Dynatrace Operator release notes version 1.5.0
  • Latest Dynatrace
  • Release notes
  • Published Apr 01, 2025
Release date: April 24, 2025
Important notice
If you're running Dynatrace Operator version 1.5.0, we recommend upgrading to version 1.5.1 to receive the latest important patches.
Upcoming changes
Kubernetes dimension names change
The Kubernetes dimension names (dt.kubernetes.cluster.id, dt.kubernetes.workload.kind, dt.kubernetes.workload.name) won't be available starting with Dynatrace Operator version 1.8.0.
If you're still using them, update your configuration, queries, and other references to the new names as soon as possible.
Deprecated nameNew name
dt.kubernetes.cluster.idk8s.cluster.uid
dt.kubernetes.workload.kindk8s.workload.kind
dt.kubernetes.workload.namek8s.workload.name
New features and enhancements
  • The new node image pull feature introduces new capabilities for image pulling, along with enhanced performance, security and flexibility in the Dynatrace Operator. For more information on the feature, see our guide for configuring node image pull.
  • For cloudNativeFullStack and hostMonitoring, OneAgent (host module) no longer depends on the CSI driver. If the CSI driver is not deployed, a hostPath volume is utilized instead. The default path (/var/opt/dynatrace) can be overriden via the storageHostPath field.
  • You can now add a PersistentVolumeClaim (PVC) to your containerized ActiveGate to avoid data loss across unexpected restarts. We recommend to add a PVC when using log_analytics_collector. Learn how to configure a PVC in our guide and protect yourself from losing log data.
  • Live Debugger can now be enabled by adding debugging to .spec.activeGate.capabilities.
  • OneAgent log module and the CSI driver are now supported on GKE Autopilot.
Resolved issues
  • The log module was unable to retrieve metadata from the Kubernetes API. This issue was resolved by providing the service account token with the appropriate permissions to the OneAgent pod.
  • Tenant tokens can be manually rotated using the Dynatrace API. This process has been simplified, as the restart of ActiveGate and OneAgent to utilize the new token is now handled automatically, eliminating the need for manual restarts.
  • The issue where stray operator logs were inadvertently included in the binary zip output during support archive generation, causing the zip file to become corrupted on non-Linux systems, has been resolved.
  • Providing custom arguments to the OneAgent (.spec.oneagent.*.args) could potentially result in duplications. To prevent unforeseen side effects, duplicates are now avoided, except for arguments --set-host-property and --set-host-tag.
    Note: Providing --set-host-tag multiple times with the same tag value is not allowed. Such a DynaKube configuration will be rejected.
  • Host properties are typically provided to the OneAgent in key=value pairs using --set-host-property arguments. An issue that caused DynaKube configurations to be rejected has now been resolved, allowing the desired host properties to be set successfully.
  • The Helm .debug switch now accepts string values, which are correctly interpreted.
  • The /var/logs host directory mount is now read-only to ensure access to journald and kubelet logs.
Removal and deprecation notices
  • The “Mark for Termination” event is deprecated and will be removed in a future Operator version. This functionality is now redundant, as it has been superseded by host availability events on host shutdown and reboot introduced in OneAgent version 1.301.
  • The Helm repository located in dynatrace/helm-charts is deprecated and will stop receiving updates in a future release! If you are still using it, please update the URL to dynatrace/dynatrace-operator or switch to the OCI registry-based approach. Update the Helm repository URL with the following commands:
    helm repo remove dynatrace
    helm repo add dynatrace https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/main/config/helm/repos/stable
Upgrade from Dynatrace Operator version 1.4
  • Dynatrace Operator version 1.5.0 Default DynaKube version is now v1beta4. Make sure to update your DynaKube accordingly to use newly introduced features!
  • The Dynatrace Operator now automatically generates certificates to facilitate secure communication between your in-cluster ActiveGate and other Dynatrace components. This feature is enabled by default and requires ActiveGate version 1.307.35 or higher. To use this feature, ensure your ActiveGate is updated to version 1.307.35+. If you prefer to disable this feature, set the feature flag feature.dynatrace.com/automatic-tls-certificate: false in your Dynakube configuration.
Related tags
Dynatrace Platform
