Collect PostgreSQL database performance metrics and query logs via remote ActiveGate monitoring to detect anomalies, blocking queries, and performance issues.
The PostgreSQL monitoring solution is based on a remote monitoring approach implemented as a Dynatrace ActiveGate extension. The extension queries PostgreSQL databases for performance and health metrics. Dynatrace Intelligence analyzes these metrics for anomalies and problems.
Install an ActiveGate in your environment.
Designate one or more ActiveGate groups to remotely connect to your PostgreSQL database server and pull data. All ActiveGates in each group must be able to reach the server.
For self-hosted Postgres: Postgres additional supplied modules must be installed.
For cloud-managed Postgres services: Ensure that specific extensions and settings are enabled.
Create a dedicated database user in your database instance. Dynatrace uses this user to run monitoring queries against your PostgreSQL database. Choose the authentication method based on your setup.
Standard user:
CREATE USER dynatrace WITH PASSWORD '<PASSWORD>' INHERIT;
IAM (AWS RDS): Use this method to authenticate using AWS IAM instead of a database password. Requires an IAM role attached to your ActiveGate host. For IAM policy and role setup, see AWS IAM.
Enable IAM database authentication on your RDS instance. For details, see Enabling and disabling IAM database authentication.
Create the monitoring user.
CREATE USER dynatrace WITH LOGIN;GRANT rds_iam TO dynatrace;
Dynatrace Hub.To monitor a new Postgres database, do one of the following:
Databases (recommended for first-time users).
Extensions.Required permission: Change monitoring settings
Extensions.Go to the PostgreSQL extension and select + Add configuration.
In Choose where to run the extension, select ActiveGate.
In Select ActiveGate group to activate extension, select the ActiveGate group, and then select Next.
Create one or more endpoints that point to your database instances. Each configuration can have up to 20,000 endpoints.
In the Database connection section, provide:
5432.postgres database).In the Authentication section:
dynatrace monitoring user you created:
Optional Configure database discovery to automatically monitor the databases running on an instance.
Optional Add Additional configuration parameters if required.
Optional Add Primary fields and Primary tags to attach metadata to the entities created for the endpoint.
To monitor more instances, select Add PostgreSQL endpoint and repeat the steps.
After you create all endpoints, select Next.
For further configuration options, see Configure PostgreSQL for monitoring section.
Adjust the polling frequency and other variables for this monitoring configuration:
Endpoint metadata: Adds a custom metadata field to all the entities created by this configuration.Query interval: Controls the polling frequency for most of the metrics collected by the extension. Defaults to 1 minute.Long query interval: Controls the polling frequency of top query monitoring. Defaults to 5 minutes.Table query interval: Controls the polling frequency of table and index monitoring queries. Available from major version 3 onwards.Configuration query interval: Controls the polling frequency of database configuration parameters and schema.The default Long query interval is 5 minutes, which aligns with the Database Monitoring billing interval.
Setting a shorter interval may result in additional Database Monitoring consumption.
Select Next.
Congratulations! You have successfully configured the PostgresSQL extension via
Extensions for remote monitoring.
To monitor your database instance, specific settings must be configured on the PostgreSQL database. If you're onboarding through
Databases, scripts are provided that create the necessary database objects. Download the script to your host and run it as an admin user with sufficient permissions. Otherwise, run the following actions manually.
The following actions are required once per instance:
Add pg_stat_statements to shared_preload_libraries to enable query-level statistics collection. This must be set before creating the extension in step 4.
Grant the monitoring user membership in the pg_monitor role for read-only monitoring access.
GRANT pg_monitor TO dynatrace;
For self-hosted PostgreSQL, install the hypopg binaries on your host. See the hypopg documentation for installation instructions.
Cloud-managed services such as AWS RDS and Aurora already ship the hypopg binaries. No additional steps are needed.
The following actions must be performed in each database you want to monitor.
The following actions are required in each database:
Create the dynatrace schema.
CREATE SCHEMA IF NOT EXISTS dynatrace;
Grant the monitoring user access to the dynatrace schema.
GRANT USAGE ON SCHEMA dynatrace TO dynatrace;
Create a helper function that generates execution plans from SQL commands for deeper query insights.
