Stream logs to Dynatrace with Fluent Bit
  • Latest Dynatrace
  • Tutorial
  • 3-min read
You can send logs to Dynatrace using Fluent Bit. Configure Fluent Bit to send logs to the Dynatrace generic ingest API.
Capabilities
  • Fluent Bit is a multiplatform log processor and forwarder that allows you to collect data/logs from different sources, unify and send them to multiple destinations. It is compatible with the Docker and Kubernetes environments.
  • Dynatrace can be configured as the target log management and analytics environment for your data thanks to Fluent Bit's configurable http output.
  • You can use any of Fluent Bit input plugins to get logs and events from your application to Dynatrace.
Configuration
The Fluent Bit http output plugin allows you to stream your logs to the Dynatrace generic logs ingest endpoint.
  1. Get an access token:
    • Platform token: with the openpipeline:logs:ingest scope. See Platform tokens.
    • Classic access token: with the logs.ingest (Ingest Logs) scope. See Access tokens classic.
  2. Deploy Fluent Bit.
  3. To send logs into the Dynatrace generic logs ingest endpoint, configure the http output plugin through the configuration file.
  4. In your main Fluent Bit configuration file, append the Output section with the following parameters:
[OUTPUT]
name http
match *
header Content-Type application/json; charset=utf-8
header Authorization Bearer {your-platform-token}
allow_duplicated_headers false
host {your-environment-id}.live.dynatrace.com
Port 443
URI /api/v2/logs/ingest
Format json
json_date_format iso8601
json_date_key timestamp
tls On
tls.verify On
[OUTPUT]
name http
match *
header Authorization Api-Token {your-classic-access-token}
Port 443
Format json
tls On
tls.verify On
You can place your API token in the header or as GET variable in URI (see example below).
  • For Dynatrace SaaS, the generic logs ingest endpoint is available in your environment.
  • If Environment ActiveGate is your choice for an endpoint in local environment, install ActiveGate instance.
    In Dynatrace Hub, select ActiveGate > Set up.
  • Generic log ingest API v2 is automatically enabled on ActiveGate.
Example: Ingest ECS Fargate logs with Fluent Bit
Fluent Bit is the recommended solution whenever reducing resource consumption is critical. The example below describes how you can configure the ingestion of AWS Fargate logs with Fluent Bit.
When creating a new task definition using the AWS Management Console, the FireLens integration section makes it easy to add a log router container. Follow the steps below to configure log ingest:
  1. In the AWS Management Console, go to the Firelens integration section.
Final log integration page in AWS Management Console
  1. Pick the built-in Fluent Bit image.
  1. Edit the container in which your log-generating apps are running.
  1. In the Storage and Logging section, select awsfirelens as the log driver.
Set AWS Firelens as a log driver
The settings for the log driver should point to the log ingest API of your SaaS tenant. You need to provide two headers for Fluent Bit: content type and authorization token. As FireLens supports only one header, you can pass the content type as part of the URL. Your configuration for AWS FireLens should contain certain key-value pairs, as shown in the code block below.
TLS: on
Format: json
Header: Authorization Api-Token {your-API-token-here}
Host: {your-environment-id}.live.dynatrace.com
Port: 443
URI: /api/v2/logs/ingest?Content-Type=application/json
Allow_Duplicated_Headers": "false"
Json_Date_Format": "iso8601"
Json_Date_Key": "timestamp"
To avoid publishing the token in plaintext, follow the steps in AWS Secrets Manager. Once your application starts publishing logs, you can view them in the Dynatrace UI.
Refer to AWS sample repository for the task definition JSON with Dynatrace configuration.
For more configuration details, see Amazon ECS Developer Guide.
Troubleshooting
Visit Dynatrace Community for troubleshooting guides, as well as see Troubleshooting Log Management and Analytics.
  • Troubleshooting logs ingested via Fluent Bit
Related tags
Log Analytics
