A new Dynatrace Docs experience launches December 9, built for people and AI agents. Existing links will redirect.
Adjust the sensitivity of anomaly detection for database services
How-to guide
5-min read
Dynatrace detects five types of anomalies for database services: response time degradations, increases in failure rate, service load drops, service load spikes, and failed database connects. Each anomaly type is detected independently and triggers its own problems and alerts.
To adjust global configuration of anomaly detection for database services
Go to Settings.
Select Anomaly detection > Database services. Here you can configure detection for each anomaly type.
Response time degradation
This type of anomaly detection observes the response time of your databases and triggers an alert if a metric violates the specified thresholds. Dynatrace can detect degradation based on automatic baselining or fixed thresholds.
Dynatrace evaluates degradation for two categories—all responses and the slowest 10%—and triggers an alert if any response time violates the threshold.
To configure the response time degradation detection
Turn on Detect response time degradation and select automatically from the list.
Set degradation values in the remaining fields. Violation of any criterion triggers an alert.
Optional To avoid over-alerting, define an actions/min rate below which a database should be considered a low load. Databases with lower load rates are excluded from evaluation.
Optional To avoid accidental alerts, define how long a database must stay in abnormal state to trigger an alert.
Turn on Detect response time degradation and select using fixed thresholds from the list.
From the Sensitivity list, select the sensitivity of the threshold:
Low: High statistical confidence is used, so brief violations (for example, due to a surge in load) won't trigger alerts.
Medium: Reasonable statistical confidence is used to not alert on every single violation.
High: No statistical confidence is used. Each violation triggers an alert.
For fixed thresholds, the problem impact includes the fixed threshold and the amount by which the threshold was exceeded.
Failure rate increase
This type of anomaly detection observes the failure rate of your database services and triggers an alert if the rate exceeds the specified thresholds. Dynatrace can detect failure rate increase based on automatic baselining or fixed thresholds.
To configure the increased failure rate detection
Turn on Detect increase in failure rate and select automatically from the list.
Specify the relative % and absolute % values above which alerts should be sent out. Both thresholds must be violated to trigger an alert.
Optional To avoid over-alerting, define an actions/min rate below which a database should be considered a low-load database. Databases with lower load rates are excluded from evaluation.
Turn on Detect increase in failure rate and select using fixed thresholds from the list.
Specify the absolute % value above which alerts should be sent out.
Service load drops
This type of anomaly detection learns the normal behavior of your database service load over a period of 7 days and triggers an alert if the load drops significantly.
To configure the database service drops detection
Turn on Detect service load drops.
Specify the observed load threshold to receive alerts in case of load drops.
Service load spikes
This type of anomaly detection learns the normal behavior of your database service load over a period of 7 days and triggers an alert if the load increases significantly.
To configure the database service spikes detection
Turn on Detect service load spikes.
Specify the observed load threshold to receive alerts in case of load spikes.
Reference period
Davis automatically generates baselines during a recent reference period. The default reference period is the past 7 days.
If monitoring data detected during the reference period is no longer valid—for example, if you've deployed a new version of your application that includes major changes, and you're now receiving a high number of alerts—select Reset to establish a new baseline. Davis will purge the previous reference period and immediately begin collecting data for a new reference period.
Thresholds for a specific database service
As an alternative to defining thresholds globally across your entire environment, you can provide fine-tuned thresholds for individual database services. Database-level thresholds override global thresholds for the database service, while global settings still apply to other databases. You can reverse to globally defined thresholds at any time.
To change threshold settings for a specific database service
Go to Database Services.
Select the database you want to configure.
In the browse menu (…), select Edit.
Select Anomaly detection.
Turn off Use global anomaly detection settings.
Set the database-level thresholds in the same manner as described above for global settings.
Thresholds for a specific database statement
Davis can intelligently analyze highly divergent statements within the same database. Some statements, however, might require some special attention due to their importance to business-critical functionality. You can achieve that via key statements.
To configure threshold for a key statement
Scroll down to the Set thresholds on key requests section and expand the menu of the required key statement.
Turn off Use service or global settings.
Set the statement-level thresholds in the same manner as described above for global settings.