CREATE OR REPLACE FUNCTION dynatrace.dynatrace_execution_plan(query text,OUT explain JSON) RETURNS SETOF JSONLANGUAGE plpgsqlVOLATILERETURNS NULL ON NULL INPUTSECURITY DEFINERROWS 1SET plan_cache_mode = force_generic_planSET statement_timeout = '10s'SET lock_timeout = '200ms'AS$$DECLAREsanitized text;nparams integer;explain_cmd text;json_result json;BEGIN/* remove literals, comments and quoted identifiers */sanitized := dynatrace_execution_plan.query;sanitized := pg_catalog.regexp_replace(sanitized, '\$([A-Za-z_]\w*)?\$.*?\$\1\$', '', 'gs');sanitized := pg_catalog.regexp_replace(sanitized, '''(''''|\\.|[^''\\])*''', '', 'g');sanitized := pg_catalog.regexp_replace(sanitized, '"(""|[^"])*"', '', 'g');sanitized := pg_catalog.regexp_replace(sanitized, '/\*.*?\*/', '', 'gs');sanitized := pg_catalog.regexp_replace(sanitized, '--[^\n]*', '', 'g');/* reject statements containing a semicolon in the middle */IF pg_catalog.strpos(pg_catalog.regexp_replace(sanitized, '[;[:space:]]+$', ''),';') OPERATOR(pg_catalog.>) 0 THENRAISE EXCEPTION 'query string must not contain a semicolon';END IF;/* drop a statement left behind by an earlier failure */IF EXISTS (SELECT 1FROM pg_catalog.pg_prepared_statements psWHERE ps.name OPERATOR(pg_catalog.=) '_dt_plan_stmt_') THENDEALLOCATE _dt_plan_stmt_;END IF;/* construct a prepared statement, letting the planner infer the parameter types */EXECUTEpg_catalog.concat('PREPARE _dt_plan_stmt_ AS ',dynatrace_execution_plan.query);BEGIN/* get the parameter count */SELECT COALESCE(pg_catalog.array_length(ps.parameter_types, 1), 0)INTO nparamsFROM pg_catalog.pg_prepared_statements psWHERE ps.name OPERATOR(pg_catalog.=) '_dt_plan_stmt_';/* construct an EXPLAIN statement */explain_cmd :=pg_catalog.concat('EXPLAIN (FORMAT JSON, ANALYZE FALSE) EXECUTE _dt_plan_stmt_',CASEWHEN nparams OPERATOR(pg_catalog.=) 0 THEN ''ELSE pg_catalog.concat('(',pg_catalog.rtrim(pg_catalog.repeat('NULL,', nparams),','),')')END);/* get the plan */EXECUTE explain_cmd INTO json_result;EXCEPTIONWHEN OTHERS THEN/* delete the prepared statement, then report the original error */DEALLOCATE _dt_plan_stmt_;RAISE;END;/* delete the prepared statement */DEALLOCATE _dt_plan_stmt_;/* return the plan */RETURN QUERY SELECT json_result;END;$$;
SECURITY DEFINER: Executes with the privileges of the user who defined the function, not the caller.
EXPLAIN: Requires the same permissions needed to run the query. The user running this function needs sufficient privileges to run PREPARE and EXPLAIN on the queries it explains.
In some PostgreSQL configurations you might also need to set search_path for the monitoring user:
ALTER USER dynatrace SET search_path to dynatrace, public;
Create the pg_stat_statements extension for query-level statistics collection.
CREATE EXTENSION IF NOT EXISTS pg_stat_statements SCHEMA public;
Create the hypopg extension, required for the Index Recommendations feature set.
CREATE EXTENSION IF NOT EXISTS hypopg SCHEMA public;
For self-hosted PostgreSQL, if the hypopg binaries were not installed (see step 3), this command will fail. Index Recommendations are unavailable until you install hypopg and re-run this step.
Create the dynatrace_index_advisor function for index recommendation analysis.
CREATE OR REPLACE FUNCTION dynatrace.dynatrace_index_advisor(query text, OUT result json)RETURNS SETOF jsonLANGUAGE plpgsqlSTRICT SECURITY DEFINER ROWS 1SET search_path TO 'pg_catalog', 'dynatrace', 'public'AS $function$DECLAREn_args int;prepared_statement_name text = 'dynatrace_ia_stmt';hypopg_schema_name text;explain_plan_statement text;error_message text;rec record;plan_initial jsonb;plan_final jsonb;statements text[] = '{}';referenced_oids oid[];initial_cost numeric;final_cost numeric;initial_startup numeric;final_startup numeric;cost_reduction_pct numeric;cost_reduction numeric;min_cost_threshold numeric := 200;BEGINhypopg_schema_name := (SELECT extnamespace::regnamespace::text FROM pg_extension WHERE extname = 'hypopg');IF hypopg_schema_name IS NULL THENRETURN QUERY SELECT json_build_object('database', current_database(),'query', query,'errors', array['hypopg extension is required but not installed']::text[]);RETURN;END IF;query := trim(regexp_replace(regexp_replace(regexp_replace(query, '\/\*[\s\S]+?