Smartscape Classic, our near real-time environment-topology visualization tool, is one of the most powerful features of Dynatrace.
Smartscape Classic auto-discovery delivers a quick and efficient visualization of all the topological dependencies in your infrastructure, processes, and services:
With just a few clicks,
Smartscape Classic gives you access to a detailed topological view of your entire environment, giving you more insight into and control over your environment.
Smartscape ClassicTo access the classic Smartscape environment-topology view, go to
Smartscape Classic.
To start, select the view you want to see:
When Show problems is selected, each
Smartscape Classic tier includes a dedicated tab with a health indicator. Select the tier at which you want to view the topology:
Each tier shows a different entity type: application, service, process, host, or data center.
Smartscape Classic.In the first example image below:
Smartscape Classic displays data from the past 72 hours and therefore can't be adjusted using the timeframe selector. To view the dependencies among entities of the same tier, just select the associated tab on the left.
In this example, the Applications tab is selected and the 12 detected applications in this environment are displayed on the right.
Dynatrace supports monitoring of web-based applications and mobile apps. The node symbols indicates the application type:
| Icon | Meaning |
Web application | |
Mobile app |
There are no application connections or dependencies because, in Dynatrace, applications are viewed from the perspective of the user and therefore only constitute user endpoints. Therefore, multiple applications may use the same services, but applications can't be connected directly to one another.
The Services tab displays the topology of all the services that are running in your environment.
Nodes
Each node represents a different service with a symbol that signifies the underlying service type.
| Icon | Meaning |
see example above | Commercial logos such as the MySQL dolphin, Apache feather, and Tomcat cat indicate service technologies supported by Dynatrace. |
Services of unrecognized technologies are depicted using a generic service symbol. These are typically opaque services. |
Connections
Smartscape Classic if the connection has been inactive for more than 72 hours or if a service hasn't received any load during the last 72 hours.Filtering your display
Open the Browse (…) menu in the upper-right corner of
Smartscape Classic to hide or show:
Note that you might observe a difference in the number of services presented in Services tab of the
Smartscape Classic page versus the Services page. This is because
Smartscape Classic takes a broader scope of service categories into account.
The Processes tab provides a visualization within which each node corresponds to a process and each connection represents a TCP/IP request.
The Hosts tab shows the topology of your infrastructure from the perspective of your hosts.
Generic host symbols are used to signify monitoring candidates (unknown hosts that are detected because they receive TCP/IP requests from monitored hosts). We recommend that you install Dynatrace OneAgent on monitoring candidates in your environment whenever possible.
| Icon | Meaning |
monitoring candidate |
Inactive monitoring candidates are monitoring candidates that haven’t communicated with a host. Inactive connections between hosts and connections that have timed-out are visualized with dashed lines.
The Data centers tab displays nodes that indicate where your hosts reside. If you have physical servers in your infrastructure, the corresponding data center nodes indicate the cities where the data centers are located. These are signified with generic host icons.
If you use virtual servers or you have a PaaS-based infrastructure, the data center nodes will be labeled accordingly (for example, VMware data center, AWS Availability Zone, or Azure region) and visualized with the corresponding company logos.
To view cross-tier connections, select any entity in any
Smartscape Classic tier. The vertical dependencies of the entity are then displayed on the left.
In this example, a web application called easytravel-dynatrace-dev is selected. On the left you can see how the application dependencies extend downward to the data centers tier.
The easytravel-dynatrace-dev application is red because it's experiencing a problem. Moving downward through the related dependencies, we can see that this application calls 27 Tomcat services and 4 ASP/.NET services. These services run on processes of the same technology types (those shown in red are experiencing problems). You can see that these processes reside on a Windows-based host called lr-ws-l02v (to see this detail, hover your cursor over the host node). Because the unhealthy processes are running on this host, this host is also unhealthy (note the red 1 on the Hosts tile on the left).
This example reveals how you can easily discover the root cause of a problem and reduce problem resolution time by exploring the related entities in
Smartscape Classic.
When Show third-party vulnerabilities is selected in
Smartscape Classic, select Risk level to specify the risk levels you want to display. You can select more than one checkbox.
CriticalHighMediumLowTo see vulnerabilities for affected entities, switch to the Processes or Hosts tier. (Vulnerabilities can be related to an application, service, or data center, but they don't impact them directly. Only processes or hosts can be impacted.)
Smartscape Classic.For more information on managing third-party vulnerabilities, see Third-party vulnerabilities (Dynatrace Classic).
