Configure a NAM monitor in Classic
  • Dynatrace Classic
  • How-to guide
  • 1-min read
With network availability monitors (NAM), you can check the availability of your hosts, devices, and services.
There are three types of NAM monitors: ICMP, TCP, and DNS. To learn more about them, see NAM types. You can create NAM monitors in Synthetic Synthetic or through API.
NAM setup
With NAM monitors, you can include more than one step.
  • Each step can contain one or multiple requests.
  • Like for HTTP and browser monitors, steps are executed sequentially.
  • Unlike for HTTP and browser monitors, NAM monitors can contain multiple requests within a single step. All requests assigned to a particular step are executed in parallel. If one request fails, it doesn't affect the execution of other requests within that step.
  • A step is skipped if nothing matches its definition in a monitor configuration. For example, when a tag is specified in the target filters list but nothing matches the tag.
  • Concept of requests executed in parallel exists for NAM monitors only
For example, if you want to monitor a group of 4 hosts with an ICMP test, you want to apply the same conditions (such as frequency, location executing test, and number of packets) for each host from your group.
NAM offers you the possibility of addressing this in multiple ways:
  • You can define 4 separate tests, one per host. The benefit of this approach is that Dynatrace triggers a separate problem for each host and you can assign separate notifications for each one. You can also adjust test parameters for each host separately.
  • You can define a single test with 4 requests (within 1 step). The same ICMP checks are executed, but there will be differences in reporting and alerting. The number or percentage of hosts that are down is reported with the Requests Success rate metric. You can configure a customized threshold for failing the whole monitor. For example, if it's OK that 1 out of 4 hosts is down, because of rolling out an update, you can define it on the >=75% level. There's always a single problem generated for a monitor, yet still, it contains detailed info about hosts that don't respond. Another benefit of this approach is easier maintenance (adjusting single setting for all 4 hosts).
    Finally, filters offer defining tests against dynamically changing structure, for example if you want to define ICMP tests against a given host group, you don't need to adjust the NAM monitor test after the host group configuration change.
You need to define constraints for each monitor. Constraints are conditions that need to be met to consider the monitor’s execution successful. It is obligatory to define the Success rate constraint. See step-level constraints to learn more.
Create a NAM monitor
To create a NAM monitor in latest Dynatrace
  1. Go to Synthetic Synthetic and select Create monitor.
  2. Follow the on-screen steps as outlined in the sections below.
Select type
The Create synthetic monitor page shows the types of synthetic monitor you can create.
Select Network monitor (NAM) to get started.
General
  • Required Provide the Monitor name as it will be displayed in the web UI (up to 500 characters).
  • Required Select a protocol—choose the monitor type: DNS, ICMP, or TCP.
  • Optional Set a description—describe your monitor.
  • Optional To manually create a new tag, select Add tag in Tags, type the Key, optionally provide a Value, and select Add.
  • Optional To manually create a new Primary Grail tag, select Add tag in Primary Grail® tags, type the Key and Value, and select Add. For details, see Primary Grail tags for Synthetic.
After you specify the general settings, select Continue.
Requests
The Requests section has two editing modes. You can switch back and forth between these modes.
  • default Visual—to view and configure NAM requests through web UI settings.
  • Script—to view and edit request settings as JSON. The script you provide also serves as payload for API requests.
Settings per request (you can add multiple requests) are:
  • Required Request name—The name of the request.
  • Required List of targets or Filter expression
    • You can provide targets for requests as an explicit list, or filter monitored hosts using a filter expression.
      • If you want to provide targets as IP or domain names, use List of targets to specify a comma-separated list of targets. Use this to monitor single or multiple hosts, devices, or services.
      • If you want to select some of the monitored hosts or custom devices, use Filter expression to specify a filter expression. This allows you to monitor a group of hosts or custom devices that meet the filter criteria. To learn more about available filters, see target filter.
      You can combine both the List of targets and the Filter expression in a single monitor step. When used together, the monitor step will include the combined set of targets from both fields.
