Modify Content Security Policy for RUM Classic
  • Dynatrace Classic
  • How-to guide
  • 5-min read
Content Security Policy (CSP) is a web standard designed to protect applications from cross-site scripting and other code injection attacks. CSP rules are most commonly defined using the Content-Security-Policy response header. Alternatively, they can also be set using a <meta> tag placed in the <head> section of the HTML document.
If your application has CSP rules in place, they may block the execution of the RUM JavaScript or prevent it from sending RUM beacons to the beacon endpoint. This page explains how to modify your CSP to ensure that RUM Classic can operate as intended.
The use of CSP nonces and hashes is not supported for the RUM JavaScript. If you need to verify the integrity of the RUM monitoring code, we recommend using Subresource Integrity (SRI) instead. For details, see Use Subresource Integrity (SRI) in RUM Classic.
Allow the loading of external monitoring code
Unless you're using the snippet format inline code and have Session Replay disabled, at least part of the monitoring code is included in your application as an external file. To ensure proper functionality, your CSP rules must allow the loading and execution of scripts from the RUM monitoring code source.
  • For agentless applications, the monitoring code is loaded from the Dynatrace CDN.
  • For automatic injection, the monitoring code is, by default, served by the OneAgent that instruments your web or application server. However, you can configure it to load from the Dynatrace CDN instead. See Request the monitoring code from the Dynatrace CDN for details.
  • If the RUM JavaScript is inserted manually even though your process groups are instrumented with OneAgent, the code source configured for automatic injection is used. The only exception is the snippet format JavaScript tag, which always loads the monitoring code from the Dynatrace CDN.
To allow the loading and execution of the monitoring code, the script-src directive in your CSP rules must include the 'self' keyword if the code is served by OneAgent, and https://js-cdn.dynatrace.com if it is served from the Dynatrace CDN.
Allow the execution of inline code
If you use the snippet formats inline code or code snippet, the script-src directive in your CSP rules must include the 'unsafe-inline' keyword to allow the execution of the monitoring code.
Allow sending RUM beacons
RUM beacons are sent to a beacon endpoint, with the default endpoint varying based on the application type:
  • For agentless applications, beacons are, by default, reported to a Cluster ActiveGate that is part of the Dynatrace SaaS infrastructure.
  • For auto-injected applications, beacons are, by default, reported to the OneAgent that instruments the web or application server where the application is hosted.
Alternative setups are described in Configure beacon endpoint for web applications in RUM Classic.
To allow the RUM JavaScript to send beacons, ensure that your CSP rules include the appropriate endpoint in the connect-src directive.
  • Use the 'self' keyword if the beacon endpoint is the OneAgent that instruments the application.
  • If you configured a OneAgent that instruments a different web server as a beacon endpoint, specify the corresponding URL.
  • If the beacons are handled by a Cluster ActiveGate, use the beacon endpoint URL shown in the UI.
To find the URL for a Cluster ActiveGate
  1. Go to Web.
  2. Select the application you're adjusting the CSP rules for.
  3. In the upper-right corner of the application overview page, select More (…) > Edit.
  4. From the application settings, select General settings > Beacon endpoint.
  5. Copy the URL next to Configured beacon endpoint.
Allow Session Replay
If you use Session Replay, your CSP rules must allow the RUM JavaScript to load code as a blob. For details, see Modify Content Security Policy for Session Replay.
Additionally, even if you're using the snippet format inline code, make sure your CSP rules allow the loading of external monitoring code. This is important because the monitoring code for Session Replay is always requested as an external file, regardless of the snippet format.
Examples
Below is a basic example of a simple CSP rule:
Content-Security-Policy: script-src 'self'; connect-src 'self';
The following examples show how this rule needs to be adapted for different RUM scenarios.
Examples for automatic injection
If you're using automatic injection with the default configuration for both the beacon endpoint and the monitoring code source, the basic CSP rule above is sufficient—as long as Session Replay is not enabled, and the snippet format OneAgent JavaScript tag is used.
If the snippet format is changed to inline code or code snippet, you must allow inline scripts by adding 'unsafe-inline':
Content-Security-Policy: script-src 'self' 'unsafe-inline'; connect-src 'self';
If the monitoring code is loaded from the CDN, update the script-src directive accordingly:
Content-Security-Policy: script-src 'self' https://js-cdn.dynatrace.com; connect-src 'self';
If the beacon endpoint is changed to a Cluster ActiveGate, update the connect-src directive:
Content-Security-Policy: script-src 'self'; connect-src 'self' https://ab12345cde.bf.dynatrace.com/bf;
If you use Session Replay, you also need to configure the worker-src directive:
Content-Security-Policy: script-src 'self'; connect-src 'self'; worker-src blob:;
Examples for agentless monitoring
For agentless monitoring, both script-src and connect-src must be adjusted:
Content-Security-Policy: script-src 'self' https://js-cdn.dynatrace.com; connect-src 'self' https://ab12345cde.bf.dynatrace.com/bf;
If you're using inline code, include 'unsafe-inline' in script-src:
Content-Security-Policy: script-src 'self' 'unsafe-inline'; connect-src 'self' https://ab12345cde.bf.dynatrace.com/bf;
If you're using the code snippet format, include both 'unsafe-inline' and the code source URL in script-src:
Content-Security-Policy: script-src 'self' https://js-cdn.dynatrace.com 'unsafe-inline'; connect-src 'self' https://ab12345cde.bf.dynatrace.com/bf;
If beacons are sent to an instrumented web or app server, include its URL in connect-src:
Content-Security-Policy: script-src 'self' https://js-cdn.dynatrace.com; connect-src 'self' http://www.example.com/rb_abcdefghi;
If you use Session Replay, you need to configure the worker-src directive:
Content-Security-Policy: script-src 'self' https://js-cdn.dynatrace.com; connect-src 'self' https://ab12345cde.bf.dynatrace.com/bf; worker-src blob:;
If you use Session Replay with the code snippet or inline code format, you need to configure the worker-src directive and include both 'unsafe-inline' and the code source URL in script-src:
Content-Security-Policy: script-src 'self' https://js-cdn.dynatrace.com 'unsafe-inline'; connect-src 'self' https://ab12345cde.bf.dynatrace.com/bf; worker-src blob:;
Related tags
Digital ExperienceWeb Classic
