Static thresholds for infrastructure monitoring
  • Explanation
  • 3-min read
  • Published May 20, 2019
  • Deprecated
Deprecation notice
This page is deprecated. Refer to the Host anomaly detection page. All updates and new information will be added there.
Dynatrace infrastructure monitoring is based on numerous built-in, predefined static thresholds. These thresholds relate to resource contentions like CPU spikes, memory, and disk usage. You can change these default thresholds in Settings > Anomaly Detection > Infrastructure.
For applications and services, you can disable automated baselining-based reference-value detection anytime and switch to user-defined static thresholds. If you set a static threshold for response time and error rate on an application or service level, events will be raised if the static threshold is breached. A slowdown event is raised if the static thresholds for either the median or the 90th percentile response times are breached.
Predefined static thresholds for hosts
HostsDefault static threshold
CPU saturation
Alert if CPU usage is higher than 95% in 18 of 30 10-second intervals.
Memory event usage
  • Alert if memory usage is higher than 90% on Windows or 80% on Linux
  • AND memory page fault rate is higher than 100 faults/s on Windows or 20 faults/s on Linux in 18 of 30 10-second intervals.
GC activity
  • Alert if GC time is higher than 40%
  • OR GC suspension is higher than 25% in 18 of 30 10-second intervals.
Java out of memory
Alert if the number of Java out-of-memory exceptions is 1 per minute or higher.
AIX High System Load
OneAgent version 1.261+ Alert if the System Load is higher than the defined threshold for the defined amount of samples. This alert is specific to AIX hosts.
Predefined static thresholds for networks
NetworkDefault static threshold
Number of dropped packets
  • Alert if receive/transmit dropped packet percentage is higher than 10%
  • AND total packets rate is higher than 10 packets/s in 18 of 30 10-second intervals.
Network utilization
Alert if sent/received traffic utilization is higher than 90% in 18 of 30 10-second intervals.
TCP connectivity for process
  • Alert if percentage of new connection failures is higher than 3%
  • AND number of failed connections is higher than 10 connections/min in 18 of 30 10-second intervals.
Retransmission rate
  • Alert if retransmission rate is higher than 10%
  • AND number of retransmitted packets is higher than 10 packets/min in 18 of 30 10-second intervals.
Predefined static thresholds for disks
DiskDefault static threshold
Low disk space
Alert if free disk space is less than 3% in 18 of 30 10-second intervals.
Slow running disks
Alert if disk read time or write time is higher than 200 ms in 18 of 30 10-second intervals.
Inodes number available
Alert if percent of available inodes is less than 5% in 18 of 30 10-second intervals.
As static thresholds don't adapt to changing environments and require too much manual effort, Dynatrace also offers intelligent, automated multi-dimensional baselining, which works out of the box, without manual configuration of thresholds. Most importantly, it adapts automatically to changes in traffic patterns.
Related tags
Dynatrace Platform
