Dynatrace Operator release notes version 1.7.3
  • Latest Dynatrace
  • Release notes
Release date: January 26, 2026
New features and enhancements
  • When telemetry ingest is enabled, Dynatrace Operator now validates that the Data Ingest token has the required scopes. If any scopes are missing, a DynaKube status condition reports the missing scopes, making it easier to diagnose why telemetry data isn't reaching Dynatrace.
Resolved issues
Handling removed API versions during Dyntrace Operator upgrade
Kubernetes records CRD versions in .status.storedVersions, but doesn’t remove entries when versions are deleted, so old versions accumulate and can block upgrades.
In Dynatrace Operator versions < 1.4, deprecated v1beta1 and v1beta2 were automatically added to .status.storedVersions and never cleaned up. Thus, any cluster that had been running versions before 1.4 is affected. If these versions remain during a future upgrade, CRD installation will fail. This release introduces a two-step solution to ensure smooth upgrades:
  1. Helm hook for CRD cleanup
    During upgrade, a Helm hook starts a Kubernetes Job that erases obsolete API versions from the DynaKube CRD's status.storedVersions field. The job only keeps the latest API version that is available in the Dynatrace Operator version installed before the upgrade. This step ensures a smooth upgrade to the new CRD during the Helm upgrade process. See Dynatrace Operator security for information regarding required permissions.
  2. Dynatrace Operator startup migration
    After the upgrade was successful and the new Dynatrace Operator version 1.7.3 is operational, it migrates all existing DynaKubes to the latest supported API version v1beta5. After the DynaKube migration, the status.storedVersions field in the DynaKube CRD is updated to hold only the latest API version v1beta5 to ensure consistency.
Important notice for clusters that have been running Dynatrace Operator version 1.3 and earlier in the past
Clusters that have previously run Dynatrace Operator version 1.3 and earlier may have obsolete v1beta1 or v1beta2 entries in the DynaKube CRD's .status.storedVersions. These must be removed before upgrading to this release, or the CRD upgrade will fail.
Whether you need to stop at Dynatrace Operator version 1.7.3 first depends on your installation method:
  • Helm-based installation
    • Current version 1.4.0 and later—No action required. The Helm pre-upgrade hook automatically removes obsolete .status.storedVersions entries during the upgrade.
    • Current version 1.3 and earlier—You must upgrade to Dynatrace Operator 1.7.3 before upgrading to the next release.
  • Alternative installation methods (Red Hat OpenShift OperatorHub, OperatorHub.io, Google Marketplace, or plain Kubernetes manifests)
    • Never ran version 1.3 and earlier—No action required.
    • Previously ran version 1.3 and earlier—You must upgrade to Dynatrace Operator 1.7.3 before upgrading to the next release.
Manually remove obsolete entries from .status.storedVersions
Instead of upgrading to version 1.7.3, you can manually remove the obsolete entries from .status.storedVersions:
  1. List the stored versions in the CRD:
    kubectl -n dynatrace get crd dynakubes.dynatrace.com -o jsonpath='{.status.storedVersions}'
  2. Continue only if multiple versions are listed in the output. If only one version is listed, no action is required.
  3. Identify the currently active version:
    storage_version=$(kubectl get customresourcedefinitions dynakubes.dynatrace.com -o jsonpath='{.spec.versions[?(@.storage==true)].name}')
  4. Convert all DynaKubes to the active version:
    kubectl get dynakube -n dynatrace -o yaml | kubectl replace -f -
  5. Remove all previous versions while keeping the active version:
    kubectl patch customresourcedefinitions dynakubes.dynatrace.com --subresource='status' --type='merge' -p "{\"status\":{\"storedVersions\":[\"${storage_version}\"]}}"
Ensuring that .status.storedVersions is clean is crucial to avoid issues with future upgrades.
ArgoCD may display resources that are still using an old API version as "out-of-sync".
Known issues
We have identified the following known issues with Dynatrace Operator versions 1.7.0–1.7.3. For other known issues, see Dynatrace Operator support and known issues.
  • Due to optimization of the injected mounts (combining them under /var/lib/dynatrace), Dynatrace components can no longer be injected with the OneAgent.
  • Classic full-stack and metadata enrichment are not compatible and cannot be used to inject the same application pods.
Removal and deprecation notices
  • The deprecated Dynatrace OneAgent Operator has been removed from the operatorhub.io catalog. Please use our Dynatrace Operator instead.
  • The Helm repository located in dynatrace/helm-charts is deprecated and will stop receiving updates in a future release! If you are still using it, please update the URL to dynatrace/dynatrace-operator or switch to the OCI registry-based approach. Update the Helm repository URL with the following commands:
    helm repo remove dynatrace
    helm repo add dynatrace https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/main/config/helm/repos/stable
  • The following API versions of the DynaKube CustomResourceDefinition have been removed in Dynatrace Operator version 1.7.0:
    • v1beta1
    • v1beta2
  • The following API versions of the DynaKube CustomResourceDefinition are marked for deprecation and will be removed in the specified Dynatrace Operator versions:
    • v1beta3 will be removed with Dynatrace Operator version 1.8
  • To prevent potential disruptions, we strongly advise keeping your DynaKube API version up to date. Once a version is deprecated and removed, updates may become significantly more complex and time-sensitive.
    • More information about the deprecation process of the DynaKube API versions can be found in the migration guide.
  • The DynaKube field .spec.oneagent.(cloudNativeFullStack|classicFullStack|hostMonitoring).autoUpdate is deprecated and should no longer be used. The flag will be removed in a future version of the Dynatrace Operator. Do one of the following:
    • Pin the OneAgent version on your tenant to control all connected Kubernetes clusters at once.
    • Use the .spec.oneagent.(cloudNativeFullStack|classicFullStack|hostMonitoring).version field to pin the version on a per-DynaKube basis.
  • CSI sidecar binaries, located in /usr/local/bin/csi-node-driver-registrar and /usr/local/bin/livenessprobe, are now deprecated and will be removed in a future version of Dynatrace Operator.
  • Support for OpenShift 4.10 and 4.11 ended in March 2025. As a result, Dynatrace Operator 1.7.0 will no longer support these versions.
Upgrade from Dynatrace Operator version 1.6
In Dynatrace Operator version 1.7, the DynaKube API versions v1beta1 and v1beta2 are no longer served. Applying DynaKube resources using these versions will fail. Update your DynaKube manifests to v1beta5 before upgrading the Dynatrace Operator. For more information, see Migration guide for DynaKube API versions.