  • Required Execution attributes—Execution attributes are essentially key/value pairs that are associated with your request. Define Request timeout, Number of packets, Data length, Time to live, Timeout to reply, you can also turn on or turn off Do not fragment data. Execution attributes are available for ICMP only.
  • Required Constraints—Constraints are conditions that need to be met to consider monitor’s execution successful. You need to define Constraint type, Operator and value.
If you want to create another request, select Add next request and specify the above for the next request.
Use Duplicate to duplicate a request and then edit it from that point instead of starting from scratch each time you add a request.
After you specify all requests, select Continue.
Frequency and locations
In the Frequency and locations section, specify the frequency and locations.
  • Required Select frequency—You can choose a frequency (every 1 min, 2 min, 5 min, 10 min, 15 min, 30 min, or 1 h) or select On demand only for manual execution.
  • Required n selected locations—Specify one or more locations.
After you specify the frequency and locations, select Continue.
Outage and Performance
In Outage handling, you can enable and configure the following settings related to problem and alert generation:
  • Optional "Generate a problem and send an alert when the monitor is unavailable at all configured locations (global outage)."
  • Optional "Generate a problem and send an alert when the monitor is unavailable only when at least two locations are assigned." Note that this option is only possible if you selected two or more locations.
  • Optional "Generate a problem and send an alert on performance threshold violations."
After you specify the outage and performance settings, select Continue.
Summary
In the Summary section, verify your settings.
After you review the summary, select Save to create your monitor or Back to go back and adjust your monitor settings.
Target filter
Target filter gives an option to filter hosts monitored by Dynatrace or custom devices having IP addresses. With this filter, you can select those two types of targets based on:
  • type (type)
  • tags (tag)
  • host ID (hostId) (deprecated, works for hosts only, use entity ID instead)
  • entity ID (entityId)
  • host groups (hostGroup)
  • management zones (managementZone)
  • IP mask (ipMask)
  • IP range (ipRange)
  • process group instance (processGroupInstance)
  • network interfaces of particular custom device (interfacesOf)
  • extension name (extensionName)
IP range and IP mask are filters for hosts or devices known for the Dynatrace server, not an option to scan the network.
Syntax
  • Logical operators: AND and OR (case insensitive)
  • Parentheses
  • Expression operators: == and !=
  • Tag names and values
  • Negation ("not"): !=.
  • Wildcard: * (selects all hosts monitored by Dynatrace)
Examples
  • tag == tagname or hostGroup == group1
  • (tag == tagname1:tagvalue1 or tag == tagname1:tagvalue2) and (hostGroup == group1 or managementZone == zone1)
  • tag != tagname1 and tag != tagname2:tagvalue
  • tag == tagname:tagvalue and (managementZone == zone1 or managementZone == zone2)
  • tag == "[tagwithbrackets and spaces]":"value, with, commas, and, spaces"
  • ipMask == 127.0.0.1/24
  • hostId == HOST-000123
  • type == CUSTOM_DEVICE and ipMask == 172.17.0.2/24
  • entityId == HOST-045BFCDA3F507D30 or entityId == CUSTOM_DEVICE-13081D4B74B3E2C8
  • type == HOST and processGroupInstance == PROCESS_GROUP_INSTANCE-07611353BB98908C
  • type == CUSTOM_DEVICE and interfacesOf == CUSTOM_DEVICE-E1A88946BF04D5E7
  • type == CUSTOM_DEVICE and extensionName == "Docker devices"
Performance thresholds
The performance threshold metric is compared to metric calculated for each request within monitor/step. For example, if TCP port check monitor, tests on the same host port 80 and 443 separately, Dynatrace compares threshold TCP connection establishment time twice, once for port 80 and once for port 443.
There are three performance metrics for three types of NAM monitors:
  • RTT for ICMP
  • TCP connection establishment time for TCP
  • DNS resolution time for DNS
Violating defined performance triggers a Problem (Slowdown).
