Dynatrace Operator release notes version 1.3.1
- Release notes
- Published Oct 15, 2024
Release date: Oct 14, 2024
Resolved issues
- OneAgent will now correctly bypass proxy usage when the feature flag
feature.dynatrace.com/oneagent-ignore-proxy is set.
- Fixed the conversion of EdgeConnect custom resources from
v1alpha1 to v1alpha2, which previously failed when the hostRestrictions field was empty.
- Fixed a problem in the Dynatrace Operator logic that was causing interruptions in Kubernetes monitoring within ActiveGate.
Upgrade from Dynatrace Operator version 1.3
No breaking changes.
