Monitor your MongoDB servers either locally or remotely!
Connect your MongoDB servers either remotely and locally. A collective batch of data is gathered every minute by this extension and sent to the Dynatrace platform for detailed analysis.
serverStatus@admin, listDatabases, and dbStats permissions. The MongoDB Built In Cluster Monitor Role has these permissions already set up.Along with the username and password you can configure the extension to:
Use a different Authentication Database (sets the authSource property in the connection string).
Add a path to a CA PEM File (sets the tlsCAFile argument of the MongoClient).
Add a path to a Client Certificate (sets the tlsCertificateKeyFile of the MongoClient).
These file paths need to be accessible on all ActiveGates in the group or locally on the OneAgent Host
Select between MongoDB Auth Mechanisms: SCRAM-SHA-1, SCRAM-SHA-256, PLAIN, DEFAULT.
If no mechanism is specified, PyMongo will automatically use a default value depending on MongoDB version.
SCRAM-SHA-1SCRAM-SHA-1 or SCRAM-SHA-256There is no charge to use the extension. You are only charged for the data that the extension ingests.
The MongoDB (local or remote monitoring) extension ingests custom metrics, which consume Davis Data Units (DDUs) (Dynatrace classic license) or Metrics powered by Grail (DPS), according to your license model.
The extension gathers a batch of data every minute. The number of metric data points produced per minute is:
per connected process/port: (17 + 5 * <number of databases>)
In the Dynatrace Platform Subscription, metric ingestion consumes Metrics powered by Grail according to the number of ingested metric data points.
To calculate the approximate yearly consumption, apply the following calculation: <metric data points per minute> * 60 minutes * 24 hours * 365 days.
In the classic licensing model, metric ingestion consumes Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point. Multiply the above formula for annual data points by .001 to estimate annual DDU usage.
When the extension runs locally on a OneAgent-monitored host, its metrics are eligible for the included metrics per host unit.
The DDU cost above does not include any possible log events or custom events that are triggered by the extension. For more information, see DDU events.
| Metric name | Metric key | Description |
| Replica Set - Oplog Size | mongodb.rs.oplog_size | The range between the earliest and latest oplog entires |
| Replica Set - Oplog Window | mongodb.rs.oplog_window | The time window covered by the oplog (Replication headroom) |
| Current connections | mongodb.current_connections | — |
| Available connections | mongodb.available_connections | — |
| Insert operations | mongodb.insert_operations2.count | — |
| Query operations | mongodb.query_operations2.count | — |
| Update operations | mongodb.update_operations2.count | — |
| Delete operations | mongodb.delete_operations2.count | — |
| Getmore operations | mongodb.getmore_operations2.count | — |
| Command operations | mongodb.command_operations2.count | — |
| Resident memory | mongodb.resident_memory | — |
| Virtual memory | mongodb.virtual_memory | — |
| Current queue | mongodb.current_queue | — |
| Active clients | mongodb.active_clients | — |
| Regular asserts | mongodb.regular_asserts2.count | — |
| Warning asserts | mongodb.warning_asserts2.count | — |
| Message asserts | mongodb.message_asserts2.count | — |
| User asserts | mongodb.user_asserts2.count | — |
| Rollover asserts | mongodb.rollover_asserts2.count | — |
| Page Faults | mongodb.page_faults | The total number of page faults |
| Uptime | mongodb.uptime | The number of seconds that the MongoDB process has been active. |
| Objects | mongodb.db.objects | — |
| Indexes | mongodb.db.indexes | — |
| Data size | mongodb.db.db_data_size | — |
| Storage size | mongodb.db.db_storage_size | — |
| Index size | mongodb.db.db_index_size | — |
| Locks - Current Global Queue | mongodb.locks.global_current_queue | The number of operations queued because of a lock. |
| Locks - Global Total Time | mongodb.locks.global_total_time | The time, in microseconds, since the database last started and created the globalLock. This is roughly equivalent to total server uptime. |
| Locks - Current Global Acquired Locks | mongodb.locks.global_acquire | Number of times the lock was acquired in the specified mode. |
| Locks - Current Global Aqcuired Waits | mongodb.locks.global_acquire_wait | Number of times the lock acquisitions encountered waits because the locks were held in a conflicting mode. |
| Locks - Global Time Acquired (Microseconds) | mongodb.locks.global_time_acquire | Cumulative wait time in microseconds for the lock acquisitions. |
| Locks - Current Global Deadlocks | mongodb.locks.global_deadlocks | Number of times the lock acquisitions encountered deadlocks. |
| Cache - Pages Requested | mongodb.cache.pages_requested | Number of pages reqeusted from the cache |
| Cache - Pages Read | mongodb.cache.pages_read | Number of pages read into the cache |