\*\/', '', 'g'),'--[^\r\n]*', ' ', 'g'),'\s+', ' ', 'g'));query := regexp_replace(query, ';\s*$', '');BEGINIF query ILIKE '%;%' THENRAISE EXCEPTION 'Query must not contain a semicolon';END IF;query := replace(query, 'WITH pgrst_payload AS (SELECT $1 AS json_data)', 'WITH pgrst_payload AS (SELECT $1::json AS json_data)');query := regexp_replace(query,'\m(INTERVAL|TIMESTAMPTZ|TIMESTAMP|DATE|TIME)\s+(\$\d+)','\2::\1','gi');query := regexp_replace(query,'\mEXTRACT\s*\(\s*(\$\d+)\s+FROM\y','date_part(\1::text,','gi');BEGINEXECUTE format('DEALLOCATE %I', prepared_statement_name);EXCEPTION WHEN OTHERS THENNULL;END;EXECUTE format('PREPARE %I AS %s', prepared_statement_name, query);n_args := (SELECT COALESCE(array_length(parameter_types, 1), 0)FROM pg_prepared_statementsWHERE name = prepared_statement_nameLIMIT 1);explain_plan_statement := format('SET LOCAL plan_cache_mode = force_generic_plan; EXPLAIN (FORMAT JSON, VERBOSE) EXECUTE %I%s',prepared_statement_name,CASEWHEN n_args = 0 THEN ''ELSE format('(%s)', array_to_string(array_fill('null'::text, array[n_args]), ','))END);EXECUTE explain_plan_statement INTO plan_initial;initial_cost := (plan_initial -> 0 -> 'Plan' ->> 'Total Cost')::numeric;initial_startup := (plan_initial -> 0 -> 'Plan' ->> 'Startup Cost')::numeric;IF initial_cost IS NULL OR initial_cost < min_cost_threshold THENEXECUTE format('DEALLOCATE %I', prepared_statement_name);RETURN;END IF;BEGINWITH RECURSIVE nodes AS (SELECT (plan_initial -> 0 -> 'Plan') AS nodeUNION ALLSELECT child.valueFROM nodes nCROSS JOIN LATERAL jsonb_array_elements(n.node -> 'Plans') AS child(value)WHERE n.node ? 'Plans')SELECT array_agg(DISTINCT rel.oid)INTO referenced_oidsFROM nodes nCROSS JOIN LATERAL (SELECT format('%I.%I', n.node ->> 'Schema', n.node ->> 'Relation Name')::regclass::oid AS oidWHERE (n.node ->> 'Relation Name') IS NOT NULLAND (n.node ->> 'Schema') IS NOT NULL) rel;EXCEPTION WHEN OTHERS THENreferenced_oids := NULL;END;IF referenced_oids IS NULL OR array_length(referenced_oids, 1) IS NULL THENEXECUTE format('DEALLOCATE %I', prepared_statement_name);RETURN QUERY SELECT json_build_object('database', current_database(),'query', query,'startup_cost_before', initial_startup,'startup_cost_after', initial_startup,'total_cost_before', initial_cost,'total_cost_after', initial_cost,'index_statements', array[]::text[]);RETURN;END IF;FOR rec IN (WITH extension_regclass AS (SELECT DISTINCT objid AS oidFROM pg_catalog.pg_dependWHERE deptype = 'e')SELECTformat('SELECT %I.hypopg_create_index(''CREATE INDEX ON %I.%I(%I)'')',hypopg_schema_name,pc.relnamespace::regnamespace::text,pc.relname,pa.attname) AS hypopg_statementFROM pg_catalog.pg_class pcJOIN pg_catalog.pg_attribute pa ON pc.oid = pa.attrelidLEFT JOIN extension_regclass er ON pc.oid = er.oidLEFT JOIN pg_catalog.pg_index piON pc.oid = pi.indrelidAND pi.indkey[0] = pa.attnumAND pi.indisvalidAND pi.indexprs IS NULLAND pi.indpred IS NULLAND (SELECT am.amname FROM pg_catalog.pg_class icJOIN pg_catalog.pg_am am ON am.oid = ic.relamWHERE ic.oid = pi.indexrelid) = 'btree'WHERE pc.relnamespace::regnamespace::text NOT IN ('pg_catalog', 'pg_toast', 'information_schema')AND er.oid IS NULLAND pc.relkind IN ('r', 'm')AND pc.relpersistence = 'p'AND pa.attnum > 0AND NOT pa.attisdroppedAND pi.indrelid IS NULLAND pa.atttypid IN (20,16,1082,1184,1114,701,23,21,700,1083,2950,1700,25,18,1042,1043,774,790,829,869,1186,1266)AND pc.oid = ANY(referenced_oids))LOOPEXECUTE rec.hypopg_statement;END LOOP;EXECUTE format('DEALLOCATE %I', prepared_statement_name);EXECUTE format('PREPARE %I AS %s', prepared_statement_name, query);EXECUTE explain_plan_statement INTO plan_final;final_cost := (plan_final -> 0 -> 'Plan' ->> 'Total Cost')::numeric;final_startup := (plan_final -> 0 -> 'Plan' ->> 'Startup Cost')::numeric;EXECUTE format('SELECT COALESCE(array_agg(%I.hypopg_get_indexdef(indexrelid) ORDER BY indrelid, indkey::text), ''{}''::text[])FROM %I.hypopg()WHERE position(indexname IN %s) > 0',hypopg_schema_name,hypopg_schema_name,quote_literal(plan_final)::text) INTO statements;EXECUTE format('SELECT %I.hypopg_reset()', hypopg_schema_name);BEGINEXECUTE format('DEALLOCATE %I', prepared_statement_name);EXCEPTION WHEN OTHERS THENNULL;END;IF final_cost IS NULL OR initial_startup IS NULL OR final_startup IS NULL THENRETURN;END IF;IF final_cost > initial_cost THENRETURN;END IF;IF initial_cost > 0 THENcost_reduction_pct := round((initial_cost - final_cost) / initial_cost * 100,2);ELSEcost_reduction_pct := 0;END IF;cost_reduction := GREATEST(initial_cost - final_cost, 0);RETURN QUERY SELECT json_build_object('database', current_database(),'query', query,'startup_cost_before', initial_startup,'startup_cost_after', final_startup,'total_cost_before', initial_cost,'total_cost_after', final_cost,'cost_reduction_pct', cost_reduction_pct,'cost_reduction', cost_reduction,'index_statements', statements);EXCEPTION WHEN OTHERS THENGET STACKED DIAGNOSTICS error_message = MESSAGE_TEXT;BEGIN EXECUTE format('SELECT %I.hypopg_reset()', hypopg_schema_name); EXCEPTION WHEN OTHERS THEN NULL; END;BEGIN EXECUTE format('DEALLOCATE %I', prepared_statement_name); EXCEPTION WHEN OTHERS THEN NULL; END;RETURN QUERY SELECT json_build_object('database', current_database(),'query', query,'index_statements', array[]::text[],'errors', array[error_message]::text[]);END;END;$function$;
After running the creation script, run the validation script to confirm all required objects are created. This ensures the monitoring setup works as expected.
