Stream logs to Dynatrace with Fluent Bit (Logs Classic)
  • Tutorial
  • 3-min read
Log Monitoring Classic
You can send logs to Dynatrace using Fluent Bit. Configure Fluent Bit to send logs to Dynatrace generic ingest API.
Capabilities
  • Fluent Bit is a multiplatform log processor and forwarder that allows you to collect data/logs from different sources, unify and send them to multiple destinations. It is compatible with the Docker and Kubernetes environments.
  • Dynatrace can be configured as the target log management and analytics environment for your data thanks to Fluent Bit's configurable http output.
  • You can use any of Fluent Bit input plugins to get logs and events from your application to Dynatrace.
Configuration
The Fluent Bit http output plugin allows you to forward your logs to the Dynatrace Log ingestion endpoint.
  1. Get a Dynatrace API token with the logs.ingest (Ingest Logs) scope.
  2. Deploy Fluent Bit.
  3. To send logs into the Dynatrace Log ingestion endpoint, configure the http output plugin through the configuration file.
  4. In your main Fluent Bit configuration file, append the Output section with the following parameters:
[OUTPUT]
name http
match *
header Content-Type application/json; charset=utf-8
header Authorization Api-Token {your-API-token-here}
allow_duplicated_headers false
host {your-environment-id}.live.dynatrace.com
Port 443
URI /api/v2/logs/ingest
Format json
json_date_format iso8601
json_date_key timestamp
tls On
tls.verify On
You can place your API token in the header or as GET variable in URI (see example below).
  • If Environment ActiveGate is your choice for an endpoint in local environmentor for Dynatrace Managed, install ActiveGate instance. Go to Deploy Dynatrace, then select Install ActiveGate.
  • Log ingestion API v2 is automatically enabled on ActiveGate.
Example
Fluent Bit is the recommended solution whenever reducing resource consumption is critical. In the below example, you need to ingest your AWS Fargate logs. FireLens enables you to set up Fluent Bit for this ingestion.
Ingest AWS Fargate logs with Fluent Bit
When creating a new task definition using the AWS Management Console, the FireLens integration section makes it easy to add a log router container. Follow the steps below to execute your ingest:
  1. In the AWS Management Console, go to the Firelens integration section.
Final log integration page in AWS Management Console
  1. Pick the built-in Fluent Bit image.
  1. Edit the container in which your app-generating logs are running.
  1. In the Storage and Logging section, select awsfirelens as the log driver.
Set AWS Firelens as a log driver
The settings for the log driver should point to the log ingest API of your SaaS tenant. You need to provide two headers for Fluent Bit: content type and authorization token. As FireLens supports only one header, you can pass the token as part of the URL. Your configuration for AWS FireLens should have the following:
TLS: on
Format: json
Header: Content-Type application/json; charset=utf-8
Host: {your-environment-id}.live.dynatrace.com
Port: 443
URI: /api/v2/logs/ingest?api-token={your-API-token-here}
Allow_Duplicated_Headers": "false"
Json_Date_Format": "iso8601"
Json_Date_Key": "timestamp"
To avoid publishing the token in plaintext, follow the directions from AWS Secrets Manager. Once your application starts publishing logs, you can view them in the Dynatrace UI.
Refer to AWS sample repository for the task definition JSON with Dynatrace configuration.
For more configuration details, see Amazon ECS Developer Guide.
Troubleshooting
Visit Dynatrace Community for troubleshooting guides, as well as see Troubleshooting Log Monitoring (Logs Classic).
  • Troubleshooting logs ingested via Fluent Bit
Related tags
Log AnalyticsLogs Classic