Similarly to availability problems:
  • Problems are opened per monitor
  • Contains information about all requests responsible for problem
You can configure the way Dynatrace aggregates results for each packet for ICMP requests with single execution. Dynatrace supports AVG, MAX and MIN with AVG as the default method.
Define thresholds
You can define performance thresholds when configuring the request for your synthetic monitor. The defined performance threshold is the same for all requests within a single step. In cases, where there's a need to build a multi-step NAM monitor, it's possible to define various thresholds for each step.
To define thresholds
  1. Follow the steps described in Create a NAM monitor section.
  2. In the Requests step, scroll down the page and see Performance thresholds alerting section.
  3. Select Generate a problem and send an alert on performance threshold violations. check box.
  4. Turn on Advanced performance thresholds settings toggle.
    In this section you can set the Number of request executions in analyzed sliding window and the Number of violating request executions in analyzed sliding window. For de-alerting samples we require n most recent non-violating request executions.
Violation reporting
Red color annotation over performance charts indicates the period of time during which the performance threshold is raised. Additionally, a threshold is drawn on the performance chart, and you can examine which requests are above the threshold.
You may narrow down the time range only to that for which the problem was active using zoom functionality.
Manage NAM monitors with API
To manage your NAM monitors via REST API
  1. Search for and select Dynatrace API.
  2. In the Select a definition field, select Synthetic - Network availability monitors.
  3. Authenticate with your API token.
    For details, see Authentication.
  4. Perform one of the following actions.
    To do thisGo to Synthetic - Network availability monitors and select this
    Get all synthetic monitors
    GET /synthetic/monitors
    Create a synthetic monitor definition
    POST /synthetic/monitors
    Delete a synthetic monitor definition for the given monitor ID
    DELETE /synthetic/monitors/{monitorId}
    Get all synthetic monitor definition for the given monitor ID
    GET /synthetic/monitors/{monitorId}
    Update a synthetic monitor definition for the given monitor ID.
    PUT /synthetic/monitors/{monitorId}
See Synthetic monitors API v2 for more details.
Available script configuration properties
Optional
Monitors consist of requests, always of the same type (ICMP, TCP, or DNS).
If you don't provide the value, defaults will apply.
Duration format examples
  • 100 milliseconds = PT0.1S
  • 500 milliseconds = PT0.5S
  • 1 second = PT1S
  • 10 seconds = PT10S
  • 90 seconds = PT1M30S
  • 1 minute = PT1M
  • 2 minutes = PT2M
  • 5 minutes = PT5M
ICMP
NameTypeDescriptionValuesDefault value
EXECUTION_TIMEOUT
string:duration
Timeout for the execution of a single request.
Valid duration, for example, PT1S.
Range = 0–PT2M
ICMP_NUMBER_OF_PACKETS × ICMP_TIMEOUT_FOR_REPLY + 1s
integer
Number of echo requests. The equivalent of the ping process are the -c (Linux) and -n (Windows) parameters.
Range = 1–10
1
ICMP_PACKET_SIZE
integer
Data length. The equivalent of the ping process are the -s (Linux) and -l (Windows) parameters.
Range = 0–65500
32
ICMP_TIME_TO_LIVE
integer
Time to live (TTL). The equivalent of the ping process are the -t (Linux) and -i (Windows) parameters.
Range = 1–255
ICMP_TYPE_OF_SERVICE
integer
Type of service. The equivalent of the ping process are the -Q (Linux) and -v (Windows) parameters.
Range = 0–255
ICMP_DO_NOT_FRAGMENT_DATA
boolean
Do not fragment. The equivalent of the ping process are the -M do (Linux) and -f (Windows) parameters.
true or false
string:duration
Wait for the echo reply message.
The equivalent of the ping process are the -W (Linux) and -w (Windows) parameters.
Valid duration, for example, PT1S. On Windows values like PT1.1S are accepted (granularity in milliseconds).
On Linux, values like PT1S are required (granularity in seconds).
