Send StatsD metrics to Dynatrace
  • Latest Dynatrace
  • 5-min read
StatsD is an industry standard for communicating arbitrary statistics and other metrics in a vendor-independent way via UDP. We recommend that you use Dynatrace OneAgent to ingest your metrics, as OneAgent comes with a StatsD daemon out of the box. This means that any application or library that supports StatsD can send metrics to Dynatrace. You only need to install OneAgent and make sure that your StatsD client uses the right port (18125 by default).
Supported OneAgent
StatsD daemon is only available on OneAgent installed on the VM or host that you want to monitor. OneAgent deployed on Kubernetes, for example using Dynatrace Operator, isn't supported. For Kubernetes environments, we recommend remote StatsD monitoring using an environment ActiveGate.
If you can't install OneAgent on a host with your StatsD metrics, however, you can use an ActiveGate to act as a remote listener.
Choose your StatsD ingestion method
Use OneAgent for direct installation on the host with StatsD. For more details, go to OneAgent listener.
Enable DynatraceStatsD
The DynatraceStatsD listener comes with OneAgent version 1.201+. You only need to enable DynatraceStatsD metric ingestion at the environment, host, or host group level. Note that the host-level and host group-level configurations override the environment configuration.
To enable DynatraceStatsD metric ingestion at the environment level
  1. Go to Settings and select Preferences > Extension Execution Controller.
  2. Turn on Enable Extension Execution Controller.
  3. Turn on Enable Dynatrace StatsD.
To enable DynatraceStatsD metric ingestion at the host group level
  1. Go to Settings and select Monitoring overview > Hosts.
  2. Select the host group name for a chosen host.
  3. On the Host group settings page, select Extension Execution Controller.
  4. Turn on Enable Dynatrace StatsD.
To enable DynatraceStatsD metric ingestion only for selected hosts
  1. Go to Hosts (previous Dynatrace) or Hosts Hosts Classic.
  2. Find and select your host to display the host overview page.
  3. In the upper-right corner of the host overview page, select More () > Settings.
  1. In the host settings, select Extension Execution Controller.
ActiveGate version 1.227+
If you can't use OneAgent to ingest StatsD metrics, you can use an Environment ActiveGate as your DynatraceStatsD ingestion point. Your ActiveGate needs to be able to connect to your StatsD client over UDP.
DynatraceStatsD metric ingestion is disabled by default on an ActiveGate.
  1. Edit the extensionsuser.conf file in the following directory
    • Linux /var/lib/dynatrace/remotepluginmodule/agent/conf/extensionsuser.conf
    • Windows C:\ProgramData\dynatrace\remotepluginmodule\agent\conf\extensionsuser.conf
  2. Set the statsdenabled parameter to true:
    statsdenabled=true
  3. Restart the Extension Execution Controller service.
    • Linux Run the following commands:
      • for systems with SystemV:
        service extensionsmodule stop
        service extensionsmodule start
      • for systems with systemd:
        systemctl stop extensionsmodule
        systemctl start extensionsmodule
    • Windows Use Task Manager and restart the Dynatrace Extensions Controller service or run the following commands:
      net stop "Dynatrace Extensions Controller"
      net start "Dynatrace Extensions Controller"
Note that the default port for remote StatsD is different than for the OneAgent DynatraceStatsD listener (18126). See Remote StatsD.
This file is not modified during ActiveGate updates.
Make sure that your ActiveGate can connect to your StatsD client. For example, you should configure the DNS name for your ActiveGate and make sure that it works after a new IP address is assigned from DHCP.
Communication port
OneAgent listener
The default DynatraceStatsD UDP listening port for the OneAgent listener is 18125. If necessary, you can use the oneagentctl command to check or change the metric ingestion port. Changing the port requires restart of OneAgent. Add --restart-service to the command to restart OneAgent automatically.
Check the ingestion port
Use the --get-extensions-statsd-port parameter to show the current DynatraceStatsd UDP listening port (default = 18125).
  • Linux: ./oneagentctl --get-extensions-statsd-port
  • Windows: .\oneagentctl.exe --get-extensions-statsd-port
Set a custom ingestion port
Use the --set-extensions-statsd-port=<arg> parameter to set a custom DynatraceStatsd UDP listening port.
  • Linux: ./oneagentctl --set-extensions-statsd-port=18125 --restart-service
  • Windows: .\oneagentctl.exe --set-extensions-statsd-port=18125 --restart-service
Remote StatsD
The default DynatraceStatsD UDP listening port for a remote listener is 18126.
To change the default 18126 listening port, modify the StatsdPort parameter in the ActiveGate extensionsuser.conf file:
  • Windows C:\ProgramData\dynatrace\remotepluginmodule\agent\conf\extensionsuser.conf:
StatsdPort=18126
Topology awareness
Using DynatraceStatsD with OneAgent, the host ID and host name context are added as dimensions to each metric automatically. For more information, see Metric ingestion. Note that we're already working on more automatic metric enrichments. For remote ingestion, no extra enrichment is added. If you want to add context to your metrics, you'll need to add dimensions of your choice to your StatsD metrics.
Security
The DynatraceStatsD OneAgent listener only accepts input from localhost addresses. This means that only processes that are running on the same host as OneAgent can leverage the interface. This ensures that no unauthorized programs are sending data to your Dynatrace environment.
StatsD metric format
DynatraceStatsD accepts the following metrics in the native StatsD format:
  • count
    <metric name>:<value>|c
  • gauge
    <metric name>:<value>|g
  • time
    <metric name>:<value>|ms
  • histogram
    <metric name>:<value>|h
  • set OneAgent version 1.303+
    <metric name>:<value>|s
  • distribution
    <metric name>:<value>|d
DynatraceStatsD extends the original protocol to enable you to also send dimensions. Use the following format:
<metric name>:<value>|g|#<Dimension1>:<value>,<Dimension2>:<value>
Datasource limits and performance
The limits are based on the test that deploys a Linux machine in the AWS cloud. The purpose of this test is to determine how much StatsD load the infrastructure framework can handle.
Hardware specification
OneAgent and ActiveGate are installed in a Linux-based VM in Amazon EC2 c5.large instance type.
  • CPU: x2
  • RAM: 4 GiB
  • Storage: EBS
  • Network bandwidth: up to 10 GBPS
Total recordsPacketsLines per packetConnectionsMetrics
StatsD on OneAgent290,00011,6002511
StatsD on ActiveGate345,00013,8002511