After completing these steps, metrics for the monitored PostgreSQL instance are visible in
Databases within 2–3 minutes. Select any instance to explore detailed metrics and performance insights.
Dynatrace supports both self-hosted and cloud-managed monitoring for Postgres databases.
Choose self-hosted Postgres for complete observability, execution plan analysis, automated onboarding, and advanced diagnostics.
Choose cloud-managed Postgres for reduced operational overhead with some monitoring limitations and manual configuration.
With self-hosted Postgres, you manage the database instance and infrastructure. The extension collects data directly from the database using a read-only user. Complete the following setup to enable monitoring:
Configure database parameters.
Configure the following Postgres parameters in the postgresql.conf file and restart the server to apply the settings. For more details, see the Postgres documentation.
Grant the Dynatrace proxy access to the database.
Select and configure the ActiveGate group.
Cloud-managed PostgreSQL is provided as a service by cloud platforms. Services like AWS RDS, AWS Aurora, and Google Cloud SQL prevent direct database configuration. Enable the following features and settings to ensure full monitoring capability.
Add the pg_stat_statements extension.
This extension collects query-level statistics.
Configure the following settings:
track_activity_query_size = 4096 Required
Enables the collection of larger queries by increasing the size of SQL text in pg_stat_activity. If left at the default value (1024), queries longer than 1024 characters aren't collected.
pg_stat_statements.max = 10000 Optional
Increases the number of normalized queries tracked in pg_stat_statements.
pg_stat_statements.track_utility = off Optional
Disables tracking of utility commands like PREPARE and EXPLAIN.
track_io_timing = on Optional
Collects timing information for block read and write operations in queries.
Starting with version Dynatrace version 1.338 and extension major version 3, the following features require an individual connection to each database:
When creating an endpoint, configure database discovery to automatically monitor databases running on an instance without configuring a separate endpoint for each one.
The following discovery modes are available:
When database discovery is enabled, the following connection management settings control how connections to each discovered database are opened and maintained:
On-demand (default)
Connections open only when a query needs to run and close afterwards. A global limit caps the total number of concurrent open connections across all discovered databases.
| Parameter | Description | Default | Minimum | Maximum |
| Maximum number of concurrent connections across all discovered databases | 200 | 15 | 500 |
Pooled
Each discovered database has a dedicated connection pool. Connections are established eagerly and kept alive, which minimizes overhead during query execution. No additional configuration is required.
Use on-demand mode when the number of discovered databases is large and maintaining a permanent pool per database would exhaust available database connections. Use pooled mode when low query latency is a priority and the number of discovered databases is small.
If Dynatrace log monitoring is enabled and the pg_stat_statements view is available, Dynatrace ingests the top 100 queries (sorted by total execution time) every 5 minutes and stores them as logs. These logs are available either from the database instance screen or on
Databases, under Top queries by total execution time.
To filter for these queries on a dashboard or notebook, filter by dt.extension.name = com.dynatrace.extension.postgres and event.group = top_queries. Example DQL query:
fetch logs| filter dt.extension.name=="com.dynatrace.extension.postgres" and event.group=="top_queries"| sort total_exec_time desc
Whether or not pg_stat_statements is available, Dynatrace collects queries from pg_stat_activity as part of the Queries feature set. These are ingested as logs with event.group = longest_queries.
If you have configured top query monitoring (see Monitoring top queries), you can fetch execution plans for these queries in
Databases by selecting Statement performance > Request on the execution plan for a specific query.
For that query, the extension attempts to execute the following:
SELECT * from dynatrace.dynatrace_execution_plan({query})
and then ingest into Dynatrace the first row of the column named explain. These execution plans are ingested as logs with event.group = execution_plans.
The ActiveGate must establish a direct connection to the host being monitored. It should avoid connecting through a load balancer, proxy, or connection pooler (such as pg-pool).
If the ActiveGate switches between different hosts while running (for example, during failover), it may compute differences in statistics across the DB instances. This can result in inaccurate metrics and misleading data.
There is no charge to use the extension. You are only charged for the data that the extension ingests.
