Collect NetApp OnTap metrics via OnTap 9.6+ API to monitor your clusters.
Collect NetApp OnTap metrics via OnTap 9.6+ API and Dynatrace Intelligence to monitor your clusters.
The NetApp OnTap (Remote) extension allows you to collect, view, and analyze metrics from your NetApp OnTap clusters both on the cluster level and for each of your nodes and storage virtual machines (SVMs).
9.6+ with a reachable REST API3.5.1+) in your environmenthttp application access that is assigned a rest-role with at least read-only access to the following API paths:
/api/cluster/api/cluster/nodes/api/snapmirror/relationships/api/storage/aggregates/api/storage/cluster/api/storage/disks/api/storage/luns/api/storage/pools/api/storage/volumes/api/svm/svms9.6+.https://ontap-prod>/.http://proxy.example.com:8080>.INFO. We recommend using DEBUG logging only when investigating issues with support.2.3.2 of the NetApp OnTap (Remote) extension, rules are included to allow linking of this extension's netapp_ontap:volume entity to the vmware:datastore from the VMware remote monitoring extension. This linking is done via the same as relationship and is based on the volume's name matching the datastore's NAS remote path property.There is no charge to use the extension. You are only charged for the data that the extension ingests.
The NetApp OnTap (Remote) extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
The approximate number of metric data points per minute is:
16 + (4 * <nodes>) + (1 * <frus>) + (1 * <svms>) + (2 * <disks>) + (5 * <aggregates>) + (20 * <volumes>) + (4 * <volume of svm with qos policy>) + (3 * <snapmirror relationships>)
The above formula assumes that all feature sets are enabled. You'll need to adjust the formula if you reconfigured the frequency of metric collection.
This extension will additionally report log events in 2 situations:
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
For logs, regular consumption applies. See Log Analytics.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
For logs, regular DDU consumption applies. See DDU consumption for Log Management and Analytics or DDUs for Log Monitoring Classic.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
| Metric name | Metric key | Description |
| SVM state | netapp.ontap.svm.state | Current SVM state: starting, running, stopping, stopped,or deleting |
| Volume state | netapp.ontap.volume.state | Volume state: error, mixed, offline, or online |
| Volume throughput (other) | netapp.ontap.volume.throughput.other.count | The volume's rate of throughput bytes observed at the storage object (other) |
| Volume throughput (read) | netapp.ontap.volume.throughput.read.count | The volume's rate of throughput bytes observed at the storage object (read) |
| Volume throughput (write) | netapp.ontap.volume.throughput.write.count | The volume's rate of throughput bytes observed at the storage object (write) |
| Volume throughput (total) | netapp.ontap.volume.throughput.total.count | The volume's rate of throughput bytes observed at the storage object (total) |
| Volume IOPS (other) | netapp.ontap.volume.iops.other.count | The volume's number of I/O operations observed at the storage object (other) |
| Volume IOPS (read) | netapp.ontap.volume.iops.read.count | The volume's number of I/O operations observed at the storage object (read) |
| Volume IOPS (write) | netapp.ontap.volume.iops.write.count | The volume's number of I/O operations observed at the storage object (write) |
| Volume IOPS (total) | netapp.ontap.volume.iops.total.count | The volume's number of I/O operations observed at the storage object (total) |
| Volume latency (total) | netapp.ontap.volume.latency.total | The volume's latency calculated as raw latency divided by operations (total) |
| Volume latency (read) | netapp.ontap.volume.latency.read | The volume's latency calculated as raw latency divided by operations (read) |
| Volume latency (write) | netapp.ontap.volume.latency.write | The volume's latency calculated as raw latency divided by operations (write) |
| Volume latency (other) | netapp.ontap.volume.latency.other | The volume's latency calculated as raw latency divided by operations (other) |
| Volume size | netapp.ontap.volume.size | Total provisioned size |
| Volume space available | netapp.ontap.volume.available | The available space |
| Volume space used | netapp.ontap.volume.used | Volume space used (including data and metadata) |
| Volume space used percentage | netapp.ontap.volume.used_percent | Percentage of volume space used (including data and metadata) |
| Maximum files (inodes) | netapp.ontap.volume.files.maximum | The maximum number of files (inodes) for user-visible data allowed on the volume. |
| Files (inodes) | netapp.ontap.volume.files.used | Number of files (inodes) used for user-visible data permitted on the volume. |
| Files (inodes) used percentage | netapp.ontap.volume.files.used_percentage | Percentage of the maximum number of files used on the volume. |
| Storage pool total capacity | netapp.ontap.pool.total_capacity | Total size of the flash pool, in bytes. |
| Storage pool usable capacity | netapp.ontap.pool.usable_capacity | Remaining usable capacity in the flash pool, in bytes. |
| Storage pool used capacity | netapp.ontap.pool.used_capacity | Used capacity in the flash pool, in bytes. |
| Storage pool total capacity | netapp.ontap.pool.used_percentage | Percentage of capacity used in the flash pool. |
| LUN state | netapp.ontap.lun.state | The state of the LUN. Normal states for a LUN are online and offline. Other states indicate errors |
| LUN container state | netapp.ontap.lun.container_state | The state of the volume and aggregate that contain the LUN. LUNs are only available when their containers are available |
