A new Dynatrace Docs experience launches December 9, built for people and AI agents. Existing links will redirect.
Adjust the sensitivity of anomaly detection for extension events
How-to guide
1-min read
Published Sep 06, 2021
Extensions that you have installed provide various event thresholds that are evaluated by anomaly detection. The particular list depends on the extension.
To configure performance-anomaly thresholds for infrastructure components that are monitored with extensions
Go to Settings > Anomaly detection > Extension events. Here you'll find a list of all the event types that your installed monitoring extensions provide.
Expand the required event to see and configure available thresholds.