The PostgreSQL extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
Use the following formula to estimate the number of metric data points ingested per minute:
(68 * number of instances) + (40 * number of databases) + (1 * number of tablespaces)
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
For logs, regular consumption applies. See Log Analytics.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
For logs, regular DDU consumption applies. See DDU consumption for Log Management and Analytics or DDUs for Log Monitoring Classic.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
| Metric name | Metric key | Description |
| Replication WAL restart delay | postgres.replication.restart_delay | Difference between current WAL LSN and the restart_lsn as reported by pg_replication_slots. |
| Replication WAL confirmed flush lag | postgres.replication.confirmed_flush_lag | Difference between current WAL LSN and the confirmed_flush_lsn as reported by pg_replication_slots. |
| Replication slot transaction age | postgres.replication.slot_xmin_age | Age of the oldest transaction that this logical replication slot needs the database to retain, as reported by pg_replication_slots. |
| Database conflicts tablespace | postgres.database_conflicts.tablespace.count | Number of queries in this database that have been canceled due to dropped tablespaces, as reported by pg_stat_database_conflicts. Standby only. |
| Database conflicts lock | postgres.database_conflicts.lock.count | Number of queries in this database that have been canceled due to lock timeouts, as reported by pg_stat_database_conflicts. Standby only. |
| Database conflicts snapshot | postgres.database_conflicts.snapshot.count | Number of queries in this database that have been canceled due to old snapshots, as reported by pg_stat_database_conflicts. Standby only. |
| Database conflicts buffer pin | postgres.database_conflicts.bufferpin.count | Number of queries in this database that have been canceled due to pinned buffers, as reported by pg_stat_database_conflicts. Standby only. |
| Database conflicts deadlock | postgres.database_conflicts.deadlock.count | Number of queries in this database that have been canceled due to deadlocks, as reported by pg_stat_database_conflicts. Standby only. |
| Replication WAL write lag | postgres.replication.write_lag | Time elapsed between flushing recent WAL locally and receiving notification that this standby server has written it, as reported by pg_stat_replication. |
| Replication WAL flush lag | postgres.replication.flush_lag | Time elapsed between flushing recent WAL locally and receiving notification that this standby server has written and flushed it, as reported by pg_stat_replication. |
| Replication WAL replay lag | postgres.replication.replay_lag | Time elapsed between flushing recent WAL locally and receiving notification that this standby server has written, flushed and applied it, as reported by pg_stat_replication. |
| Replication backend transaction age | postgres.replication.backend_xmin_age | Age of the backend's xmin horizon, as reported by pg_stat_replication. |
| Replication replay delay | postgres.replication.replay_delay | Difference in bytes between the current WAL position and the last WAL position replayed on the standby server, as reported by pg_stat_replication. |
| WAL receiver received timeline ID | postgres.wal_receiver.received_tli | Timeline number of the last WAL received and flushed to disk, as reported by pg_stat_wal_receiver. Standby only. |
| WAL receiver last message send age | postgres.wal_receiver.last_msg_send_age | Time elapsed since last message sent to origin WAL sender, as reported by pg_stat_wal_receiver. Standby only. |
| WAL receiver last message receipt age | postgres.wal_receiver.last_msg_receipt_age | Time elapsed since last message received from origin WAL sender, as reported by pg_stat_wal_receiver. Standby only. |
| WAL receiver latest end age | postgres.wal_receiver.latest_end_age | Time elapsed since last write-ahead log location reported to origin WAL sender, as reported by pg_stat_wal_receiver. Standby only. |
| Instance uptime | postgres.uptime | Time since the instance has been started |
| Instance recovery mode | postgres.recovery.state | Indicate that the instance is in recovery mode. 1 if in recovery, 0 otherwise. |
| Index size | postgres.indexes.index_size | Disk space used by the index, as reported by pg_relation_size(). |
| Index scans | postgres.indexes.scans.count | Number of index scans initiated on this index as reported by pg_stat_user_indexes (idx_scan). |
| Index tuples read | postgres.indexes.tuples_read.count | Number of index entries returned by scans on this index as reported by pg_stat_user_indexes (idx_tup_read). |
| Index tuples fetched | postgres.indexes.tuples_fetched.count | Number of live table rows fetched by simple index scans using this index as reported by pg_stat_user_indexes (idx_tup_fetch). |
| Index disk block reads | postgres.indexes.index_disk_reads.count | Number of disk blocks read from this index as reported by pg_statio_user_indexes (idx_blks_read). |
| Index buffer hits | postgres.indexes.index_buffer_hits.count | Number of buffer hits for this index as reported by pg_statio_user_indexes (idx_blks_hit). |
| Estimated row count | postgres.tables.rows | Estimated number of live rows in the table as reported by pg_stat_user_tables (n_live_tup). |
| Dead rows | postgres.tables.dead_rows | Estimated number of dead rows in the table as reported by pg_stat_user_tables (n_dead_tup). |
| Rows modified since analyze | postgres.tables.rows_modified_since_analyze | Estimated number of rows modified since this table was last analyzed as reported by pg_stat_user_tables (n_mod_since_analyze). |
| Rows inserted since vacuum | postgres.tables.rows_inserted_since_vacuum | Estimated number of rows inserted since this table was last vacuumed as reported by pg_stat_user_tables (n_ins_since_vacuum). |
| Total table size | postgres.tables.total_size | Total disk space used by the table, including indexes and TOAST data, as returned by pg_total_relation_size(). |