| LUN enabled state | netapp.ontap.lun.enabled | The enabled state of the LUN. LUNs can be disabled to prevent access to the LUN. 1 = enabled, 0 = disabled |
| LUN space used | netapp.ontap.lun.used | The amount of space consumed by the main data stream of the LUN |
| LUN size | netapp.ontap.lun.size | The total provisioned size of the LUN |
| LUN space used percentage | netapp.ontap.lun.used_percentage | Space used in the LUN as a percentage |
| Node uptime | netapp.ontap.node.uptime | How long the node reports it has been running |
| Over temperature | netapp.ontap.node.over_temperature | Specifies whether the hardware is currently operating outside of its recommended temperature range (0 = "normal", 1 = "over"). |
| Node membership | netapp.ontap.node.membership | Membership status of the cluster node |
| Node processor utilization | netapp.ontap.node.processor_utilization | Average CPU Utilization for the node |
| FRU state | netapp.ontap.node.fru.state | State of the field replaceable unit (100% for OK 0% for ERROR)) |
| Cluster availability | netapp.ontap.cluster.availability | Connectivity to the configured OnTap cluster URL as detected by the extension |
| Cluster IOPS (other) | netapp.ontap.cluster.iops_other.count | The cluster's number of I/O operations observed at the storage object (other) |
| Cluster IOPS (read) | netapp.ontap.cluster.iops_read.count | The cluster's number of I/O operations observed at the storage object (read) |
| Cluster IOPS (total) | netapp.ontap.cluster.iops_total.count | The cluster's number of I/O operations observed at the storage object (total) |
| Cluster IOPS (write) | netapp.ontap.cluster.iops_write.count | The cluster's number of I/O operations observed at the storage object (write) |
| Cluster throughput (other) | netapp.ontap.cluster.throughput_other.count | The cluster's rate of throughput bytes observed at the storage object (other) |
| Cluster throughput (read) | netapp.ontap.cluster.throughput_read.count | The cluster's rate of throughput bytes observed at the storage object (read) |
| Cluster throughput (total) | netapp.ontap.cluster.throughput_total.count | The cluster's rate of throughput bytes observed at the storage object (total) |
| Cluster throughput (write) | netapp.ontap.cluster.throughput_write.count | The cluster's rate of throughput bytes observed at the storage object (write) |
| Cluster latency (other) | netapp.ontap.cluster.latency_other.count | The cluster's raw latency in microseconds observed at the storage object (other) |
| Cluster latency (read) | netapp.ontap.cluster.latency_read.count | The cluster's raw latency in microseconds observed at the storage object (read) |
| Cluster latency (total) | netapp.ontap.cluster.latency_total.count | The cluster's raw latency in microseconds observed at the storage object (total) |
| Cluster latency (write) | netapp.ontap.cluster.latency_write.count | The cluster's raw latency in microseconds observed at the storage object (write) |
| Cluster block storage size | netapp.ontap.cluster.block_storage_size | The size of the cluster's block storage |
| Cluster block storage used | netapp.ontap.cluster.block_storage_used | Amount of block storage on the cluster in use |
| Cluster block storage used percentage | netapp.ontap.cluster.block_storage_used_percentage | The percentage of the cluster's block storage that is currently in use |
| Rated life used | netapp.ontap.disk.rated_life_used_percentage | Percentage of rated life used |
| Disk state | netapp.ontap.disk.state | Current disk state: broken, copy, maintenance, partner, pending, present, reconstructing, removed, spare, unfail, or zeroing |
| Aggregate state | netapp.ontap.aggregate.state | Current aggregate state: online, onlining, offline, offlining, relocating, unmounted, restricted, inconsistent, failed, or unknown |
| Aggregate block storage used | netapp.ontap.aggregate.block_storage_used | Space used or reserved in bytes. Includes volume guarantees and aggregate metadata. |
| Aggregate block storage available | netapp.ontap.aggregate.block_storage_available | Space available in bytes |
| Aggregate block storage size | netapp.ontap.aggregate.block_storage_size | Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve. |
| Aggregate block storage used percentage | netapp.ontap.aggregate.block_storage_used_percent | Percentage of block storage used |
| Volume QOS minimum throughput (IOPS) | netapp.ontap.volume.qos.min_throughput_iops | The minimum throughput in IOPS (volumes) |
| Volume QOS maximum throughput (IOPS) | netapp.ontap.volume.qos.max_throughput_iops | The maximum throughput in IOPS (volumes) |
| Volume QOS maximum throughput (Mbps) | netapp.ontap.volume.qos.max_throughput_mbps | The maximum throughput in Mbps (volumes) |
| Volume QOS minimum throughput (Mbps) | netapp.ontap.volume.qos.min_throughput_mbps | The minimum throughput in Mbps (volumes) |
| SVM QOS minimum throughput (IOPS) | netapp.ontap.svm.qos.min_throughput_iops | The minimum throughput in IOPS (svms) |
| SVM QOS maximum throughput (IOPS) | netapp.ontap.svm.qos.max_throughput_iops | The maximum throughput in IOPS (svms) |
| — | netapp.ontap.svm.qos.max_throughput_mbps | — |
| SVM QOS minimum throughput (Mbps) | netapp.ontap.svm.qos.min_throughput_mbps | The minimum throughput in Mbps (svms) |
| Lag time | netapp.ontap.snapmirror.relationship.lag_time | The time since the exported snapshot was created |
| Relationship state | netapp.ontap.snapmirror.relationship.state | The state of the relationship |
| Relationship health | netapp.ontap.snapmirror.relationship.health | Is the relationship healthy? |
