Metrics API - DELETE an ingested metric
  • Reference
Deletes the specified ingested metric.
  • You can only delete metrics that have been ingested via the Metrics v2 API.
  • You can't delete a metric if it has data points ingested within the last two hours.
  • Deleted metrics cannot be restored.
DELETEManagedDynatrace for Governmenthttps://{your-domain}/e/{your-environment-id}/api/v2/metrics/{metricKey}
DELETEEnvironment and Cluster ActiveGate (default port 9999)https://{your-activegate-domain}:9999/e/{your-environment-id}/api/v2/metrics/{metricKey}
Authentication
Api-Token:
To execute this request, you need an access token with metrics.write scope.
To learn how to obtain and use it, see Personal access tokens.
Parameters
ParameterTypeDescriptionInRequired
metricKeystring
The key of the required metric.
pathRequired
Response
Response codes
CodeTypeDescription
202-
Success. The deletion of the metric has been triggered.
400-
Failed. The metric has been written within the last two hours.
404-
Failed. The metric cannot be found or the key cannot be parsed.
500-
Failed. The deletion of metric dimensions failed.
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Example
In this example, the request deletes the cpu.temperature metric. The response code of 202 indicates that the deletion has been triggered successfully.
The API token is passed in the Authorization header.
Curl
curl --request DELETE \
--url https://mySampleEnv.live.dynatrace.com/api/v2/metrics/cpu.temperature \
--header 'Authorization: Api-Token dt0c01.abc123.abcdefjhij1234567890'
Request URL
Response code
202
Related topics
  • Extend metric observability