| Table size | postgres.tables.table_size | Disk space used by the main fork of the table, as returned by pg_relation_size(). |
| TOAST size | postgres.tables.toast_size | Disk space used by the TOAST table associated with this table, as returned by pg_relation_size(). |
| Indexes size | postgres.tables.indexes_size | Total disk space used by all indexes on the table, as returned by pg_indexes_size(). |
| Sequential scans | postgres.tables.sequential_scans.count | Number of sequential scans initiated on this table as reported by pg_stat_user_tables (seq_scan). |
| Index scans | postgres.tables.index_scans.count | Number of index scans initiated on this table as reported by pg_stat_user_tables (idx_scan). |
| Rows read by sequential scans | postgres.tables.rows_read_seq.count | Number of live rows fetched by sequential scans as reported by pg_stat_user_tables (seq_tup_read). |
| Rows read by index scans | postgres.tables.rows_read_idx.count | Number of live rows fetched by index scans as reported by pg_stat_user_tables (idx_tup_fetch). |
| Rows inserted | postgres.tables.rows_inserted.count | Number of rows inserted into this table as reported by pg_stat_user_tables (n_tup_ins). |
| Rows updated | postgres.tables.rows_updated.count | Number of rows updated in this table as reported by pg_stat_user_tables (n_tup_upd). |
| Rows deleted | postgres.tables.rows_deleted.count | Number of rows deleted from this table as reported by pg_stat_user_tables (n_tup_del). |
| HOT updates | postgres.tables.hot_updates.count | Number of rows HOT updated in this table, where no separate index update was needed, as reported by pg_stat_user_tables (n_tup_hot_upd). |
| Table disk block reads | postgres.tables.table_disk_reads.count | Number of disk blocks read from this table as reported by pg_statio_user_tables (heap_blks_read). |
| Table buffer hits | postgres.tables.table_buffer_hits.count | Number of buffer hits for this table as reported by pg_statio_user_tables (heap_blks_hit). |
| Index disk block reads | postgres.tables.index_disk_reads.count | Number of disk blocks read from all indexes on this table as reported by pg_statio_user_tables (idx_blks_read). |
| Index buffer hits | postgres.tables.index_buffer_hits.count | Number of buffer hits for all indexes on this table as reported by pg_statio_user_tables (idx_blks_hit). |
| TOAST disk block reads | postgres.tables.toast_disk_reads.count | Number of disk blocks read from this table's TOAST table as reported by pg_statio_user_tables (toast_blks_read). |
| TOAST buffer hits | postgres.tables.toast_buffer_hits.count | Number of buffer hits for this table's TOAST table as reported by pg_statio_user_tables (toast_blks_hit). |
| TOAST index disk block reads | postgres.tables.toast_index_disk_reads.count | Number of disk blocks read from this table's TOAST table indexes as reported by pg_statio_user_tables (tidx_blks_read). |
| TOAST index buffer hits | postgres.tables.toast_index_buffer_hits.count | Number of buffer hits for this table's TOAST table indexes as reported by pg_statio_user_tables (tidx_blks_hit). |
| Manual vacuums | postgres.tables.vacuum.count | Number of times this table has been manually vacuumed (not counting VACUUM FULL) as reported by pg_stat_user_tables (vacuum_count). |
| Autovacuums | postgres.tables.autovacuum.count | Number of times this table has been vacuumed by the autovacuum daemon as reported by pg_stat_user_tables (autovacuum_count). |
| Manual analyzes | postgres.tables.analyze.count | Number of times this table has been manually analyzed as reported by pg_stat_user_tables (analyze_count). |
| Autoanalyzes | postgres.tables.autoanalyze.count | Number of times this table has been analyzed by the autovacuum daemon as reported by pg_stat_user_tables (autoanalyze_count). |
| WAL files size | postgres.wal_files_size | Total size of all WAL files in the WAL directory |
| WAL files count | postgres.wal_files | Total number of WAL files in the WAL directory |
| WAL files age | postgres.wal_files_age | Time elapsed since the oldest WAL file was modified |
| WAL write | postgres.wal_write.count | Number of times WAL buffers were written out to disk via XLogWrite request |
| WAL sync | postgres.wal_sync.count | Number of times WAL files were synced to disk via issue_xlog_fsync request |
| WAL write time | postgres.wal_write_time.count | Total amount of time spent writing WAL buffers to disk via XLogWrite request, in milliseconds |
| WAL sync time | postgres.wal_sync_time.count | Total amount of time spent syncing WAL files to disk via issue_xlog_fsync request, in milliseconds |
| WAL diff size | postgres.wal_diff_size | Size of difference between current WAL and last WAL replay |
| WAL records per minute | postgres.wal_records.count | Number of WAL records generated per minute |
| WAL fpi per minute | postgres.wal_fpi.count | Number of WAL full page images generated per minute |
| WAL bytes | postgres.wal_bytes.count | Total amount of WAL generated in bytes |
| WAL buffers full | postgres.wal_buffers_full.count | Number of times WAL data was written to disk because WAL buffers became full |
| I/O reads | postgres.io.reads.count | Number of read operations as reported by pg_stat_io. |
| I/O read time | postgres.io.read_time.count | Time spent waiting for read operations as reported by pg_stat_io. |
| I/O writes | postgres.io.writes.count | Number of write operations as reported by pg_stat_io. |
| I/O write time | postgres.io.write_time.count | Time spent waiting for write operations as reported by pg_stat_io. |
| I/O writebacks | postgres.io.writebacks.count | Number of units of size BLCKSZ (typically 8kB) which the process requested the kernel write out to permanent storage as reported by pg_stat_io. |
| I/O writeback time | postgres.io.writeback_time.count | Time spent waiting for writeback operations as reported by pg_stat_io. |
| I/O extends | postgres.io.extends.count | Number of relation extend operations as reported by pg_stat_io. |
