Log Monitoring Classic
  • Dynatrace Classic
  • 2-min read
With Log Monitoring as a part of the Dynatrace platform, you gain direct access to the log content of all your mission-critical applications, infrastructure and cloud platforms. You can create custom log metrics for smarter and faster troubleshooting. You will be able to understand log data in the context of your full stack, including real user impacts.
Log Monitoring Classic end-of-life
Log Monitoring Classic (SaaS) will reach end-of-life by 2027. For details, see the Log Monitoring Classic end-of-life announcement in our release notes.
We recommend upgrading to Log Management and Analytics well in advance.
Ingestion channel overview
Ingest & Processing
Set up automatic log collection, and extract value with Log Processing.
Analysis
Analyze significant log events across multiple logs, across parts of the environment (production), and potentially over a longer timeframe.
Alerting
Define patterns, events, and custom log metrics to receive proactive notifications.
API
Use the Dynatrace API to send log data to Dynatrace and quickly search, aggregate, or export the log content.
Configuration
Get the latest Log Monitoring
Tweak your setup
Default limits
Supported log data format
Connect log data to traces
Log ingest rules
Log Monitoring FAQ
Log data acquisition
Autodiscovery
Add log files manually
Generic log ingestion
Cloud log forwarding
Logs from Kubernetes
Add log sources
Log processing
Log data analysis
Log viewer
Log events
Log metrics
Log custom attributes
Management zones
Related topics
  • Log monitoring
  • DDUs for Log Monitoring Classic
