Generate SSO token
This API call generates a token that allows you to execute update package download URLs.
Endpoint
/public/v1.0/oauth/api-token
Parameter
ParameterTypeDescriptionInRequired
bodyTokenGrantCredentialsDto-bodyOptional
Request body objects
The TokenGrantCredentialsDto object
ElementTypeDescriptionRequired
clientIdstring-Optional
clientSecretstring-Optional
scopestring-Optional
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"clientId": "string",
"clientSecret": "string",
"scope": "string"
Response
Response codes
CodeDescription
200
Token generated successfully
401
Invalid credentials
404
Cluster not found
Example
In this example, you generate a token execute following REST call:
Curl
curl -X POST "https://mcsvc.dynatrace.com/rest/public/v1.0/oauth/api-token" \
-H "accept: application/json" \
-H "Content-Type: application/json" \
-d "{ \"clientId\": \"dt0s04.AAAAAAAA\", \"clientSecret\": \"dt0s04.AAAAAAAA.AAAA00AAAAAAAAAA0OBA6AVNCQVQAGSO25VM5KDFBIKEZ7HVG6THKTHGWAY5ACCL\", \"scope\": \"sso20-managed-cluster-offline-bundle\"}"
Request URL
Response body
"token": "aaA0aAAaAaAAA0AaAAAaaAaaAaAAAaA0AaA0.eyJzdWIiOiJjbHVzdGVyLTBhMDBhMGEwLTkyZWMtMTFlNy1iMWU2LTEyZmJkMWZiMzczMkBkeW5hdHJhY2UtbWFuYWdlZC5jb20iLCJhdWQiOiJkdDBzMDQuTFFWT1FQQVMiLCJ1aWQiOiI5N2Y0OGFhMy1jYmRiLTRkMzEtOGE2YS02NjUyNTQxMzY5MTIiLCJzY29wZSI6InNzbzIwLW1hbmFnZWQtY2x1c3Rlci1vZmZsaW5lLWJ1bmRsZSIsImlzcyI6Imh0dHBzOi8vc3NvLXNwcmludC5keW5hdHJhY2VsYWJzLmNvbTo0NDMiLCJleHAiOjE2MTU0NzcxNTIsImdyYW50VHlwZSI6ImNsaWVudF9jcmVkZW50aWFscyIsImlhdCI6MTYxNTQ2OTk1Mn0.svn34bJEZbziHVyV7cKW9OWwvBwakzH0Ke_Iu19GV743zrC4zHuX4YQFts-JkEHRYmnVvnQRwPPCakuq0LHVjA",
"scopes": [
"sso20-managed-cluster-offline-bundle"
"expiresAt": 1615477153001
Response code
200