| I/O extend time | postgres.io.extend_time.count | Time spent waiting for extend operations as reported by pg_stat_io. |
| I/O hits | postgres.io.hits.count | The number of times a desired block was found in a shared buffer as reported by pg_stat_io. |
| I/O evictions | postgres.io.evictions.count | Number of times a block has been written out from a shared or local buffer in order to make it available for another use as reported by pg_stat_io. |
| I/O reuses | postgres.io.reuses.count | The number of times an existing buffer in a size-limited ring buffer outside of shared buffers was reused as part of an I/O operation as reported by pg_stat_io. |
| I/O fsyncs | postgres.io.fsyncs.count | Number of fsync calls as reported by pg_stat_io. |
| I/O fsync time | postgres.io.fsync_time.count | Time spent waiting for fsync operations as reported by pg_stat_io. |
| I/O read bytes | postgres.io.read_bytes.count | The total size of read operations as reported by pg_stat_io. |
| I/O write bytes | postgres.io.write_bytes.count | The total size of write operations as reported by pg_stat_io. |
| I/O extend bytes | postgres.io.extend_bytes.count | The total size of relation extend operations as reported by pg_stat_io. |
| Active backend processes | postgres.activity.active | Number of server processes executing a query |
| Active waiting backend processes | postgres.activity.active_waiting | Number of server processes actively waiting |
| Idle backend processes | postgres.activity.idle | Number of server processes waiting for a new client command |
| Idle in transaction backends processes | postgres.activity.idle_in_transaction | Number of server processes in transaction not currently executing a query |
| Idle in transaction aborted backends processes | postgres.activity.idle_in_transaction_aborted | Number of server processes in transaction not currently executing a query where one of the statements caused an error |
| Fast-path function backend processes | postgres.activity.fastpath_function_call | Number of server processes executing a fast-path function call |
| Tablespace size | postgres.tablespace.size | Tablespace size in bytes |
| Buffers written by background writer | postgres.buffers_clean.count | Number of buffers written by the background writer |
| Cleaning scan stops | postgres.maxwritten_clean.count | Number of times the background writer stopped a cleaning scan because it had written too many buffers |
| Buffers allocated | postgres.buffers_alloc.count | Number of buffers allocated |
| Scheduled checkpoints performed | postgres.checkpoints_timed.count | Number of scheduled checkpoints that have been performed |
| Requested checkpoints performed | postgres.checkpoints_req.count | Number of requested checkpoints that have been performed |
| Checkpoints write time | postgres.checkpoint_write_time.count | Total amount of time that has been spent in the portion of checkpoint processing where files are written to disk |
| Checkpoint sync time | postgres.checkpoint_sync_time.count | Total amount of time that has been spent in the portion of checkpoint processing where files are synchronized to disk |
| Buffers written during checkpoints | postgres.buffers_checkpoint.count | Number of buffers written during checkpoints |
| Buffers written by backend | postgres.buffers_backend.count | Number of buffers written directly by a backend |
| Backend fsync executions | postgres.buffers_backend_fsync.count | Number of times a backend had to execute its own fsync call |
| SLRU blocks zeroed | postgres.slru.blks_zeroed.count | Number of blocks zeroed during initializations, as reported by pg_stat_slru. |
| SLRU blocks hit | postgres.slru.blks_hit.count | Number of times disk blocks were found already in the SLRU cache, so that a read was not necessary, as reported by pg_stat_slru. |
| SLRU blocks read | postgres.slru.blks_read.count | Number of disk blocks read, as reported by pg_stat_slru. |
| SLRU blocks written | postgres.slru.blks_written.count | Number of disk blocks written, as reported by pg_stat_slru. |
| SLRU blocks exists | postgres.slru.blks_exists.count | Number of blocks checked for existence, as reported by pg_stat_slru. |
| SLRU flushes | postgres.slru.flushes.count | Number of SLRU flushes of dirty data, as reported by pg_stat_slru. |
| SLRU truncates | postgres.slru.truncates.count | Number of SLRU truncates, as reported by pg_stat_slru. |
| Number of locks | postgres.locks | Number of locks as reported by pg_locks |
| Subscription stats - apply error | postgres.subscription_stats.apply_error.count | Number of times an error occurred while applying changes, as reported by pg_stat_subscription_stats. |
| Subscription stats - sync error | postgres.subscription_stats.sync_error.count | Number of times an error occurred during the initial table synchronization, as reported by pg_stat_subscription_stats. |
| Subscription stats conflict - insert exists | postgres.subscription_stats.confl_insert_exists.count | Number of times a row insertion violated a NOT DEFERRABLE unique constraint during the application of changes, as reported by pg_stat_subscription_stats. |
| Subscription stats conflict - update origin differs | postgres.subscription_stats.confl_update_origin_differs.count | Number of times an update operation was applied to a row that had been previously modified by another source during the application of changes, as reported by pg_stat_subscription_stats. |
| Subscription stats conflict - update exists | postgres.subscription_stats.confl_update_exists.count | Number of times that an updated row value violated a NOT DEFERRABLE unique constraint during the application of changes, as reported by pg_stat_subscription_stats. |
| Subscription stats conflict - update missing | postgres.subscription_stats.confl_update_missing.count | Number of times the tuple to be updated was not found during the application of changes, as reported by pg_stat_subscription_stats. |
