.
  • How-to guide
Read this guide
Collect logs from AWS Lambda functions (Dynatrace Classic)
Collect logs from AWS Lambda functions using the Dynatrace Lambda extension, a lower-latency and lower-cost alternative to the CloudWatch log forwarder.
  • How-to guide
Read this guide
Monitor AWS Lambda (built-in)
Monitor AWS Lambda (built-in) and view available metrics.
  • How-to guide
Read this guide
Integrate Dynatrace Lambda Layer on container images (Dynatrace Classic)
Deploy Dynatrace Lambda Layers when deployed via a container image.
  • How-to guide
Read this guide
Integrations
AWS Lambda instrumentation is available for the following runtimes:
RuntimeLambda layer version1Applies to Lambda Classic
Python
1.321 (or later)
Yes
Node.js
1.319 (or later)
Yes
Java
1.319 (or later)
Yes
.NET
1.335 (or later)
Yes
Go
1.333 (or later)
Log Monitoring only
1
Managed offline clusters are not supported.
For more details, see Technology support.
Monitoring consumption
For AWS Lambda, monitoring consumption is based on Davis data units. See Serverless monitoring for details.
Related tags
Infrastructure ObservabilityAWS
