Create custom user action names for mobile applications
  • Dynatrace Classic
  • How-to guide
  • 1-min read
  • Published Jan 27, 2023
Dynatrace generates names for most user actions automatically. You can define user action naming rules to change the automatically generated names to a predefined name.
To create a user action naming rule
  1. Go to Frontend.
  2. Select the application that you want to configure.
  3. Select More (…) > Edit in the upper-right corner of the tile with your application name.
  4. From the application settings, select Naming Rules.
  5. Expand the x action naming rules section, and then select Add naming rule.
  6. Enter the Resulting user action name and specify the naming rule conditions.
Related topics
  • User actions
Related tags
Digital ExperienceMobileMobile
