Web applications in RUM Classic
  • Dynatrace Classic
  • Overview
  • 1-min read
All HTML pages—like static webpages or single-page applications running in a browser—are regarded as web applications.
We ended support for Internet Explorer 11 starting with RUM JavaScript version 1.293. For more information, see RUM JavaScript for Internet Explorer.
Initial setup
  • Define applications for Real User Monitoring Classic
  • Configure automatic injection in RUM Classic
  • Set up agentless monitoring in RUM Classic
  • Select a snippet format in RUM Classic
  • Configure Real User Monitoring Classic to capture XHR actions
  • Pages and page groups in RUM Classic
  • Create custom user action names for web applications in RUM Classic
  • Infrastructure pass-through requirements for RUM Classic
  • Link cross-origin XHR user actions and their distributed traces in RUM Classic
  • Use Subresource Integrity (SRI) in RUM Classic
  • Check your application health in RUM Classic
  • Roll out RUM Classic selectively for your applications
Additional configuration
  • Control the RUM JavaScript version in RUM Classic
  • Configure cost and traffic control for web applications in RUM Classic
  • Configure data privacy settings for web applications in RUM Classic
  • Configure key user actions for web applications in RUM Classic
  • Capture additional interaction types for web applications in RUM Classic
  • Adjust Apdex settings for web applications in RUM Classic
  • Change user experience score thresholds for web applications in RUM Classic
  • Create calculated metrics for web applications in RUM Classic
  • Create USQL custom metrics for web applications in RUM Classic
  • Define user action and user session properties for web applications in RUM Classic
  • Customize Real User Monitoring Classic with the JavaScript API for web applications
  • Configure error detection for web applications in RUM Classic
  • Tag specific users for web applications in RUM Classic
  • Customize IP address detection for web applications in RUM Classic
  • Map internal IP addresses to locations for web applications in RUM Classic
  • Configure first-party, third-party, and CDN resource detection for web applications in RUM Classic
  • Configure cookie attributes in RUM Classic
  • Configure beacon origin allowlist for web applications in RUM Classic
  • Configure beacon endpoint for web applications in RUM Classic
  • Configure the monitoring code source in RUM Classic
  • Exclude IP addresses, browsers, bots, and spiders from monitoring for web applications in RUM Classic
  • Configure your caching servers in RUM Classic
  • Check application detection rules in RUM Classic
  • Configure XHR for older versions of Internet Explorer in RUM Classic
  • Control RUM Classic at the process group level
  • Modify Content Security Policy for RUM Classic
  • Delete a web application in RUM Classic
Analyze and use RUM data
  • Introduction to application overview page in RUM Classic
  • Performance analysis in RUM Classic
  • User behavior analysis in RUM Classic
  • Multidimensional analysis for web applications in RUM Classic
  • Waterfall analysis in RUM Classic
  • World map view in RUM Classic
  • Work with key performance metrics in RUM Classic
  • Analyze individual user actions in RUM Classic
  • Leverage user action and user session properties for web applications in RUM Classic
  • Define conversion goals in RUM Classic
  • Use 'Visually complete' and 'Speed index' metrics in RUM Classic
  • Visually complete top findings in RUM Classic
  • Application analysis with Hyperlyzer in RUM Classic
  • Service flows for applications and user actions in RUM Classic
  • Source map support for JavaScript error analysis in RUM Classic
Troubleshooting
Troubleshooting RUM Classic for web applications