Range = PT1S–PT2S
PT1S
The packet transmission interval is hardcoded to 200ms, which corresponds to the minimum value allowed for the -i option of the Linux ping command without requiring elevated privileges.
TCP
TCP_PORT_RANGES
string
Comma-separated list of port ranges
A single range can be either a single port number or a range of ports, defined as two port numbers with a hyphen.
The final list of requests to be executed is the product of all defined ports and target hosts. For example, if a step has two target hosts (1.1.1.1 and 2.2.2.2) and a range of two ports (80-81), four requests are executed within such a step.
  • Request to 1.1.1.1 on port 80
  • Request to 1.1.1.1 on port 81
  • Request to 2.2.2.2 on port 80
  • Request to 2.2.2.2 on port 81
Sample values
  • 8080
  • 8000-9000
  • 80,443,90-100
EXECUTION_TIMEOUT
string:duration
Connection timeout
Range = 0–PT2M
1s
DNS
DNS_RECORD_TYPES
string
Comma-separated list of DNS record types.
The final list of requests executed is the product of all defined record types and target hosts. For example, if a step has two record types (A,AAAA) and two target hosts (host1.domain.com and host2.domain.com), four requests are executed within such a step.
  • Request for A record contents for host1.domain.com
  • Request for AAAA record contents for host1.domain.com
  • Request for A record contents for host2.domain.com
  • Request or AAAA record contents for host2.domain.com
Sample values
  • A
  • A,AAAA
  • A,AAAA,CNAME
EXECUTION_TIMEOUT
string:duration
Connection timeout
Range = 0–PT2M
2s
DNS_SERVER
string
Address of the DNS server to query, with optional port
If a hostname is provided, it's resolved to an IP address using the system default DNS server.
Valid address, such as:
  • 1.1.1.1
  • 8.4.4.8:53
  • dns.google
  • dns9.quad9.net:53
If only host is provided, the default port 53 is used.
If no value is provided, the system default DNS server and port are used.
DNS_FORCE_TCP
boolean
By default, the DNS server is queried over a UDP connection, unless the message is too large to fit the UDP datagram. This option allows you to specify a TCP connection instead.
true or false
false
Script configuration constraints
Constraints are conditions that need to be met to consider monitor’s execution successful. You need to define constraints for each monitor.
Step-level constraints
SUCCESS_RATE_PERCENT
Required
This is an obligatory constraint for all monitors' request success rate. The default value is >=80%.
Percentage of successful requests in a step.
Actual success rate = ratio of the number of requests that didn't fail to all requests.
For example, if 1 request out of 6 has failed, the ratio is (6-1)/6 = 83.33%.
PropertyTypeDescriptionValueDefault value
operator
string
Comparison operator to compare actual and expected value
>=, >, <=, <, =, or !=
value
integer
Expected value of success rate to use for comparison
Range = 0–100
80
"type": "SUCCESS_RATE_PERCENT",
"properties": {
"value": "80",
"operator": ">"
For requests with only one target, we suggest setting the constraints values to 100.
Request-level constraints
ICMP request constraints
ICMP_SUCCESS_RATE_PERCENT
Required
This is an obligatory constraint for ICMP monitors request success rate. The default value is >=80%.
Percentage of successful pings (echo requests) in a request.
Actual success rate = ratio of number of the packets received to number of packets sent.
For example, if 5 packets were sent and 4 packets were received, the ratio is 4/5 = 80.00%.
operator
string
value
integer
Range = 0–100
80
"type": "ICMP_SUCCESS_RATE_PERCENT",
"properties": {
"value": "80",
"operator": ">"
TCP request constraints
TCP_PORT_UNREACHABLE
Optional
This is an optional constraint for TCP monitors. This is a special constraint that inverts the execution status for TCP requests. It should be applied if it's expected that the port being checked is unreachable.
This constraint has no configuration properties.
If this constraint is applied:
  • When the Execution timeout (12033) and TCP socket connection error (22000) statuses are detected after performing a connection attempt, they are interpreted as HEALTHY (0).
