Dynatrace Operator release notes version 1.6.3
  • Latest Dynatrace
  • Release notes
Release date: September 20, 2025
This page provides an overview of the patches included in Dynatrace Operator version 1.6.3. For detailed information on new features and other enhancements, see the release notes for version 1.6.
Resolved issues
  • Reintroduced the mark for termination event, which was previously removed in Dynatrace Operator version 1.6.0, to address challenges in reliably detecting node terminations in setups facilitating auto-scaler. This feature requires your API token to have the DataExport token scope.
Known issues
We have identified the following known issues with Dynatrace Operator version 1.6.3
When switching from using the CSI driver without codeModulesImage to using it with node image pull, ensure that the CSI driver’s filesystem does not contain a code module for the specified DynaKube. If it does, the CSI driver will fail and require manual intervention to recover.
Upgrade from Dynatrace Operator version 1.5
No breaking changes.
Related tags
Dynatrace Platform
