Pushes custom data points to Dynatrace.
You can access the ingested datapoints via:
Provided data points must follow the Metrics ingestion protocol. You don't have to register the metric first. After Dynatrace has ingested and processed the data, you can use it just like any other metrics in Dynatrace, such as in charts or metric events. You can also provide metadata for the ingested metric via the Settings API.
You can also push the data points directly from a OneAgent-monitored host to the Extensions Execution Controller (EEC) OneAgent module over a secure channel using the local http://localhost:<port>/metrics/ingest endpoint, which doesn't require token authentication. The default port is 14499. Using this method, the Dynatrace reserved dt.entity.host=<host-ID> dimension is added to each metric.
You can use the dimension dt.process.id=<PID> to add a process group identifier dimension. When the process group identifier is provided, dt.entity.process_group_instance dimension will be added to a given metric. It works on OneAgent metrics ingest only via dynatrace_ingest API.
For more information, see OneAgent metric API.
You can't ingest metrics with key prefix of dt.—these are reserved for usage by Dynatrace.
The request consumes a text/plain payload. The payload is limited to 1 MB.
There's no limit on the number of metrics.
| POST | ManagedDynatrace for Government | https://{your-domain}/e/{your-environment-id}/api/v2/metrics/ingest |
| POST | Environment and Cluster ActiveGate (default port 9999) | https://{your-activegate-domain}:9999/e/{your-environment-id}/api/v2/metrics/ingest |
To execute this request, you need an access token with metrics.ingest scope.
To learn how to obtain and use it, see Personal access tokens.
Required scope: storage:metrics:write (legacy)
To learn how to obtain and use it, see Platform tokens or OAuth clients.
| Parameter | Type | Description | In | Required |
| body | string | Data points, provided in the line protocol. Each line represents a single data point. | body | Required |
RequestBody object| Code | Type | Description |
| 202 | Validation | The provided metric data points are accepted and will be processed in the background. |
| 400 | Validation | Some data points are invalid. Valid data points are accepted and will be processed in the background. |
| 4XX | Error | Client side error. |
| 5XX | Error | Server side error. |
ValidationResponse object| Element | Type | Description |
| error | Metric | - |
| linesInvalid | integer | - |
| linesOk | integer | - |
| warnings | Warnings | - |
MetricIngestError object| Element | Type | Description |
| code | integer | - |
| invalidLines | Invalid | - |
| message | string | - |
InvalidLine object| Element | Type | Description |
| error | string | - |
| line | integer | - |
Warnings object| Element | Type | Description |
| changedMetricKeys | Warning | - |
WarningLine object| Element | Type | Description |
| warning | string | - |
{"error": {"code": 1,"invalidLines": [{"error": "string","line": 1}],"message": "string"},"linesInvalid": 1,"linesOk": 1,"warnings": {"changedMetricKeys": [{"line": 1,"warning": "string"}],"message": "string"}}
With this curl command, you'll ingest the cpu.temperature metric assigned to the HOST-06F288EE2A930951 dimension.
curl -L -X POST 'https://mySampleEnv.live.dynatrace.com/api/v2/metrics/ingest' \-H 'Authorization: Bearer <your-platform-token>' \-H 'Content-Type: text/plain' \--data-raw 'cpu.temperature,dt.entity.host=HOST-06F288EE2A930951,cpu=1 55'
Required scope: openpipeline:metrics:ingest
