Get insights into your OpenShift control plane with metrics from its components.
This is an extension for monitoring the OpenShift control plane and comes with an out-of-the-box dashboard and pre-configured alerts. The OpenShift Control Plane extension only requires metrics already ingested into Dynatrace via Prometheus integration.
Use this extension to:
The extension supports:
1.252+.To set up the extension
Enable Prometheus monitoring in Dynatrace.
Start ingesting control plane metrics.
To ingest metrics exposed by the OpenShift control plane, the related services need to be annotated with specific Dynatrace annotations. Based on the used OpenShift version, the YAML files referenced in the commands below define a default set of annotations, enabling the ingestion of all metrics used by the OpenShift control plane extension. Before executing any of the instructions below, ensure your kubectl is configured to use the Kubernetes cluster you want to monitor. If the default set of annotations fits your needs, use the corresponding instructions below. Otherwise, download the files first and adapt them accordingly.
kubectl apply -f https://raw.githubusercontent.com/dynatrace-extensions/kubernetes-control-plane/main/scripts/control-plane-monitoring-annotations-ocp4.yaml
kubectl apply -f https://raw.githubusercontent.com/dynatrace-extensions/kubernetes-control-plane/main/scripts/control-plane-monitoring-annotations-ocp3.yaml
Ensure that you have an active OpenShift Control Plane extension in your environment.
After some minutes, you can verify if everything works as expected by finding control plane related metrics in
Notebooks. kube_pod_status_ready is one of the metrics to search for.
Additionally, the extension comes with multiple pre-configured metric events for alerting. To activate them:
To uninstall the extension
Stop ingesting control plane metrics and remove the metric annotations from the related services. If you followed the instructions described in the "Start ingesting control plane metrics" section, you can use kubectl to remove the annotations, by referencing the previously applied file in a kubectl delete -f command, as shown below for the default YAML files. Before executing any of the instructions below, ensure your kubectl is configured to use the right Kubernetes cluster.
kubectl delete -f https://raw.githubusercontent.com/dynatrace-extensions/kubernetes-control-plane/main/scripts/control-plane-monitoring-annotations-ocp4.yaml
kubectl delete -f https://raw.githubusercontent.com/dynatrace-extensions/kubernetes-control-plane/main/scripts/control-plane-monitoring-annotations-ocp3.yaml
Deactivate the extension via the Dynatrace Hub.