  • The HEALTHY (0) connection status is interpreted as CONSTRAINT_VIOLATED (1401) because we expected a failure.
  • The UNEXPECTED_ERROR (-1) and UNKNOWN_HOST (12013) statuses are preserved and reported as is.
"type": "TCP_PORT_UNREACHABLE",
"properties": {}
DNS request constraints
At least one required
DNS constraints are optional, but at least one must be defined to indicate what is a successful query.
DNS_STATUS_CODE
DNS_STATUS_CODE by default is 1, having status code =0 is the simplest example of a successful query.
operator
string
= or !=
statusCode
integer
Numeric code indicating status of DNS responseExclusive with status
Valid code, for example, 0Range = 0–65535
0
status
string
Mnemonic representing DNS status codeExclusive with statusCode
Valid status, for example, NOERROR
NOERROR
"type": "DNS_STATUS_CODE",
"properties": {
"operator": "=",
"statusCode": "0"
"properties": {
"operator": "=",
"status": "NOERROR"
DNS_IP_ADDRESS
Verifies the IP address value returned in A/AAAA records.
quantifier
string
How many records must match the condition for the constraint to pass
any (at least one) or all
any
operator
string
Comparison operator
=, != or in
= for an address, in for a subnet
recordType
string
DNS record type
A or AAAA
A if address/subnet is IPv4AAAA if address/subnet is IPv6
address
string
IPv4 address in dot notation or IPv6 address in colon notationOnly with the operators =, !=Exclusive with subnet
Valid address, for example, 192.168.0.1, 2001:db8::2:1
subnet
string
IPv4 subnet in dot notation or IPv6 subnet in colon notation, followed by network prefix lengthOnly with the operator inExclusive with address
Valid subnet, for example, 172.22.80.0/20, 2001:db8:85a3::0/48
"type": "DNS_IP_ADDRESS",
"properties": {
"quantifier": "any",
"recordType": "A",
"operator": "=",
"address": "54.208.9.71"
"properties": {
"quantifier": "all",
"recordType": "A",
"operator": "in",
"subnet": "10.102.44.0/24"
DNS_RECORD_COUNT
Verifies the count of records of a given type.
operator
string
Comparison operator
recordType
string
DNS record type
Valid record type, for example, MX
value
integer
Expected record count
Valid count, for example 2 Range = 0–65535
80
"type": "DNS_RECORD_COUNT",
"properties": {
"recordType": "A",
"operator": ">",
"value": "80"
DNS_TIME_TO_LIVE
Verifies the time to live (TTL) of records of a given type.
quantifier
string
any
operator
string
Comparison operator
recordType
string
DNS record type
Valid record type, for example, NS
value
integer
Expected TTL in seconds
Valid TTL, for example 3600 Range = 0–2147483647
80
"type": "DNS_TIME_TO_LIVE",
"properties": {
"recordType": "A",
"operator": ">=",
"value": "80"
DNS_RECORD_VALUE
Verifies the raw value of records of a given type, with the value format depending on the record type.
Constraints process all records in a response, regardless of the section to which they belong (answer, authority, or additional).
quantifier
string
any
operator
string
Comparison operator- contains checks if the record value contains a given sequence.- matches checks if record value matches a given pattern.
contains or matches
contains
recordType
string
DNS record type
Valid record type, for example, TXT
sequence
string
Sequence of characters that the record value should containOnly with the operator containsExclusive with pattern
Non-empty sequence, for example, ms71815323
pattern
string
Pattern to be matched against the record value, with * denoting 0 or more charactersOnly with the operator matchesExclusive with sequence
Non-empty pattern, for example, "v=spf1 include:*
"type": "DNS_RECORD_VALUE",
"properties": {
"recordType": "TXT",
"operator": "contains",
"sequence": "ms71815323"
"properties": {
"operator": "matches",
"pattern": "\"v=spf1 include:*"
Related topics
  • Synthetic Monitors API
Related tags
Digital ExperienceSynthetic ClassicSynthetic Classic
