Dynatrace Operator release notes version 1.6.2
  • Latest Dynatrace
  • Release notes
Release date: August 18, 2025
This page provides an overview of the patches included in Dynatrace Operator version 1.6.2. For detailed information on new features and other enhancements, see the release notes for version 1.6.
Upgrade to 1.6.3
If you're running Dynatrace Operator version 1.6, we recommend upgrading to version 1.6.3 to receive the latest important patches.
Resolved issues
  • Resolved an issue where annotations with the prefix metadata.dynatrace.com on scheduled customer application pods were not propagated properly to the enrichment file.
  • The initContainer in the log monitoring DaemonSet now respects resource values set in .spec.templates.logMonitoring.resources in the DynaKube.
  • To promote consistent configurations and avoid the anti-pattern of using the latest tag, it will be required to explicitly specify an OpenTelemetry collector image in the .spec.templates.otelCollector.imageRef field in future operator releases. To prepare for this update, users leveraging the Telemetry ingest feature will now receive a warning if an OpenTelemetry collector image is not defined in the configuration.
Known issues
We have identified the following known issues with Dynatrace Operator version 1.6.0 - 1.6.2.
  • In Kubernetes environments — especially those utilizing auto-scalers — there are challenges in reliably determining whether a node was intentionally removed or has failed unexpectedly. This ambiguity can lead to a high number of false-positive “Host is unavailable” alerts, impacting monitoring accuracy and alerting quality.
When switching from using the CSI driver without codeModulesImage to using it with node image pull, ensure that the CSI driver’s filesystem does not contain a code module for the specified DynaKube. If it does, the CSI driver will fail and require manual intervention to recover.
Upgrade from Dynatrace Operator version 1.5
No breaking changes.
Related tags
Dynatrace Platform