| Subscription stats conflict - delete origin differs | postgres.subscription_stats.confl_delete_origin_differs.count | Number of times a delete operation was applied to row that had been previously modified by another source during the application of changes, as reported by pg_stat_subscription_stats. |
| Subscription stats conflict - missing delete | postgres.subscription_stats.confl_delete_missing.count | Number of times the tuple to be deleted was not found during the application of changes, as reported by pg_stat_subscription_stats. |
| Subscription stats conflict - multiple unique conflicts | postgres.subscription_stats.confl_multiple_unique_conflicts.count | Number of times a row insertion or an updated row values violated multiple NOT DEFERRABLE unique constraints during the application of changes, as reported by pg_stat_subscription_stats. |
| Latest transaction XID age | postgres.xid_age | Difference between the current transaction's XID and datfrozenxid. If this value exceeds 2^31, this can cause a database crash due to transaction ID wraparound. |
| Number of backends | postgres.numbackends | Number of backends currently connected to this database |
| Committed transactions | postgres.xact_commit.count | Number of transactions in this database that have been committed |
| Rolled back transactions | postgres.xact_rollback.count | Number of transactions in this database that have been rolled back |
| Block read from disk | postgres.blks_read.count | Number of disk blocks read in this database |
| Blocks found in buffer cache | postgres.blks_hit.count | Number of times disk blocks were found already in the buffer cache, so that a read was not necessary |
| Live rows returned | postgres.tup_returned.count | Number of live rows fetched by sequential scans and index entries returned by index scans in this database |
| Live rows fetched by index scans | postgres.tup_fetched.count | Number of live rows fetched by index scans in this database |
| Rows inserted | postgres.tup_inserted.count | Number of rows inserted by queries in this database |
| Rows updated | postgres.tup_updated.count | Number of rows updated by queries in this database |
| Rows deleted | postgres.tup_deleted.count | Number of rows deleted by queries in this database |
| Queries canceled due to conflict | postgres.conflicts.count | Number of queries canceled due to conflicts with recovery in this database |
| Temporary files created | postgres.temp_files.count | Number of temporary files created by queries in this database |
| Data written to temporary files | postgres.temp_bytes.count | Total amount of data written to temporary files by queries in this database |
| Deadlocks | postgres.deadlocks.count | Number of deadlocks detected in this database |
| Data file blocks reading time | postgres.blk_read_time.count | Time spent reading data file blocks by backends in this database |
| Data file blocks writing time | postgres.blk_write_time.count | Time spent writing data file blocks by backends in this database |
| Database Size | postgres.db_size | Size of the database in bytes |
| Time spent by sessions | postgres.session_time.count | Time spent by database sessions in this database |
| Time spent executing SQL statements | postgres.active_time.count | Time spent executing SQL statements in this database |
| Time spent idling | postgres.idle_in_transaction_time.count | Time spent idling while in a transaction in this database |
| Data page checksum failures | postgres.checksum_failures.count | Number of data page checksum failures detected in this database. Only available if data checksums are enabled. |
| Established sessions | postgres.sessions.count | Total number of sessions established |
| Abandoned sessions | postgres.sessions_abandoned.count | Number of database sessions to this database that were terminated because connection to the client was lost |
| Fatal error terminated sessions | postgres.sessions_fatal.count | Number of database sessions to this database that were terminated by fatal errors |
| Killed sessions | postgres.sessions_killed.count | Number of database sessions to this database that were terminated by operator intervention |
| User function calls | postgres.user_functions.calls.count | Number of times this function has been called, as reported by pg_stat_user_functions. |
| User functions total time | postgres.user_functions.total_time.count | Total time spent in this function and all other functions called by it, as reported by pg_stat_user_functions. |
| User functions self time | postgres.user_functions.self_time.count | Total time spent in this function itself, not including other functions called by it, as reported by pg_stat_user_functions. |
Top queries: For security reasons, ALTER statements are excluded from top query collection.
Execution plan details:
extensions:configuration.actions:write permission is required to trigger the execution plan fetching.dynatrace.dynatrace_execution_plan function has been created.This extension runs from your Dynatrace ActiveGates and connects to the configured databases. Once the connection is established, the extension regularly runs queries on the database to gather performance and health metrics, reporting the results back to Dynatrace.
The extension executes only SELECT queries to collect data. To see exactly which queries run, download the extension yaml artifact: open the Release notes, select a release, and select Download version.
From version 2.3.0 onwards, the configuration variables query-interval and heavy-query-interval control query execution frequency. Most of the queries executed by the extension run every query-interval minutes (with a default of 1 minute), while the queries under the Queries feature set run every heavy-query-interval minutes (with a default of 5 minutes).
For older versions, most queries run every minute. The heavy queries mentioned above run every 5 minutes.
Supporting a wide range of Postgres versions requires running several versions of the same queries in parallel, since Postgres has changed column names for several tables over time. Some query failures are expected. As long as no data is missing, there is no cause for concern.
